Islineclear3_1
I remember the days when these used to be lit by paraffin lamps. When were they replaced by electric lamps (and back-up battery) please?
The bulbs were underrun, partly for long life, partly to make their glow more yellow and closer to the parafin flame colour; this eliminated the need to change the blue filter for a green one. Some modern replacement LED-fitted lamps have, I am told, needed the blue filter to be replaced by a green one.Does anyone know if the conversion required a change to the "green" glass on the signal arms. As paraffin burns with a yellow flame, these glasses were originally blue in order to show a green light. Or were yellow bulbs fitted when the lamps were converted?
Yes, they were on the Settle-Carlisle line and were converted to electricity upon the retirement of lamp man Peter Akrigg.Not specifically Southern, but I believe NR (possibly Railtrack at the time?) trumpeted the demise of the last paraffin-lit semaphores some 15-20 years ago.
Yes, the indicators were used both with parafin and electric signal lights. We have several on our block shelf at St Albans South, although not yet in working order.IIRC when I visited signal boxes in my youth, there were "lamp in/lamp out" indicators on the instrument shelf to prove that the signal lamps were alight. I assume these were for oil lamps. Were these indicators still used when the lamps were converted? I wonder why working signal lamps were "in" rather than "on". Special railway jargon again?
It's easy to confuse On and Off verbally - possible reason?As to the 'In' and 'Out' names I am uncertain.
Thank you kind sir. Yes I have this book too and had a cursory glance but couldn't see anything in there. I'm currently printing up some photos of the remaining SR semaphores which, obviously have electric lights but I remember as a young man, being up and down signal boxes and remember well, the paraffin lamps. I think I even have one in my possessionI've had a quick look through my copy copy of G Pryer's "A Pictorial Record of Southern Signals" (Oxford Publishing Co., 1977). He does not make any specific comment on this, but it would seem that generally when a line was electrified without updating the signals to colour lights, the semaphores were fitted with electrically-powered lamps. So the conversion was a gradual process. Interestingly none of my other books on the history of signalling give any indication, other than there were electrically-lit semaphores on the Liverpool Overhead Railway from 1893 onwards.
Thanks John Webb and 30907. I hadn't thought about swapping the inner burner assemblies. Makes perfect sense.It's easy to confuse On and Off verbally - possible reason?
Though signals are on/off OTOH....
