Queensbury Tunnel Petition
IanD
18 Sep 2011
Newport Pagnell
Apologies if this has been raised before or is in the wrong place!
The Queensbury Tunnel Society have started a petition to stop Highways England’s Historical Railways Estate (HRE) from spending £3M on sealing off Queensbury tunnel (on the old Great Northern line between Bradford/Keighley and Halifax) but rather to spend a slightly smaller amount to make it safe and therefore potentially useable as a cycle/walking route - eventually becoming a link in the Great Northern Railway trail.
Parts of the old Great Northern routes between Bradford/Halifax/Keighley which are alreday preserved of make for excellent walking and cycling. Preserving Queensbury Tunnel could only enhance the experience.
Link to the petition here:
https://www.change.org/p/department-for-transport-securing-a-beneficial-future-for-queensbury-tunnel
29 Aug 2010
It's a bit long... 2.3km i think. Great idea in principle. Also preserves the line / right of way for future use :)
IanD
18 Sep 2011
Newport Pagnell
I didn't realise it was that long. Ventured that way in the early eighties (and a few times since) to have a look at the remains of the GN network in the area. Got chased off by farmers occasionally but never got far into the tunnels.
Clip
28 Jun 2010
Ha ha you're optimistic. Once they get converted to a cycle/walkway they will never be returned to a railway!!
sonorguy
18 May 2011
Not always, the extension of the T&W Metro into Sunderland meant that about 1 and a half miles (or so) of recently created cycle/walkway and carpark was all ripped up and reverted to it's original use, including section in a cutting that had been completely back-filled.
Railsigns
15 Feb 2010
Not always, the extension of the T&W Metro into Sunderland meant that about 1 and a half miles (or so) of recently created cycle/walkway and carpark was all ripped up and reverted to it's [sic] original use, including section in a cutting that had been completely back-filled.
Same with Airdrie to Bathgate (about 15 miles).
Pinza-C55
23 May 2015
And several bridges that had been demolished 10 years earlier had to be rebuilt at enormous extra expense.
IanD
18 Sep 2011
Newport Pagnell
One thing's for sure, if they seal it up, it will never see use again - rail or otherwise. At least converting it to a cycle route gives the option of rails being reinstated however slim the chance may be.
w1bbl3
6 Mar 2011
The tunnel is prone to flooding and various parts of the linings have failed previously or are considered in a state likely to fail.
The sealing plan is based on the principle that once sealed the tunnel will be impossible to repair further in the future. Cover is generally good but with local sections of under 40m depth.
The concerns are that the tunnel will without ongoing maintenance collapse around the access shafts, two of which are located near to houses the cost which would be substantial if the tunnel was to fail. In detail both portals would be filled with 20m of foam concrete and the shafts backfilled the rest the tunnel would be allowed to collapse over time.
The repair option as proposed for the cycleway will render the tunnel unsuitable for reuse later for twin track rail with significant sections being narrowed by new linings of upto 1m in thickness reducing the bore to 5.4m wide and 5m high.
Xenophon PCDGS
17 Apr 2011
Is what you describe about the collapse of shafts similar to what occurred in "Black Harry's Tunnel" in Swinton in April 1953 where houses had been built over shaft areas in which five of the residents were killed?
Joe D
20 Feb 2016
And quite a bit on Borders Railway, at Eskbank and again through Galashiels and Tweedbank.
It's almost like every single example of a reopening is proof of the nonsense of the statement.
30907
I cannot see even the remotest chance of a future rail use, given that Queensbury to Bradford is almost entirely built over - whereas a cycle route Halifax-Keighley is at least plausible.
Not necessarily. The Clifton Hall incident involved a backfilled shaft, the contents of which was supported by timbers, which rotted over time and eventually were unable to support the weight of the backfill.
In the case of Queensbury, it would appear the bigger issue is with still-extant shafts, where the base of the shaft lining fails and is unable to support the brickwork above. This can be seen in many disused tunnels, where the base of the shafts is often marked by piles of bricks.
Bevan Price
22 Apr 2010
Even if the line was not built over, Queensbury station had one nearly unsurmountable problem - it was located at the foot of the valley - but most of the people live on / near the top of the "hill".
A long, steep climb from the station to your home is an unattractive option, when there are fairly frequent bus services close to the residential areas.
Not to mention that Halifax to Bradford already has a rail service, so any revival of the Queensbury route (lovely though this would be from an enthusiast point of view!) would be simply to serve intermediate local traffic. Doubtless some people would find it useful, but enough to cover costs?
