Quadruple headed container train
sjm77
8 Jan 2020
Manchester
4K51, a Freightliner container train from Trafford Park to Crewe, has just crawled past my window with 4 class 90s at the front! Is this normal? Or are they just using a scheduled freight train to relocate locomotives from A to B rather than sending them as a loose engine on their own and requiring an extra main line path?
greyman42
14 Aug 2017
4K51 has just crawled past my window with 4 class 90s at the front! Is this normal? Or are they just using a scheduled freight train to relocate locomotives from A to B rather than sending them as a loose engine on their own and requiring an extra main line path?
Were the pans up?
D6975
26 Nov 2009
Bristol
Light engine movements cost money. Adding locos to a service is a cheaper way of getting them from A to B.
driver9000
13 Jan 2008
Most likely it's the 2 leading locos with the pans up and 2 dead locos in transit to save a separate light move and crews.
Deepgreen
12 Jun 2013
Gomshall, Surrey
There can be some spectacular headers to freights, but with only one loco powering. Of course it could be that extra adhesion was sought and two were powering.
Probably also a little 'greener'.
Lucy1501
9 Nov 2021
Cumbria
I was at Carlisle last week and saw something similar. A flask train heading to Sellafield with four 68s (only one seemed to be taking power) alongside four flasks, quite an odd sight compared to what I was expecting.
Numbskull100
29 Jul 2017
Other than exceptionally light <1000t (ish) trains, 90s always run in pairs. Their 110mph gearing and light weight requires this.
Class15
30 Dec 2021
North London or Mildmay line
On Saturdays Freightliner wants the fleet at Basford Hall for the weekend so will run multiple out from a terminal to Basford Hall.
90s are almost always double headed.
If it’s 90s, I doubt it? But maybe there’s some other reason?
william.martin
18 Oct 2022
Telford
As you say, a cheaper way of moving locos without placing in an extra path, also it could be that 2 of the locos failed so they were rescued by another 2 en route.
