The EU Council has published its draft regulation amending the EU261 air passenger rights legislation (attached).
Someone has summarised the changes on Flyertalk. There are a number of positives:
But arguably some of the negative changes outweigh this:
The proposals are yet to be voted on by the EU Parliament as I understand it, so let's hope that some of the negative changes are removed or lessened before it becomes the law.
- The ability to drop the outward leg of the journey without penalty - see Article 4(5a): “Passengers shall not be denied boarding and shall not be charged any fee on the inbound journey, including one which consists of connecting flights, on the grounds that they did not take the outbound journey under the same air transport contract.”. Given the definition of “journey” is “a flight or connecting flights transporting the passenger from the initial point of departure to the passenger’s final destination in accordance with a single air transport contract, with outbound and return flights being separate journeys” I don’t think any argument about this including skip-lagging would carry weight. Of course, there will still be ways of saving money by booking a return in the “wrong direction” when you want to make a one-way flight priced at a premium, e.g. transatlantic business class. Existing precedents in Germany, Austria and Italy recognise this as justifiable under consumer or contract law, so this isn’t a completely new concept.
- A requirement for fares to include both a personal item and a piece of hand luggage by default (i.e. larger bag or small suitcase). Elsewhere it has been reported that the latter is only up to 7kg or up to a total dimension of 100cm (width/length/height combined, which really isn’t much and is less than the standard IATA size trolley bag) but I can’t see any reference to those limits in Regulation 2(zfa) defines the former as up to 40x30x15cm and the latter as “a piece of unchecked baggage which is not a personal item and which complies with security and safety requirements”. Given there are currently no material weight or size limitations for hand luggage at security I wonder if the airlines will either try to argue their overheads can’t take more than a small amount of weight (to charge for heavier cases) or whether they will charge extra for being guaranteed to have your second item in the cabin.
- New rights during “tarmac delays”, defined as any 30+ minute period between the aircraft door closing and takeoff, or between touchdown and the door opening. These include free water, access to toilets and A/C, albeit with exceptions if it would lead to a greater delay etc. After a 2+ hour delay the aircraft is required to return to a stand to allow passengers to disembark unless infeasible. I wonder if this will actually change anything on the ground, because there is no obvious mechanism for enforcement or penalty for non-compliance. Still, a good right to have in principle.
- Explicit enumeration of case law on several points, e.g. that diversions to an alternative airport count as a cancellation unless it is to an airport serving the same city/town/region, and whether rebooked or diverted, alternative transport must still be provided to the booked destination and the delay timer keeps counting until you actually reach the booked destination airport.
- A ban on Ryanair’s boarding pass shenanigans such as being required to use a specific app or log in to check in or show your boarding pass, being denied boarding if you print out an electronic boarding pass, or being charged a fee for printing boarding passes once checked in. Similarly you can’t be required to log in to submit a compensation etc. claim
- The right to free water and phone charging facilities in airport terminals. In fairness it’s been a while since I saw an airport charging for either but good to have this enshrined. Again no specific penalty or enforcement mechanism is specified so this may be better enforced by some countries’ National Enforcement Bodies than others.
- The establishment of a 30 day deadline for airlines to respond to compensation claims and a requirement to provide more reasoning as to any ‘exceptional circumstances’ defence relied on. Seeing as there is no penalty for non-compliance I can’t exactly imagine this will change much but it’s nice to have on paper.
- Explicit enumeration of the right to self-rerouting (and the right to be reimbursed reasonable expenses for this - but see the next section for limitations) if an airline fails to offer re-routing within 3 hours of the scheduled departure time, or the re-routing isn’t under comparable transport conditions. The legislation gets painfully close to explicitly stating that re-routing must be as quick as possible, but then suggests that one of the acceptable options for an airline to offer would be “a different routing [i.e. connecting flights] between the same airport of departure and of arrival as stated in the air transport contract”. No doubt airlines will seize upon this as evidence that they don’t need to provide a direct same-day alternative… Talk about snatching defeat from the jaws of victory.
- Clarification of the refreshments you are entitled to during a delay, i.e. a meal after 3 hours’ delay and every 5 hours thereafter up to a maximum of 3 meals a day and a requirement for any meal vouchers to be accepted at all airport shops, not just ones the airline’s chosen voucher provider has an affiliation with.
- A new requirement for airlines to “pay out” any vouchers that passengers originally accepted (in lieu of cash compensation/refunds) if they aren’t fully used within a year of issuance. Also, “All options … shall be clearly displayed, without being subject to pre-selection, default settings or additional procedural burdens which favour one option.” No doubt squarely aimed at the scummy refund processes adopted by the likes of Wizzair (when I last had a cancellation with them, they first required you to obtain a voucher and then convert this into a cash refund).
- Additional rights for PRMs and musicians travelling with instruments in the cabin.
- Airlines would now only be required to provide up to 3 nights of accommodation if exceptional circumstances apply. Ryanair fought this after the Icelandic ash cloud and lost at the CJEU - so why is the EU legislating to overturn that long-established decision? There doesn’t seem to be any evidence that it imposes unreasonable costs on airlines. If anything, the obligation to pay for accommodation until people are rebooked currently serves as an encouragement to quick (possibly cross-carrier) re-routing. The ostensible justification in Recital 31 is that “contingency planning and speedy rerouting should lessen the risk of passengers being stranded for long periods contingency planning and speedy rerouting should lessen the risk of passengers being stranded for long periods” but this seems hopelessly naive as to the reality on the ground when there’s widespread disruption (e.g. after the closure of ME airspace, NATS system failure etc.)
- The introduction of a 9 month time limit for submitting compensation claims. Given the statute of limitations is considerably longer in most countries this represents a substantial lessening of passenger rights. That said, this is likely targeted at reducing claims management companies’ business and in fairness, if you are truly inconvenienced by a delay I don’t think it’s unreasonable to expect you to submit your claim within that period. This was probably a sweetener added in to limit airlines’ liability and thus cap their overall ‘bill’.
- A new reduction of compensation if rebooked to depart earlier: 25% for 2-3 hours earlier, and 50% if rebooked 1-2 hours earlier. Until now, both attracted the full rate of compensation although the law was somewhat ambiguous on this point, which airlines exploited. Disappointing to see the EU legislating in favour of the non-compliant airlines, overwriting existing CJEU precedent - no doubt lobbied for by the likes of A4E.
- Existing case law is overriden to redefine “arrival time” as the time the aircraft’s brakes are applied on stand, rather than the time the doors open, unless there is a tarmac delay (i.e. 30+ min delay in opening the doors). This works very much in the airlines’ favour and effectively slightly increases the current delay thresholds. Obviously it’s much easier to independently verify the arrival time on stand than the time the doors opened, but this is clearly an anti-passenger measure.
- You would be required to present yourself at the gate in good time to be eligible for IDB protections, not just at checkin as is the case now. A crucial distinction given the current EES mess, since airlines can currently be held responsible if you miss boarding due to security or passport delays (see Caldwell v easyJet). Seems to be another case of endorsing the airlines’ current failure to comply with the law.
- A new cap of 400% of the original fare paid when claiming back self-rerouting costs. Given that “walk-up” fares can be extortionate this severely limits the practical usefulness of this right. I appreciate the airlines will have lobbied for this to protect their financial interests but if you have bought a bargain-basement economy light/basic fare for say 30 Euros, what use is the ability to claim back 120 Euros when you have to pay 500 Euros for a new flight that actually leaves the same day (as opposed to the flight next Wednesday which Ryanair may be offering…).
- Disruption to Greenlandic internal flights would be entirely excluded from compensation if part of a journey to the EU (they are outside the scope of EU261 if purely booked as a domestic journey). Again, it’s unclear why this is considered necessary when the legislation has applied to these flights for the last 20 years? It looks remarkably like Danish lobbying on behalf of Air Greenland...
