Promise to pay still valid?
molliepoppie
7 May 2026
Doncaster
My commute to work starts from a rural station with a card only ticket machine so I get a promise to pay when I pay with cash. I change at a city station with a manned ticket office but my change over is only 5 minutes and it's the other side of the station. The next train after that is half an hour later and will make me late for work. Will my promise to pay be valid on the second train?
jfollows
26 Feb 2011
Wilmslow
You don’t have to delay yourself in order to buy a ticket at the station where you change.
See https://assets.nationalrail.co.uk/e...e/National_Rail_Conditions_of_Travel_2026.pdf
In these cases, you must buy an appropriate Ticket to complete your journey as soon as you are reasonably able to.This should either be onboard from a member of the train staff – or else as soon as you leave the train and before you exit the station at your destination.
I know that’s a bit vague, but we’ve had a similar discussion before which you should find if you search the forum.
Belperpete
17 Aug 2018
Will you need to pass through a barrier line or ticket inspection to change trains? If so, in practice, you may encounter difficulties using the promise to pay to get through.
And are you allowing the official minimum connection time between trains? For example, the minimum connection time at Doncaster is 7 minutes - anything less isn't regarded as a valid connection. In which case, if the official next connection isn't for half an hour, you could be expected to buy a ticket in that time.
It would be much easier to give precise information if you gave precise details, rather than a vague "a city station".
We need to know the exact journey you're making to advise with accuracy.
