Jubilee Line Southern Extension. For massively improved connectivity/modal shift and to free up the land where west ham depot is. Some other TOD might be possible in the SE. Route Idea Below. Would love to hear criticisms or alternative ideas.
The existing route would split in 2 at North Greenwhich, north to stratford and south along new route. There would also be branch going from stratford on existing lines then continuing south on new route from North Greenwhich. In that way the capacity is still there. Passengers could jump on the first train at Stratford and change at North Greenwhich if wanting to go west. Has EL reduced demand on this corridor anyway?
Phase 1
- From North Greenwhich, which was built with 3 platforms partly to facilitate a possible future extension.
- Emerge above ground as soon as possible to run elevated along either Parkside or Millenium Way, which are both 2 lanes in each direction with a median in between. A station to serve the large new and in-progress housing developments on the peninsula, location to be further studies but there are a number of options.
- Turning south at either Blackwall Lane, Commercial Way, or Peartree Way to run along the A2, either at grade or elevated, and whatever alignment creates the least conflicts. It would require taking 1 or 2 lanes taken away from the A2 but the connections created will greatly reduce traffic levels given driving is the best option for much of SE London to get to North Greenwhich and beyond. I also note there is an existing freight corridor along this path. but it is partly single track and the access might need to be maintained.
- Station perpendicular to Westcombe Park station, maybe on Westcombe Hill road with improved pedestrian access over the A2.
- New station where the A2 meets Charlton Road, Old Dover Road, or Shooter's Hill Road. There isn't much room for development at any location so should go where the best bus connections are or have potential for enhancement. I also note there is the existing rail tunnel for Blackheath to Lewisham services, but I think it would create too many issues with existing services to use that, better to create new connections along new route and serve areas where this is currently no rail station at all.
- Station connecting to Kidbrooke Station. Massive development here, some of which is still in progress, currently only served by national rail 6 tph on 3 different routes.
- It could terminate there. The West Ham depot could relocate to somewhere along this route on the peninsula or where the Charlton Police Car Pound is, with the police depot in-turn relocated or rebuilt above or next to the train depot. This might not be big enough and would itself become much more valuable land if the extension happened, so one of the following branches would work better for the depot itself. Could also be part of phase 2. The West Ham depot is in a location right next to DLR route to Stratford and a new station could also be added on JLE1. This could be a massive new development.
Phase 2 or branch 1 options
Eltham
- Take over existing NR lines to Dartford. New depot at Slade Green. Might not be popular idea similar to resistance from some Hayes residents for bakerloo taking over their existing big trains. Could Jubilee share tracks with NR?
- Alternatively running along A2 Rochester Way with new stations at various points along the route. Again this would serve areas where this is currently much better car than public transport infrastructure, at least once you get beyond Falconwood. If this route was taken it could turn NW where the A2 meets the Sidcup line, quad track to Crayford station for connection and new depot in the industrial area there.
A20 corridor
- This corridor brings in connections to another existing rail line
- Turning SW at A205 to Clifton Roundabout. This is also 2 lanes in each direction with median in the middle. Could run elevated with pillars in the median in order to maintain current traffic lanes. new station somewhere between Yorkshire Grey roundabout and Clifton Roundabout.
- From there, again, it could take over existing NR route (or share track? again I don't know if feasible) and run along to Crayford with depot in same place as Eltham route.
- Or running along A20, this would almost certainty require taking away a traffic lane or two. But I don't believe this route is as busy as the A2 and given modal shift it might be OK. New station where A20 meets Court Rd to connect to Mottingham station, which is 120m away. This short road section is 4 lanes including turning lane and parking/bus stop. One lane could be removed to expand room for interchange. The shops here would greatly benefit from the increased footfall. 1 or 2 new stations along Sidcup bypass then, importantly, a station at Queen Mary's hospital which is 1.5km from nearest station. New station where A20 meets Sevenoaks way, with improved bus priority going N/S from here. Slightly to the north is large industrial area where depot could go.
Bromley
- really a separate but complementary proposal, as much as my crayons want to take this to the bromley North branch, the railway from Lee around to Grove Park is too complex and the road narrows down to 2 lanes before it meets this line.
- instead I think a BRT take-over the BromNor line would be a big improvement, connecting through to serve civic centre and bromley South. And north from grove Park on baring Road and/or burnt Ash Road with either bus lane or closing the road to through traffic with bus gates (allowing residents still).
- Once joining south circular to travel in bus lane to an interchange with JL then up Eltham hill in bus lane to serve high street before heading to Eltham station.
