Preston to Swindon - valid via Newport?
SSp
26 Oct 2016
Hi all, first post. I’m travelling from Preston to Swindon on Friday 4th November, coming back on Sunday 6th November.
I’m sure in the past when going instead from Manchester, it has been valid to go via Newport (South Wales) but it is not being shown on itineraries. Travelling via Reading is being suggested but this is going just as far east as Newport is west...! I’m trying to avoid as much travelling on Cross Country as possible and I know the Welsh Marches route is normally much more pleasant on a Friday.
Coming back on Sunday 6th there also seems to be a problem east of Swindon, and travelling via Newport on the 09:10 would also seem preferable to avoid buses and loads of changes, but again isn’t suggested - is this valid given the diversions in place?
One outbound alternative could be to get a Preston to Swindon "not via London" but then excess the outward journey to be valid via London. If I do this, what journey restriction code does the outward ticket hold – the original restriction code not via London, or the new (and more restrictive in terms of timings - from permitted travel at first train of 08:17 instead 09:58) one via London?
Welcome to the forum :)
There does not appear to be a mapped route via Newport. Perhaps someone can look at whether it was ever valid that way. There may well be an alternative destination you can book to, that would allow it.
The new conditions apply.
DaiGog
23 Oct 2013
Sometimes Mirfield, sometimes Hull, often Niebüll
Swindon to Shrewsbury / Wrexham / Chester / Liverpool / Runcorn East is showing as valid via Newport, but Swindon to or anywhere via Crewe / Warrington / Manchester is not.
Maybe split your tickets at Shrewsbury or Newport if you want to travel via Crewe and Newport?
John @ home
1 Mar 2008
The cheapest flexible through Preston Lancs - Swindon Wilts return ticket is the £84.90 Off-Peak Return route Not Via London (£56.05 if SSp has a Railcard) but, as yorkie points out, this is not valid via Newport S Wales. This ticket is valid by all trains except those timed to depart Mon-Fri 0430-0753.
The cheapest combination of flexible tickets I've found which would allow a Preston Lancs - Swindon Wilts return journey via Newport S Wales costs £99.00 (£65.35 with a Railcard):If using this combination of tickets, you need to use trains which call at Shrewsbury and Abergavenny. All relevant trains call at Shrewsbury. All except the 0810 Mon-Fri departure from Shrewsbury call at Abergavenny.
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
I believe that you could use this combination of tickets, which at £89.60 is marginally cheaper. However, you would need to ensure that your trains stop at Leominster, and they don't all. So I suppose it's a question of whether it's worth the inflexibility for the saving.
OFF-PEAK R - PRESTON LANCS to LEOMINSTER
ANY PERMITTED £49.40
ANYTIME R - LEOMINSTER to SWINDON (WILTS)
ANY PERMITTED £40.20
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Another option which only requires a stop at Shrewsbury, and is a few pounds cheaper than John@Home's example, is:
Off-Peak Return Preston to Shrewsbury £38.60 (valid any time)
Super Off-Peak Return Shrewsbury to Didcot Parkway route VIA NEWPORT £58
The second ticket is valid to stop short at Swindon and the only time restriction on the outward portion seems to be that you can't depart Newport before 10:00, which shouldn't be an issue if you're coming all the way from Preston.
Total Price £96.60
SSp
26 Oct 2016
Thanks for all the suggestions. One thing I was thinking of was a return to Bristol Parkway (valid via Newport) and starting the return leg on 4th and completing on 6th... but I doubt this is OK and means I'd not be able to go back via Newport on the Sunday, enforcing some north or eastbound bustitution!
lightning76
27 Aug 2009
Leighton Buzzard
Although I cannot provide any evidence, I do remember reading, many years ago - before joining this forum or being aware of the routeing guide etc. - that journeys from Paddington (and points west) to the North West via Newport were considered "reasonable" by BR, I believe due to some sort of historical Western Region / GWR (the proper one!) validity.
Whilst this doesn't cut any ice today, it does support the view of the OP that such a route would have been valid at some point in the past.
island
30 Dec 2010
I know London to Oxford was at one point valid via Newport S Wales!
319321
13 Apr 2013
I have checked the 1997 Routeing Guide and Manchester (Routeing Point) to Swindon (Routeing Point) was permitted via Swindon using map BD. Preston (Routeing Point to Swindon (Routeing Point) was not permitted via Newbury at that time.
