Mcr Warrior
- Joined
- 8 Jan 2009
- Messages
- 17,239
Is a Preston (Lancs) -> Edinburgh Off Peak Return or Off Peak Day Return (both routed "via Carlisle") valid / still valid via Glasgow Central / Glasgow Queen Street?
The fares to Glasgow are nearly identical, so you could buy those in future? A ticket to somewhere like Falkirk is unambiguously valid both either Edinburgh or Glasgow, albeit there's no Off-Peak Day Return, in case that's what you were using.Thanks. Avanti guard not overly happy when inspecting my ticket between Carlisle and Glasgow Central today, but I politely stood my ground, and he eventually moved on.
Subsequently was left wondering whether someone might have sneaked in a negative easement or some such in the last year or so, however National Rail website was showing apparently valid itineraries via Glasgow Central quoting the Off Peak fare.
The Preston to Edinburgh off peak ticket allows for a more varied / flexible itinerary, including travel across Central Scotland via Glasgow, then Falkirk or Airdrie, and gives something of a safety net if WCML services to/from Edinburgh are delayed/cancelled. And, as you say, there's no Off Peak Day Return to Falkirk or Airdrie.The fares to Glasgow are nearly identical, so you could buy those in future? A ticket to somewhere like Falkirk is unambiguously valid both either Edinburgh or Glasgow, albeit there's no Off-Peak Day Return, in case that's what you were using.
Preston to Croy is part of the same flow as Preston to Glasgow, so the fares and restrictions are the same (i.e. it includes the cheap CDR). However, unlike a ticket to Glasgow, it allows travel via the same routes as a ticket to Falkirk - i.e. including via Edinburgh and/or any of the E-G lines.The Preston to Edinburgh off peak ticket allows for a more varied / flexible itinerary, including travel across Central Scotland via Glasgow, then Falkirk or Airdrie, and gives something of a safety net if WCML services to/from Edinburgh are delayed/cancelled. And, as you say, there's no Off Peak Day Return to Falkirk or Airdrie.
