Prentendo Mk3
I T S
3 Jul 2010
What will happen to the Prentendolino Mk3 set once it goes over to First Group??
Am I right in Saying the 1843 Euston / Crewe on Friday 7th Dec will be the last VIRGIN TRAINS operated Mk3 service to operate?
sprinterguy
4 Mar 2010
Macclesfield
As far as I am aware, the Pretendolino is being retained within the West Coast franchise with First, although I do not believe that there has been anything official saying this.
I imagine that you would be correct in your theory that December 7th's 18:43 from Euston will be the last VT mark 3 service.
Pumbaa
19 Feb 2008
The Pretendo is not required to be taken on by First. Nor have they stated if they will or not.
My personal hunch and the hunch of others is that it will not be transferred as part of the new franchise.
The Ham
6 Jul 2012
I would have thought that until they have all their new rolling stock (the new 6 coach trains) and have sorted out the new seating configurations that First will need or at least like to option to fall back on the Pretendo
Anon Mouse
20 Mar 2011
Yeah I agree. The Pretendo will certainly not fit into their long term plans but at least until the promised new trains are in service I suspect it will remain in service, unless they can get a spare Voyager or Pendo from somewhere (would the TPE 350's be an option as spare stock, just like HT using TPE stock between Hull and Donny when they had the acute shortage)
sprinterguy
4 Mar 2010
Macclesfield
That’s a good point. At the very least, while First have Pendolinos out of service for refurbishment, reportedly in the first two and a half years of the franchise for the Voyagers at least, they’ll need something to step into the breach and fill the gap.
It seems that there will be even less slack in TPEs’ 350 fleet than there is in their fleet of 185s, so I think that that idea is a non-starter, particularly when you think of just how under-specified in terms of passenger capacity, catering provision and maximum speed a 350 would be if it was required to do the same work as the Pretendolino.
rail-britain
12 Aug 2007
http://www.firstgroup.com/assets/pd...Coast_franchise_award_presentation_150812.pdf
First InterCity West Coast will clearly be retaining the Mark 3 loco hauled set initially
This suggests it will be retained until 2016, when it will be displaced by the new rolling stock
Equally I would expect it to be involved in strengthening on the revised Preston / Blackpool timetable from 2013 which will most likely see it in daily weekday use
However, no mention of Class 57 locos which were included in the West Coast Trains Limited franchise up to 09 December 2012
David10
25 May 2012
Manchester
Given its ability to only operate at 110mph, if WB64 stays imagine it would be restricted to Birmingham services to minimise its time on the WCML. Once the H3 overhauls are completed this year there should be 1 or 2 extra Pendolinos available. The Blackpool service will probably be operated by diverting Lancaster terminators.
rail-britain
12 Aug 2007
Don't forget the increase in requirements on Glasgow services, with an hourly service from 2013, and an earlier Press Release advised this would be done by extending these services to Glasgow
This suggests the Blackpool service is achieved by extending the Preston services
150001
24 Jul 2011
Not liking the use of new seats! Please do not be those HST ones!
MCR247
7 Nov 2008
Neither do I, they are very nice. Not sure about in a 390 though
Yew
12 Mar 2011
I've never understood the hate for the FGW HST seats.
I havent used them on HST's, but on EMT's 158's they are just a bit too high, then the 'head wings' make it even worse. The versions used by ATW could be better though, same style of seat without the wings. Should give a good balance of priviacy and visibility.
They are very well built though, although maybe a little hard
tom1649
5 Jul 2010
If privacy is an issue they should go back to having side compartments. I'm an IC70 seat lover here and prefer them over the much harder and higher modern seats. It is my aim to travel on the last ever service train with IC70 seats, whenever and wherever that may be! I was very pleased that the EMT HST refurbishment a few years ago retained the original seating, especially as EMT are my local operator.
Yew
12 Mar 2011
Priviacy might not be the right word, and if anything compartments could be worse for it if travelling alone. Look on a packed EMT HST, you can see everyone else in the carriage when youre in standard. Whereas on a 156 with slightly higher backed seats, you can still see everyone easily, but also its easier to shut everyone out. I think a IC70 with 6-12 inches of extra height (ie with a headrest) would be a good balance
DXMachina
24 Oct 2011
.... when you think of just how under-specified in terms of passenger capacity, catering provision and maximum speed a 350 would be if it was required to do the same work as the Pretendolino.
A new 350 has higher acceleration and the same top speed as the Pretendolino
sprinterguy
4 Mar 2010
Macclesfield
Will the TPE 350s be cleared for 110mph operation? I wasn't sure. And they still fall well short on train capacity and passenger amenities. I would absolutely hate to see a 350 standing in for the Pretendolino set on the 18:43 Euston - Crewe on a Friday, where you can expect to find around ninety people in each standard class carriage.
Pumbaa
19 Feb 2008
And as the 350 can hold MU differentials, arguably can hold top speed for longer too ;)
dubscottie
4 Apr 2010
Do you have the 0-60 times? Remember a class 90 could keep to class 91 timings on the London - Leeds route even although they could only do 110mph... A class 90 may be slower, but could out run a 91 or HST away from the platform.
Also, who is to say that the 110mph 350's wont be stuck on the slow lines for most of their journeys with lots of less than 110mph running?
Nym
2 Mar 2007
Somewhere, not in London
The 'slow' lines covered as part of the TV4 project are all 110/125EPS anyway for the most part, biggest single thing they kept telling me about the TV4 project at a recruitment presentation by NR.
dubscottie
4 Apr 2010
By the time you add freight, stopping trains etc.. They will still be hampered speed wise. And I can see NR being keen on 4-car EMU's running in between 125mph Pendo's on the fast lines!
I would be very surprised if a 90 hauling eight or so trailers could outperform a modern EMU...
DXMachina
24 Oct 2011
I've ridden behind 90s in mk3 sets before, when that wasnt something unusual on the WCML. They don't feel fast. Even the original 100mph 350 feels like it just wants to go, all the time... and the rate at which they reach linespeed compared to the 321s they replaced is breathtaking. And a 321 isn't a particularly slow set...
And yes as others stated the pretendolino is 110 tops and has a reputation on here for losing time even when its been catered for in the timetable.
monty9120
10 Jan 2012
ive been on a 350 on the fasts from northampton to euston. shame my sat nav didnt work
