Practising for online tests
PK96
28 Jun 2021
Hello everyone,
Just need some help. I'm sure plenty of people here will have the knowledge & experience that could help me understand this much better.
Anyone have any methods on how I could practice these tests and what are they?
- Group Bourdon
- TRP1 & TRP2
- Tea-Occ,
- DFFT
Thank you in advance!
NorthernTech
12 Apr 2021
Uk
When you are successful in an application the TOC will send you an assessment pack, the same as everyone from every application gets. In the pack in training and preparation information. Other than that, if you use the search function at the top of the page you will find all the help you need on the forum, as the questions you ask have been asked many many times before. Do some research on each section, make notes and practice the Group Bourdon dots test a lot.
Newapplicant
21 May 2018
Hello everyone,
- Group Bourdon
- TRP1 & TRP2
- Tea-Occ,
- DFFT
Good evening,
As @NorthernTech has rightly said, in terms of the tests and what to expect should you be successful at the interview stage, then your TOC will send you documentation that will reference the test and give you practice material to work with.
The only one you can currently practice at the moment is the group bourdon test which is available free via this forum found here: https://www.railforums.co.uk/threads/group-bourdon-tool.156417/
Failing that, look through the forum as there is a lot of helpful advice that will likely help you with the information you're looking for.
17 Aug 2022
