Post your Post Boxes! (Photos and fun facts)
High Dyke
1 Jan 2013
Yellabelly Country
A couple of recent finds, both EIIR.
  1. Type K, with festive topper. Wainfleet, Lincolnshire. (The building behind used to be the post office. It had a stamp machine set into the window).
  2. Newark, Nottinghamshire. Complete with 'out of use' stamp machine.
stadler
5 Jun 2023
Horsley
Is anyone aware of whether any of the fully combined post box and stamp machine still exist. It was a fully round (or more oval in this case as it was slightly longer) post box and the stamp machine was built in to it. One side of the box is a normal standard post box slot where you insert your letter and the other side of the box is a stamp machine where you used to be able to insert coins and it would dispense stamps. The last time i came across one was around 2019 and the post box slot was still in use but the stamp side was long out of use (probably for decades) and plated over. I presume that a few of these must still exist in places.
Sun Chariot
16 Mar 2009
Those late-20th century replica Penfold boxes are a fabulous touch by Royal Mail. I discovered the backstory by chance:
I wanted to photograph Haslemere's dark green Penfold box - its designer, John Wornham Penfold, was born there. Then I noticed the base plaque - and it surprised me to learn the box was of recent construction.
Royal Mail's decision to revive the design was driven by:
Heritage and Conservation​
By the 1980s, a growing movement toward "heritage" tourism and for the preservation of historic townscapes. The replicas allowed Royal Mail to match heritage architecture, whilst also providing a modern postal capacity.
Backlash Against Modern Designs​
In 1980, Royal Mail introduced the Type K "cigar-shape" pillar box design. However, it was widely disliked by the public who felt it lacked the character of traditional cast-iron boxes. The Penfold replicas were, in part, a strategic "pivot" backward.
Commemoration and Anniversaries​
Several replicas for specific historical links. Two examples:
- Haslemere's box, I mention above;
- Carlisle (in 1989) to commemorate the first mainland pillar box (originally installed in 1853).
Fun fact...
How to tell if a Penfold box is a replica, or an original:
The Aperture (Letter Slot): in many original Penfolds, the slot was high up (under the cap). On replicas, slot is placed lower down and is often wider.
The Foundry Mark: originals were cast by Cochrane, Grove & Co. Replica boxes typically cast by Machan Engineering.
The Paint and Surface: Replicas often have a much "cleaner" finish with fewer layers of thick, caked-on paint.
Post 3's Penfold (Gosport), is original (1872).
RPM
24 Sep 2009
Buckinghamshire
Fun fact...
Also worth noting the Machan Engineering maker's plates are not an integral part of the casting, so they often fall off. You can usually see a crusty patch at the base where it used to be though.
Sun Chariot
16 Mar 2009
I've seen several local Type A pillar boxes modified to accept Royal Mail's parcel drop-off facility & associated electronics. Post 101 shows an example.
A local Type B, attached, also seems about to receive similar treatment.
Mcr Warrior
8 Jan 2009
Seen similar in my neck of the woods. Royal Mail do seem to be taking a long time to replace/upgrade them. Slightly annoyingly, a few of these postboxes, in the course of being upgraded (and which are currently out of use), were ones with last collections at 5.30 p.m. on weekdays. Most others in the locality are 9.00 a.m.
High Dyke
1 Jan 2013
Yellabelly Country
Haven't managed to get a photo, but did spot one in Navenby, Lincolnshire the other day which was wearing a topper of a knitted solar panel, as if to mimic these new modifications.
25 Aug 2019
Lancaster
A PB58 fibreglass pillar box at Meadowhall shopping centre, Sheffield/Rotherham. There's a similar one at an ASDA store near Lancaster.
DelW
15 Jan 2015
Since I see that "toppers" have made it onto this thread, I thought I'd add the seasonal one that's round the corner from me.
I don't know who makes them, but they're changed regularly.
I've belatedly noticed that, after a period of nakedness, the same local box is now marking Valentine's Day.
WesternLancer
12 Apr 2019
I'm now seeing quite a lot of pillar boxes with their front's removed and wrapped in heavy black plastic as part of the adaptation to parcels drop off points or whatever they are calling it - so the roll out seems quite extensive - more so than I thought it would be.
Sun Chariot
16 Mar 2009
I thought similar. I'd read one source quoting 3500 boxes for conversion; yet - down here on the provincial south coast - I have seen a fair number of "plastic-wrapped" boxes and the completed boxes, more than I expect for a 3500 nationwide total. So, perhaps we'll see more than that.
Some local boxes have been out of action up to two months; I wonder if there is a supply / fit backlog?
WesternLancer
12 Apr 2019
interesting point. I wonder what will happen to all the parts that are getting removed. Scrap?
Sun Chariot
16 Mar 2009
The conversions I've seen, all used their existing hinged door (alll have been EIIR Type A and Type B examples here so far).
The parcel-drop fixture seems welded to the door (I presume a flame-cut bigger aperture in the door for that purpose).
Similarly, the solar panel's angled mount is, seemingly, fitted onto the box's in-situ cap.
pdeaves
14 Sep 2014
Gateway to the South West
I get the impression that the removed doors/tops are taken away, converted and refitted to a compatible box elsewhere. So the only 'scrap' would be part of the door cut away. But that's just how I see it, no inside knowledge!
WesternLancer
12 Apr 2019
Thanks - helpful to understand it - I've not seen the finished result as yet - apart from when pictured here.
Thanks
Bevan Price
22 Apr 2010
Disused post boxes, former main post office buiding, Liverpool.
And their effective replacement, "twins" outside St. Johns Shopping Centre.
Bevan Price
22 Apr 2010
Taken in 2017 in Ramsbottom town centre. Don't know if is still there:
Sun Chariot
16 Mar 2009
Here's one in Chichester's gloom today. Its solar panel cap is fitted the opposite way round to the example in post 101.
I'll try the one in Emsworth on a better day.
