Possible plans for Edinburgh Waverley station?
29 Nov 2018
Joke, right?
Yes, only joking - apologies if you thought it was a serious concern.
I certainly wouldn't want to belittle the efforts involved in opening up the new platforms and introducing the ticket gates, which I know takes a huge amount of coordination and forward thinking. The same goes for introduction of new trains on GWR and LNER routes. It really is awful if there have been incidents of people climbing up on cables between carriages and I fully understand how difficult it can be to plan for every conceivable issue.
If there's a 500 tonne train where it shouldn't be I doubt that a 50g bolt is going to be a major concern!
If the friction buffers do what they are intended to do, stopping the 500 tonne train safely, then it's possible they could put tension in the fence which causes the end of the frangible bolt to ping off like a bullet. Not very likely I grant you, but possible.
InOban
12 Mar 2017
This seems like a clear case of an error on measurement or manufacture. The short section simply needs to abut the section behind the stops, doesn't need to be attached.
AngusH
27 Oct 2012
The flowers are a nice addition, I haven't seen them before at Edinburgh.
Well done to whoever is organising them.
InOban
12 Mar 2017
As I suggested, although there is no longer a gap, the sections aren't joined, so in the case of a buffer stop incident, there would be no damage to the new fence.
och aye
21 Jan 2012
Vital track upgrades for Calton Tunnel
https://www.networkrailmediacentre.co.uk/news/vital-track-upgrades-for-calton-tunnel-1
Engineers will be renewing the track through a key Edinburgh rail tunnel next month in a £1m investment in Scotland’s railway.
The Calton south tunnel, to the east of Edinburgh’s Waverley station, will be closed on Saturday, September 14, and Sunday, September 15, before reopening for customers at the start of service on Monday, September 16.
Engineers will be working around-the-clock to replace life-expired rails, sleepers and ballast in the tunnel, which connects Waverley to the East Coast Mainline (ECML).
In addition to the Calton tunnel works, Network Rail will also be renewing track, signalling and drainage at several locations on the ECML between Drem and Dunbar over the same weekend.
These engineering works cannot be delivered without some short-term disruption to journeys through Edinburgh Waverley, including to some services to the west of the city.
Passengers are being urged to check National Rail Enquiries, or with their individual train operator, to see how their plans may be affected.
Liam Sumpter, Network Rail Scotland Route Director, said: “Our engineers will be working hard throughout the weekend to complete these vital upgrades – which will help to deliver a more reliable service for passengers on the East Coast Mainline.
“We understand the inconvenience this work will cause to some customers, but such a significant investment cannot be delivered without temporary disruption to services and every effort has been made to reduce the impact of our activities as much as possible.”
InOban
12 Mar 2017
So the only access will be through the North tunnel? Fortunately the new platforms 5&6 only have access that way. I wonder if the relayed tracks will include additional points to give more flexible routing.
But there will no access from the East to 8&9 (the Sub)
221129
21 Mar 2011
Sunny Scotland
Doesn't matter as there will be no trains heading south!
4 Sep 2016
Am I correct in thinking that both of the Calton tunnels are single track?
I saw a post earlier in this thread hinting that one tunnel might be double tracked (CP6?), could both tunnels handle double tracking? Presumably there'd be a benefit in doing it (resilience, etc).
Presumably these upcoming works are purely signal and track replacement and not double tracking?
Altnabreac
20 Apr 2013
Salt & Vinegar
As I understand it Calton South tunnel is pretty much impossible to double track at current gauge, you’d have to open it right out which then creates World Heritage view issues so is challenging to get permissions for.
Calton North is easier and can be done by track lowering / small amount of reprofiling but I get the impression it’s more like an 8 week closure job than a weekend job.
route:oxford
1 Nov 2008
Surely as long as the outcome is that portals look essentially the same it shouldn't make much difference to the WHS?
There's a big block of white rendered council flats to hide most of any changes to the South tunnel anyway:-
Scotrail84
5 Jul 2010
Both tunnels used to be double track. Redoubling is a big job but really not that difficult. Inside the South tunnel about halfway down they've put like a plastic cladding which the overhead masts are attached to. Just remove that then realign the track and remodel station throat. North tunnel much easier to double.
Altnabreac
20 Apr 2013
Salt & Vinegar
Just what I was told by someone from NR that the south tunnel is a real challenge to double while maintaining gauge clearance without enlarging the bore.
And enlarging the bore in the south tunnel is problematic as it potentially destabilises the whole side of the hill.
marks87
23 Jun 2010
Dundee
What impact would there be on the existing timetable with Calton North out of action?
If it were to come onto the agenda, could the Sub be used to mitigate, especially if most/all LNER services will be bi-modes in the not too distance future?
There's precedent. As you likely know, the Sub was used when the Haymarket tunnels were out of action for electrification works.
route:oxford
1 Nov 2008
That precedent was set back in the olden days though. There were considerably fewer services going through the Haymarket tunnels in the late 1980/early 1990s.
To avoid wasting paths...
Should the Inverness & Aberdeen services be routed round the sub without calling at Haymarket or Edinburgh? Instead calling at Edinburgh Park & Edinburgh Gateway for connecting services?
221129
21 Mar 2011
Sunny Scotland
Nothing south out of Edinburgh for these upcoming works.
221129
21 Mar 2011
Sunny Scotland
Afaik there is no access to the Up Main off the sub without a reversal.
takno
Verified Rep - Traksy
It would be entertaining to see everything stagger through Millerhill to avoid the reversal. I think there's still just about a through route
221129
21 Mar 2011
Sunny Scotland
Thanks both. Now that I'm out of bed and less lazy I've had a look and on RTT they're all timed as HSTs. Yes, I know timing load doesn't actually mean anything but does this mean no drags? Or do Azumas (Azumii?) on diesel get timed as HSTs?
Still in the old timings.
221129
21 Mar 2011
Sunny Scotland
You mean the ones going via Carlisle?
I'll have to check that out in the timetable. Be great to take the Chieftain to Carlisle and over the hills to Newcastle.
I've done it a couple of times heading down to London from the Dundee. It's definitely a pleasant journey.
d9009alycidon
22 Jun 2011
Eaglesham
There is but unfortunately the points at the southern end of the yard are manual lever operated, so cannot be used for passenger traffice without being clamped
