Blindtraveler
- Joined
- 28 Feb 2011
- Messages
- 10,544
Where would you put this additional lift then?
Genuinely interested
The wate time for the current lift is very long at peek times and its small. A taxi arrangement down below would simply not work without additional lifts or a travelater. Speeking of travelaters one would have to be provided to Waverley bridge should that be used, which will never happen anyway as the tour and airport buses would struggle to opperate from anywhere else. The only reason things are such a pickle is due to the council doing what they do best, i.e nothing.
I agree that the present rank is a shambles and an embarrassment to the city, but the main reason for removing nearly all vehicles from the inside of Waverley was security rather than pollution.The TAXI policy is a disaster! The number of times I've had to wait outside in the ****ing rain on one thanks to this stupid policy, considering half the trains that use the station are diesel I don't see how it actually improves anything not to mention the rank was away from any shopping areas etc.
I don't know if this makes it any better or not, but also bear in mind that the location of the old cab rank will be swallowed by the extensions to platforms 5 and 6 to accomodate full length trains.
I was under the impression it was due to clean air nonsense, seems I was misinformed
Will the new/former Motorail platforms be used for Provincial or Intercity trains?
Anyway Market Street should have a shelter erected for the Taxi rank. I noticed NR are going to reorientation the escalators at Platform 12, good idea however weren't these only installed a few years back? Was there a Victorian staircase in that area previously?
Re the escalators at P11 there weren't any stairs there before that I can remember, the only stairs at that side are the ones that used to be behind and above what used to be Dixies/Quiksnack/Sockshop/Lastminute or whatever else has been in there over the last twenty odd years.
I noticed NR are going to reorientate the escalators at Platform 12, good idea however weren't these only installed a few years back?
I'm pretty sure there were stairs from the eastern side up to the, um, walkway up above. (As opposed to the western side for the escalators.)
Either a covered walkway or a bus shelter would be a good idea although I still think shutting the bus stops at the top of Waverley Steps and having two taxi ranks there (one either side of the road) would be better than Market Street but I'd imagine shutting those stops would cause a riot.
However the buses on Waverley Bridge are the Airlink and the city tour buses. As I remember, no service routes operate through there. But I can't think of anywhere else they could go.
Possibly, the only two sets of steps up to the walkway from when I started in Waverley back in 1996 were the ones where the escalators leading up towards Waverley Steps are and the ones at the opposite end of the ticket hall building that I mentioned earlier. You had to go round the side of the of the building to go up them and when you got to the top you were looking up the south ramp.
IIRC the old refund Office was at the foot of the stairs. Those are the only two sets I can remember from when I worked there - I think
Buses before taxis, every time. Actual public transport should take priority over private transport
(the "make 5/6/12/23 through platforms" plan would of course require the removal of the southern ramp, leaving the north ramp as the service and emergency access)
I'm still surprised that when 10 was built, it was just one platform- I'd have thought a full length double platform, giving the same arrangement as 1/2/19/20, would have been more flexible?
That's the one I was thinking of!
Does any one else think the stairs to Market Street should have escalators?
The north ramp has an uncertain future as well. Just as P5/6/12/13 will be knocked through to make two new through platforms, so will P18 be extended through the area currently occupied by Caffe Nero and Europcar to make yet another ultra long through platform.
The combination of Princes St. and Waverley would certainly have made a difference to the capacity limitations at the west end of Haymarket. It might have seen a scenario where the links to the Caledonian/NBR day were broken with West Coast trains going into Waverley instead of Princes St. for through connections and then terminating some services at Princes St. that traditionally were Waverley terminators.Maybe NR should rebuild Princess St for capacity expansion. Another example of poor foresight from the 60s.
