So, I'm considering upgrading from my current 5.0 megapixel camera, to a nice branded 12.0 megapixel jobbie, but the question is, will there be obviously better quality (less motion blur, clearer images) pictures from the higher pixel camera?
Cheers, Tim.
It would help if we knew the model that you have and are thinking of upgrading to.
An increase of 7 megapixels will likely bring a noticeable iprovement in resolution, but not necessarily
quality.
What does bring an improvemnt in quality is the size of the sensor, for example a camera phone such as an Iphone will have a sensor that is miniscule, probably around the size of your little finger nail, therefore the photosites (which make up the pixels) have to be smaller and more tightly packed.
Every time you move up a level in terms of intended market for a camera the sensor
usually gets bigger, up until medium format which is the largest (for digital) now these things have huge sensors, usually around 4x5inches.
Each time you increase the size of the sensor the pixel density is reduced, which means things like less digital noise etc. Thats why most D-SLR's are around 12-16mp.
one thing that higher megapixels won't cure is motion blur. That is due to the camera (or user) selecting a shutter speed that is too low to freeze any motion in the scene.
Incidentally newer more modern cameras can shoot at higher ISO speeds (basically you can adjust how sensitive to light the sensor is. This however comes with added digital noise, or grain) without noise being a problem, so you could say that buying your new camera would help to cure a motion blur problem, however again, it depends on the size of the sensor being used.
Sorry If I've gone a bit too technical.
