Porto metro system
MarcVD
23 Aug 2016
We, wife and I, are in Porto for a few days. Mostly walking but using the metro once or twice a day. Wife will also use the metro for her return to the airport (I won't because I'll return to Brussels by train). The metro uses a zonal fare system, you pre-load the tickets you need on a smartcard and validate them as you go. We normally need two-zones tickets but she will need a four-zones one to go to the airport.
And hence the question : when you have different ticket types loaded on your smartcard, how do you tell, at validation time, which ticket type should be validated ?
Lxd2
18 Jan 2012
From my limited experience of the system, I think you may need to buy two Andante cards - one loaded with the two-zones tickets, the other loaded with the four-zones tickets. But if anyone knows how it can be done on one card, please let me know as it would be useful.
Belperpete
17 Aug 2018
If its anything like the system used in Lisbon, while you can load further tickets of the same type, you can't load a different type of ticket onto a card until the existing tickets have expired. I ended up with about 3 cards.
Iskra
11 Jun 2014
West Riding
You can simplify things by just using contactless payment on the blue tap-in readers. This is simpler and inexpensive.
MarcVD
23 Aug 2016
I have indeed been caught. It does not let you chose. And picks the most expensive ticket available on the card first. So, will have to purchase that 4 zones ticket again, just before I need it. Porto métro is not expensive, so the loss is minimal, but it is a pity that this is not explained clearly anywhere. Otherwise I like that métro system. The frequencies on Sundays are a bit low, though.
Also, while I'm at it :
Two new métro lines are under construction. Lots of disturbances around Sao Bento station. As a result, tram tracks are interrupted and line 22 does not run. The other two, 1 and 18, are not affected.
Porto Campanha has 6 new stub tracks that do not seem to have much usage right now. I suspect they want to concentrate all services there and stop serving Sao Bento, which also has 6 tracks.
Our train to Pinhoa was diesel hauled, of course, (a 1400) but came from Campanha hauled by an electric. Never saw that livery before, is it new ?
