Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
david l
27 Dec 2016
Wigan
Yep, it got to the point around half 10 this morning that there was only one working unit left, and Network Rail have stated that when it's down to one it has to be pulled from service.
Presume 769421/52 (ie the cavalry from TfW) are still not yet ready, and 769431 at Brodies is still having its holes filled at Brodies. It's about time that Northern pulled the plug on this lot...........are Porterbrook now actually paying Northern to use these units as opposed to the other way round?
GhostManDN91
2 Oct 2022
Wigan
Ironically I did see 1 769 at Wigan Wallgate this evening but I'm guessing it was going ECS somewhere by the looks of it. Not good in the evening rush hour though 2 carriages to Southport from Manchester.
Geeves
6 Jan 2009
Rochdale
Had a check still none out it seems!
424 - Allerton
431 - Kilmarnock
434 - Allerton
442 - Springs Branch
448 - Springs Branch
450 - Allerton
456 - Allerton
458 - Allerton
Just two lots of 4 cars out on the Southport work off Southport 156 X 2 on the 1705 and 150+156 on the 1832
T74
12 Aug 2019
It would of been cheaper for the leasing company to refurb the ex 156s stored at Ely put wsp on them and run them as pairs more reliable than the 769s and could have interworked with other units .
They may have been rust buckets but look at some of the ex anglia ones that was taken to bare metal and rebuilt .
23 Nov 2015
There are five off-lease 156s so not enough to replace the 769s. Second four of those 156s - the ones at Ely - are owned by a different ROSCO (Angel) than the 319/769 fleet (Porterbrook), so Porterbrook wouldn't be touching those four.
Soft Hands
27 Dec 2020
Bolton
424 - Allerton
431 - Kilmarnock
434 - Allerton
450 - Allerton
456 - Allerton
458 - Allerton
There are eight daily diagrams on the Southport / Oxford Road / Stalybridge services. In theory six are booked for 769's and two are booked 150/156 combos. All services are booked for four cars! The layovers are quite substantial, 45 minutes at Stalybridge and almost an hour in some cases at Southport. Generally, out of the peak, the sets do a return to Oxford Road, then a return to Stalybridge, then back to Oxford Road again.
D365
29 Jun 2012
The 156s at Ely are knackered and are very unlikely to ever again see passenger use.
FrontSideBus
11 Feb 2025
With the reliability of these 769's, at this stage they'd be better off with 4 mk3's and a 37!
Surely the lease agreement has to have some sort of availability clause in it?
WAO
10 Mar 2019
Or a "Castle" class/half 125 shuttle to and from Southport, specifically to cover the peaks.
Yes it would cost more but there's value in a higher quality service offering - so much for Northern Powerhouse!
The LYR could justify club trains for this route, like Blackpool, which at least has electrification.
Or just hold some feet to the fire until the 769's are fixed.
WAO
fgwrich
15 Apr 2009
Hampshire
It’s also unlikely they’d end up with Northern in this scenario either - they are Angel Trains owned units, while the 769 is Porterbrook’s disaster.
However, if Porterbrook has any of the Welsh 150s, I wonder if they may be weighing up and reconsidering the idea of not putting them through any more overhauls and writing them off, for a short term extended life with Northern?
david l
27 Dec 2016
Wigan
37884 + 769434 on 5Q08 Allerton-Kilmarnock approaching Preston at 13.17.
3 769's started service today, no wonder can't have 6 in service as diagrammed as only 6 in the area. What's happened to 769421/52??
Update 8 April 37884 + 769431 on 5Q37 Kilmarnock-Allerton, currently at Edge Hill.
As yesterday, 3 769's started service today, several short forms using DMU's again.
childwallblues
3 Jul 2014
Liverpool, UK
769431 arrived back at Allerton Depot this afternoon hauled by 37884 passing through Liverpool South Parkway at 1613. I am unsure what work has been done on the unit but she has had a full repaint externally and looks very smart.
507016
25 Feb 2024
What works are involved in a C6 exam? I know 434 went recently and it’s A motor sounds fantastic, hoping it doesn’t get a gear swap any time soon
Bob Price
8 Aug 2019
For info 37884 has just towed 769452 from Crewe IED to the South Yard. The unit has had its pantograph refitted and is debranded.
diligentdave
20 Oct 2007
This Class 769 C6 exam generally involves a lot of interior overhauls. Repairs to seats, tables etc. The doorgear for the passenger doors has been upgraded to an IFE system, it's much quieter than the original Westinghouse system. Supposed to be more reliable as well. These 769's have also had a lot of corrosion work carried out on them (hence the 10 week works) so are now future proofed.
Some of the units will be having C4 overhauls at the same time (434 is one of these) so new bogies and underframe stuff as well.
Geeves
6 Jan 2009
Rochdale
431 on what I believe is it's debut after it's return from Scotland... Currently recieving fitters' attention at Victoria on 2W01. 2W02 442 is now also a requiring fitters but now also thankfully departed.
431 has been declared a failure. Heading back to the shed Edit 2. Did not have enough working engines to get to the shed, now going back to Allerton as 5Z85
TT-ONR-NRN
30 Dec 2016
Cambridge
Why is this, because they need to have another to rescue in case another one pops too?
sportzbar
11 May 2014
Yes exactly this. The only other Northern units that have the same tight lock couplers are 323s. So there needs to be a minimum of two 769 units in service (could be more), so if one fails either under the wires or on a non-electrified line, there is another 769 somewhere between Manchester/Stalybridge and Southport to rescue it....
sportzbar
11 May 2014
That is weird, do you know if that is related to the conversion or would a 319 have the same one direction compatibility?
Weight restriction as to what a 323 can rescue means a 769 is definitely too heavy, not sure about the 319 though....
