Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
507020
23 May 2021
Southport
Couple of things regards to the 769s come the December timetable
769s will no longer go beyond Oxford Rd on planned work
Manchester Piccadilly depot will no longer sign 769s
Two 769s per night will finish at Allerton on the new diagrams, the other diagrams will end at Springs Branch or Newton Heath with no overnight stabling at Vic, Wigan or Southport.
What I noticed is that only 3 trips to Stalybridge on Southport diagrams (some early and late services are provided by other diagrams) will by booked Sprinters, there will be 4 booked Sprinters a day from Southport to Oxford Road.
I can guarantee that regardless there will almost certainly continue to be outstabling at Wigan and Southport, particularly on Sundays.
No - the ban was in place because the cause of the incident was not known. Porterbrook had to bring in specialist engineers to determine that it was a VCB failure and thus not a fault specific to a 769. At which point the electric mode ban was rescinded.
So it is a known fact now. It’s not reasonable to expect to know the exact cause, but Network Rail made the (incorrect) decision to ban 769s from electric mode based on prejudice against their conversion.
Why was it assumed (incorrectly) that it must be a failure specific to 769s until this was proved not to be the case?
gmaguire
29 Dec 2021
I think it was a precaution more than anything else. If I remember correctly the failed unit was interfering with signals?
507020
23 May 2021
Southport
For a niche fleet like that with limited traction knowledge I would imagine very rarely if at all.
Never. They are locked in to work Southport services. At Man Vic, only 2 out of 4 drivers links sign them for instance.
Obviously they won’t work anywhere other than Southport, but if one fails and is either replaced by a Sprinter or the service is cancelled, it remains highly likely that 769s will be found stabled at Southport, Wigan and Victoria.
wrinkley
6 Feb 2015
On a journey from Wigan to Stalybridge yesterday we saw three 769 sets on the Southport - Stalybridge service, also when dog walking by the railway near Lostock I almost always see 769 on the services that I expect them to be on. Are they now more reliable or am I being too optimistic?
AM9
13 May 2014
St Albans
Hi Wrinkley, I hope you are riding on them whilst you can. It seems de rigueur to complain about them but they certainly are much nicer than tatty 150s being thrashed and the ride that we had 18 months ago between Southport and Wigan was speedy and comfortable.
jfollows
26 Feb 2011
Wilmslow
Six active diagrams for the eight units, so they do seem to have improved a little.
EDIT Diagrams at https://www.railforums.co.uk/threads/december-2022-timetable-changes.231835/page-61#post-5938036
JBuchananGB
30 Jan 2017
Southport
Also seemingly on the Southport to Oxford Road services. I travelled yesterday afternoon on 769458 Manchester to Southport, delayed by a door fault at Parbold. This in turn delayed 769448 the service from Oxford Road. In the morning it was 769458 which took me from Southport to Manchester.
Geeves
6 Jan 2009
Rochdale
All of the 769s will be making their way to Allerton over the next day or two, none will be in service for a week or so. I wonder if they will actually come back out
Peter Sarf
Croydon
Hmm. Could they be joining their GWR and TfL siblings at a scrappy.
scrapy
15 Dec 2008
That's only because of the Hindley engineering works, and them not being permitted to run via Chat Moss. They are expected to be back in service on 15th May.
david l
27 Dec 2016
Wigan
Why can't they run via Chat Moss, as 319's go that way each day from Manchester to Wigan?
scrapy
15 Dec 2008
They've only been cleared on the routes they have booked work or empty stock moves over. Reliability issues and there not being enough of them about to perform a rescue. Network Rail want to keep them off the WCML as much as possible. They would only be able to run in diesel mode that way anyway so the fuel tanks probably wouldn't last a day.
david l
27 Dec 2016
Wigan
Maybe pathing issues?
No, because the booked trains are still running from Southport-Ox Road which will presumably be diesel (and probably short formed....) - perhaps its in the 'too hard' category to stop the 769's at Wigan S Junc to change from diesel to electric and vice versa! despite them running that way from SP to WNW or WW!
Dspatula
19 Dec 2019
Manchester
Greybeard33
18 Feb 2012
Greater Manchester
Can a 319 rescue a 769 if it sits down under the wires?
Geeves
6 Jan 2009
Rochdale
A 319 has took some dead 769s back to Allerton in the past and Northern tested 323 to 319 emergency coupling but as you say it would be purely mechanical, out of ideas and options stuff. It would be difficult now as various depots don't all sign the same traction either.
scrapy
15 Dec 2008
err no they're permitted via Chat Moss, https://www.realtimetrains.co.uk/service/gb-nr:C01817/2023-05-04/detailed#allox_id=1
but you are probably right as to reason the won't be running.
Last time it was shut it was mainly double 158 sets on the Oxford Road Southport run.
Should have been clearer, it's the WCML south of Springs Branch that they can't be used on (which obviously stops them being used over Chat Moss from Wigan). They are cleared but Network Rail want to keep them off the WCML as much as possible so they can only go that way with special permission. (Likely to be given for an overnight empty stock move if Prescot route closed, but unlikely for an hourly daytime service when there is alternative traction that can be used).
Give that faults most likely occur when changing between electric and diesel, stopping at Wigan S Junction to do this is probably out of the question as it would be a bad place to fail if things go wrong. Even a unit reset can take 5-10 minutes and that's without the time spent waiting on the phone to get hold of a maintenance controller.
