Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
AM9
13 May 2014
St Albans
A couple of points to note. 769s actually respond initially quicker, when the driver moves the traction power controller from off to a power notch when starting away from a stand quicker in diesel mode than in electric mode or than a 319 does. Engine revs rise with each notch taken however there is often no discernable rise in engine revs between power notches 3 and 4. As I understand it there is no field weakening in power notch 4 on a 319 when the traction power is supplied in 'DC mode', which is effectively what a 769 on diesel mode is.
I think that I remember that, Once the up train reached about 50mph on the straight beyond Meols Cop, the engine speed was moderate although the speed steadily built up to 73mph. I suppose the generator excitation is adjusted to apply a steady load at the optimum engine rotational speed which is not necessarily maximum HP. The whole ride experience on the 769s is far less hectic than the thrashing of the 150's engines, - even though the cars are very similar.
One other thing that's odd is that the engine revs only really die down to idle when the unit actually comes to a stand. The driver will have shut off traction power long before this (and in any event braking in brake step 2 or more -normal braking on a 319/769- would disable any traction power still applied) but even when coasting with no traction power applied the engines still rev quite high until the train virtually comes to a stand.
Would that be because the compressors are recovering after use?
Gricer99
21 Jun 2020
Hindley
No 769s out again today. Most trains now overcrowded two car 150 or 156s.
Have the 769s been quietly withdrawn?
AM9
13 May 2014
St Albans
150s etc don't have to be 'thrashed' before the brakes are released. Once the torque converter is actually filled (2-3 seconds) so long as sufficient traction power is applied to overcome any rising gradient, and even on the steepest gradients I drive of 1-in-40-odd, then the unit won't roll back even in just notch 3 power. Lesser rising gradients wouldn't need that much traction power.
Maybe the engines are just so much noisier than I'm used to nowadays.
Bikeman78
26 Apr 2018
Many of us will remember how the compressor slowed down and sometimes the lights dimmed on the old Southern Region slam door units when they started away from a station. Traction packages have to be designed to tolerate these fluctuations.
Even another train entering the same section had a slight effect. I recall waiting for trains coming up the Arun Valley at Horsham. There would usually be an EPB or a VEP humming away on platform 1. When the train coming from Christ's Hospital moved on to the Horsham substation area the note of the motor generator changed so I knew the train was just over a minute away.
D9006
28 Aug 2019
Wigan
Yes 2nd day on trot now, everything on Man to Southport is 2 car unit , plus cancelled services this morning, glad do not commute to Manchester it’s a lottery if going get on train or not
Gricer99
21 Jun 2020
Hindley
With the overcrowded 150s, very few windows open and unmasked people coughing and spluttering it's rapidly becoming the Covid Express route.
That sounds like the sort of place that might be a long way from a substation, so even a small extra demand some distance away will cause the voltage to drop noticeably.
Do the 769s have an audible compressor, and if so does anyone have observations on how the note changes with demanded power in diesel mode?
Llama
29 Apr 2014
No, that's what I thought it might be at first but it's definitely speed related rather than any auxiliary load, the compressor doesn't really affect engine revs even though it draws quite a lot of current when it runs.
Yes the main compressor is audible on a 769, it's the same as on a 319 and runs directly off the 750v DV busline and is protected by a 60 amp fuse. Tends to run at a fairly high rate when it starts up, located on the ATS car.
Gricer99
21 Jun 2020
Hindley
They terminated the ALD to SOP at Wigan Wallgate tonight despite the fact it was running on time. A fellow passenger was bound for SOP but the guard said he knew nothing of any onward connection as he was only told of the termination at Bolton!
Meanwhile, according to RTT an 8 car 769 ran empty from Allerton via Wallgate to SOP
D9006
28 Aug 2019
Wigan
The 2218 Southport to Man vic is booked a 769, none out all day until the end of service, what is that all about
507020
23 May 2021
Southport
Why would they terminate at Wigan when it was a Sprinter? They usually only do this with 769s that have run on half power from Bolton.
Bikeman78
26 Apr 2018
It's under the middle car that doesn't have the traction motors and is quite loud. I'll have a listen next time I go on one.
507020
23 May 2021
Southport
On 2nd thought, due to the sub-optimal signalling arrangement since the closure of New Lane and Bescar Lane signal boxes, there won’t have been a spare path for the ECS movement without cancelling the service train, which isn’t exactly ideal!
Gricer99
21 Jun 2020
Hindley
Or very fair to the fare paying end of rush hour customers that were inconvenienced and had their evenings ruined.
Meanwhile, it’s just arrived at Hindley 20 minutes late, which doesn’t auger well for tomorrow!
507020
23 May 2021
Southport
I just passed through Southport station to see 769448 in Platform 5 with a 156 either side and was told by staff that it arrived as an 8 car, but the rear set failed on arrival and was detached and taken away again. Then I noticed that while the unit on Platform 4 was running and ready to leave but there was a green signal on platform 6…
nightflyian
12 Oct 2021
Southport
448 still sat there this morning on 5. 431 is the 2K82 service which turned up 7 mins late inbound. On board signage doesn't appear to be working either.
M60lad
31 May 2011
Surprise Surprise Northern sent out 769450 on 06:37 Manchester Victoria-Southport service and its now blocking the Atherton line after breaking down at Atherton Station.
Llama
29 Apr 2014
Eventually shifted from Atherton at 0950, unit 769431 pinched off 2K82 0716 Southport-Alderley at Salford Crescent to use as 1Z99.
nightflyian
12 Oct 2021
Southport
And with 431 0716 SOP-ALD borrowed at Salford Crescent for rescue duties thats another one out of service on top the one sat on Platform 5 at Southport. As much as love these commuting on these trains when they work I think someone at Northern or Network Rail needs to make the decision to suspend use of them pending issues being resolved making them reliable.
Geeves
6 Jan 2009
Rochdale
431 should be back out at some point, it was down to work 2W08 to Southport but that looks to have been caped 2K88 is the return at 1315 so see if it runs! Saying that if only one set is out I would imagine they would end up leaving it, unless they want to really ask for trouble!
Ribbleman
12 Jun 2019
Whilst I agree that the level of reliability of the 769s is very poor, in the continued absence of the additional 156 sets from East Midlands, there is nothing with which Northern can replace the 769s without extensive shortening of train formations.
LowLevel
26 Oct 2013
Some 156s will be transferring to Northern from EMR in December I believe though I don't think it will make much difference. 3 or 4 sets quoted.
175001
3 Feb 2007
Between Heaven and Hell
If only one set is out then its pulled ASAP.
Geeves
6 Jan 2009
Rochdale
Its out now but so far as I can tell they are relying on 448 which is currently parked in Southport!
Gricer99
21 Jun 2020
Hindley
What happened to the 135s being coupled to 2 car 158s on the Leeds- Wigan NW? Not seen a 153 for weeks.
If they returned on the Leeds route, this could free up some 258s for SOP-ALD
py_megapixel
5 Nov 2018
Northern England
158s are surely unsuitable for that route because it gets so busy in the peaks. The relatively large vestibules will extend boarding and alighting times.
craigybagel
25 Oct 2012
And in any case I don't think there are any drivers who sign through to Alderley Edge who also sign 158s.
