Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Greybeard33
18 Feb 2012
Greater Manchester
No, and as I've said upthread, I don't have any knowledge of their current reliability performance other than assuming an improvement from the lack of complaints here, as were prevalent when they were first introduced, - hence my comment about maintainers getting used to them.
However, in post #3354, you commented: "Am I right in thinking that the conversion package does not include any reliability improvement mods?", so addressing the impact of the conversion on critical components of the units traction system, i.e. the effect of the additional 7'ish tonnes of genset/fuel tanks added to the DTSOs, I surmised the relatively small additional load under ac conditions (likened to a full passenger load in 2 of the 4 cars) and the lower loading on the motors when under diesel power that was unable to provide more than about 60% of the motors' continuous ratings, (which is in effect a derating of the DC electric traction components when running under diesel). In reliability engineering terms those changes with a new modern diesel engine I contend would be somewhere between reliability neutral and slightly improved. The other issue briefly discussed upthread was that of adhesion, for which I posted figures showing the minimal reduction of percentage adhesive weight for empty, full and crush loading for class769 stock compared with class the original class319s.
Last year the poor reliability of the Northern 319s was somewhat masked, because the delay to Preston - Manchester electrification meant that the fleet was underutilised. Now, however, there are three additional 319 diagrams on the Bolton line and the cracks are showing. A survey of relevant threads on this forum will show plenty of complaints, e.g. last Saturday:
Ones I can think of:
  • One diagram today on Liverpool - Wigan stopper
  • One on Thursday on the peak Chat Moss stopper from Victoria at around 1900
  • Around 2-3 diagrams at the start of the week on Crewe - Lime Street stoppers
Lately, a lot of the 319s I've used have been sounding worse for wear mechanically. Failures are therefore unsurprising for a train not famed for stellar reliability in the first place.
There was previously more slack in the fleet with some of the /4s destined to become 769s available for use, but these have disappeared to the forgotten abyss at Loughborough
Edit: To add to the above, was checking JourneyCheck for my train later and happened to notice a Liverpool-Crewe diagram has been updated to show a DMU substitution for the rest of the day.
The issue can be seen by random checks of "Train Formation Updates" on the Northern JourneyCheck webpage. Where a service normally 319-operated is "formed of 2 coaches instead of 4", a DMU has been substituted. That DMU will have been robbed from another diagram, causing a bunch of (normally 4-car) DMU services to be short formed as well. Today, for example, 2-car DMUs were working two 319 diagrams on the Chat Moss stopper - Manchester Airport - Wilmslow/Crewe circuit, causing multiple short formed services throughout the day.
My query in #3354, about reliability improvement mods, was intended to suggest that, for the 769 to be a success, something needs to be done to address the poor reliability of the baseline 319 unit, over and above the changes that are a direct consequence of installing the diesel generators.
Chester1
25 Aug 2014
Its about keeping costs to the minimum. Northern's fleet is currently smaller than planned therefore its saving on leasing costs. They should lease extra 319s from Porterbrook who have dozens off lease. They have leased 3 extra until 769s enter service but that is still a saving of 5 units. Its more profitable to short form services though.
Greybeard33
18 Feb 2012
Greater Manchester
I believe Northern currently has 27*319s (26*/3s and 1*/4), which should be more than enough to cover the current booked diagrams after allowing for scheduled maintenance. That total includes 319372, 373 and 446, which are on short term loan due to the delays to the 769s.
When the 8*769s eventually enter service in place of the 3 loaned 319s, 5 will be needed on part electrified routes (Wigan NW - Alderley Edge and Stalybridge) that are currently worked by DMUs. So they will not increase the stock available to work the fully electrified routes.
The franchise agreement originally specified a 319 fleet of 32 units, assuming that Lostock - Wigan and Victoria - Stalybridge would be electrified, with 5 of those units going off lease in 2020, when all 331s were to be in service. The 24*319s + 8*769s will meet that requirement. It should not be necessary to lease additional units just to cover for chronic unreliability.
Chester1
25 Aug 2014
I know 769s won't run on all electric routes but my point was that Northern are pocketing a saving on the lease of 5 fewer units than expected. Extra 319s for a short period shouldn't make a difference but would because of the chronic unreliability. It shouldn't be acceptable for them to run DMUs on all electric routes due to poor reliability while the same Rosco that owns the 769s has loads of 319s in storage. It makes the delay in delivery of 195s and 769s even worse.
Cardiff123
10 Mar 2013
South Wales
This news story (behind a paywall) https://www.transportxtra.com/publi...o-give-date-for-flex-train-entry-into-service has a spokesperson from Porterbrook confirming that the 769s need modifications to their exhaust stacks due to gauging issues before they can enter service and start mainline testing. According to the article there's still no confirmed date when the 769s will enter service with Northern, TfW or GWR.
How many 319s are currently spare?
Am I right in thinking that the 769 project could easily end up consuming the entire fleet of 86 units?
At last, a reason for the delivered 769s staying idle.
js1000
14 Jun 2014
I don't think there's a business case for converting all 86 units when the 769 project is essentially a stop-gap to get around aborted electrification schemes in the North and the fact ROSCOs are unwilling to make a large order for new diesel units given they could be banned/require extensive hybrid conversion by 2040. I expect that most if not all the 769s will be gone by 2030 and replaced by purpose built bi-mode stock as part of the new Northern franchise, likewise GWR and TFW.
Cardiff123
10 Mar 2013
South Wales
The TfW 769s will be gone by 2022!
I very much doubt any electrodiesel units will be retired by 2040!
There is a lot of stock that would have to go before then, the 769s would have modern diesel engines and from an emissions perspective would be just as good as new units.
As they are unlikely to be as expensive as newbuild electrodiesels I would expect them to be used in preference to them.
Especially as they would be dual voltage electrodiesels, apparently, and are thus go-anywhere units.
anamyd
17 Aug 2018
ahh, so the "pipe sticking out" was exhaust pipes sticking out!
big all
23 Sep 2018
redhill
it seems like you need an account to veiw the other 82% off content including the bit about the exhaust pipes ??
adrock1976
10 Dec 2013
Apart from 319446 operating in its original form with Northern, are there any more of the 319/4 operating in their original form, or are they presently being converted to 769s?
I know that 434 and 456 are converted and sitting on Allerton, and 431 did run in its original form as I had that for haulage within the last couple of years.
Geeves
6 Jan 2009
Rochdale
I know this is the railway and nothing is ever simple but how hard is it to get up there and hacksaw off some exhaust pipe?
Mathew S
7 Aug 2017
Depends whether it's height or width? If it's sideways sticky-outness that's a problem, rather that upwards sticky-outness, then it's a lot more complicated.
The silencer may be bigger than on a 150 due to the bigger engine and/or having to meet more stringent noise limits.
JN114
28 Jun 2005
Has anyone said it’s difficult? Has anyone even said it hasn’t been done already?
When I reported the same a few weeks ago (and was told that I was wrong and not a trustworthy source but hey ho) I also said it was a simple 2-3 man hour fix; that only the 3 so-far delivered units need tweaking “in the field”, the rest will be done on production line before delivery. That hasn’t changed.
The mods need to be done before they come out to play on the mainline yes, but there’s a whole host of other things that the operator(s) need to sort out before they can play with them; which are entirely within the operators control.
a_c_skinner
21 Jun 2013
This is from Railway Magazine's www site. If it is out of gauge it isn't the top or the sides. IIRC the acceptable envelope narrows below the solebar so is that where the problem is? That would take a bit of re-design. Or is it the brakes? Or the staff/paths/inclination to get on with testing? Or is there a more fundamental problem?
hwl
5 Feb 2012
This photo shows that the bend at the bottom might be out of gauge:
https://www.railengineer.co.uk/2018/09/27/bi-mode-good-tri-mode-better/#gallery-5
JN114
28 Jun 2005
Below the solebar. The necessary modification required is known and is being done at the build stage for units not yet delivered. The modification required is very slight; well within the capabilities of Canton and Allerton to exchange the parts necessary.
A hold up, perhaps. But not the main bottleneck.
reddragon
24 Mar 2016
Churn (closed)
To me, it looks cost effective to replace class 15x series trains with converted Mk3 EMU's as adding a diesel engine to a 319 is easier long term than re-engineering class 150s AND the class 769 or class 321 conversions will still be able to run on OLE / 3rd rail and could later have diesel engines swapped for batteries which a class 150 cannot.
Cardiff123
10 Mar 2013
South Wales
What is the main bottleneck then?
