In my experience those "World" type dryers blew cold air approximately 75% of the time. The Dysons were much better.Original Airblades are terrible. You have to put your hands in a slot full of accumulated grime and hold them very steady else you touch it and negate the point of having washed them to start with. The only good dryers were the old heated "World" type ones with the big button you were meant to hit with your elbow.
Having the door close sound at all doors is doubtless much less complicated in software and also possibly hardware terms. It is also potentially a useful safety feature.I tend to find the passenger DOOR OPEN and DOOR CLOSE buttons are sometimes a bit confusing. I find they're usually stacked vertically but sometimes the OPEN is at the top and other times the CLOSE is at the top.
I also don't like it when the doors are released by the train crew and then both buttons light up. To me that's the system suggesting pressing the CLOSE button to close a door that's already closed? Similarly when you open the door but the OPEN button remains illuminated.
While I'm on the subject I don't like it when the door close alarm sounds on a door which is already closed. I think the 170s do it correctly, which is if the door is open then it goes through the whole shebang, if the door is already closed (wasn't used at that station or was closed manually by a passenger) then the door interior light turns off and the door locks immediately, without the alarm etc process.
I can't see any use as a safety feature. Quite the opposite in fact - it replaces a specific door beeping about something that it's about to do with an obscure train-wide alarm which could mean anything.Having the door close sound at all doors is doubtless much less complicated in software and also possibly hardware terms. It is also potentially a useful safety feature.
Specifically it replaces "this door is about to shut, so don't try to get on or off" with "THE TRAIN IS ABOUT TO LEAVE YOU BEHIND, RUUUN!".I can't see any use as a safety feature. Quite the opposite in fact - it replaces a specific door beeping about something that it's about to do with an obscure train-wide alarm which could mean anything.
Software and hardware shouldn't be s massive issue at all - the sensors and logic are already there, and it's easy enough to test, so you're basically taking about half a dozen lines of code
Does anyone have any examples of poor design on train control panels etc or other railway infrastructure? I'll start with the DLR B92 stock, the AUX OFF button (basically Train OFF), is directly above the HEAT ON button, separated by 5mm!
Have to disagree on this one, purely because the system on the Turbo's is frankly utter rubbish. There's the buttons to open the internal doors, but most of the time the sensors, doors and switches will just do their own thing - It's not uncommon to see the slightly amusing frightened door where it goes so close to closing, before opening itself again.Interior doors that need a touch or push button to open.
I agree, the doors on 222 Meridians often used to have issues with the floor switches, and they would just constantly, repeatedly open and close. Very annoying on a long journey.Have to disagree on this one, purely because the system on the Turbo's is frankly utter rubbish. There's the buttons to open the internal doors, but most of the time the sensors, doors and switches will just do their own thing - It's not uncommon to see the slightly amusing frightened door where it goes so close to closing, before opening itself again.
158/159 internal doors are also rather slow to open and close.
It's one of those can't-cover-everything situations - I love the pressure-switch mats when I'm moving through the train with my hands full, but dislike them quite a bit when, as you say, they're constantly being activated by standees in the vestibule.Buttons are better than them banging back and forth when standees are there, as per Mk2s and Mk3s.
The ones on the IETs seem to be quite good. I think they use infrared sensors like automatic doors in buildings do, but they seem to be angled well enough not to trigger constantly.It's one of those can't-cover-everything situations - I love the pressure-switch mats when I'm moving through the train with my hands full, but dislike them quite a bit when, as you say, they're constantly being activated by standees in the vestibule.
The problem with them is having to get incredibly close to them before the sensor triggers as it's positioned very close to the door on the ceiling.The ones on the IETs seem to be quite good. I think they use infrared sensors like automatic doors in buildings do, but they seem to be angled well enough not to trigger constantly.
Vestibule doors that are on a timer and close regardless of whether someone is in the doorway or not.
As a few have said, this is an awkward one. Whichever method is chosen it'll throw up issues at times. Some HST trailers had little toggle switches in the vestibules to lock the doors in the 'open' position, but there were probably rules preventing staff from using those when trains were full and standing. I did once hear of a group of anti-social passengers being shut into a carriage using those switches on a late-night St Pancras to Leeds service, but that could be apocryphal.Buttons are better than them banging back and forth when standees are there, as per Mk2s and Mk3s.
The class 315s manage it. Hardly cutting edge modern technology! I don't understand the safety concern. As soon as the driver or guard presses the door close button in the cab, all passenger door buttons are deactivated and the doors will not open. The Networkers as built, and probably all BREL units too, were more risky as pushing the open button during the hustle alarm sequence resulted in the doors opening part way before sliding shut again.Having the door close sound at all doors is doubtless much less complicated in software and also possibly hardware terms. It is also potentially a useful safety feature.
At London termini the auto closing doors often counter productive. They cause people to panic if they arrive three or four minutes before departure because they think the train is about to depart without them.Specifically it replaces "this door is about to shut, so don't try to get on or off" with "THE TRAIN IS ABOUT TO LEAVE YOU BEHIND, RUUUN!".
At least, that's how people treat it on 165/166s.
As often used to happen on the 156s when they were new in the late 1980s. They had a passcom located beneath the WC bowl in what was thought to be an ideal location for disabled people but it was often mistaken for the flush so passengers would pull it and the train would come shuddering to a halt.No it’s not!
If the ‘user’ doesn’t put the seat down quite often they assume the passcomm all call for aid button is the flush!
It's great fun trying to reopen them before they squash the poor person in the doorway thoughVestibule doors that are on a timer and close regardless of whether someone is in the doorway or not.
Though I'm far too young to have experienced them, the original door handles on class 313 units (as-built until 1977 according to Wikipedia) were apparently liable to being operated even when the doors were locked - can anyone confirm this?
The same can be said about the entrances to the main concourse toilets at some other stations such as Sheffield.The entrances to the main concourse toilets at Manchester Piccadilly are a severe choke point, not helped by the location of the hand driers.
You’ve just been spoilt for the last couple of years with those StadlersBoth toilets on 158s seem so outdated now.
You’ve just been spoilt for the last couple of years with those Stadlers![]()
The Voyagers and Pendolini have the door open and close buttons reversed.
If we're moaning about station toilets, the ones at London Bridge are awful for a no expense spared, completely rebuilt station.The same can be said about the entrances to the main concourse toilets at some other stations such as Sheffield.
Far too small and congested, with the urinals down one end, the sinks down the other (by the WCs) and the hand dryers located near the entrance.
