Pontefract Stns to Leeds
Adam0984
18 Feb 2014
Is a Pontefract Stns to Leeds ticket valid via Church Fenton using Pontefract Baghill to Church Fenton and Church Fenton to Leeds
Hmm, how come you ask? ;)
As it happens someone asked me that yesterday for a journey today. Yes it is valid*, and you can get itineraries for it.
(* Subject to your interpretation of the shortest route rule agreeing with the interpretation implemented by the booking engines!)
Ah, I've just realised which train you're working. I will send you a PM!
Starmill
18 May 2012
Bolton
If this ticket were used in this way by a passenger holding a valid itinerary, I have full confidence that it would be accepted in a polite and reasonable manner despite being perhaps somewhat uncommon. :D
Small world, eh? :D
Solent&Wessex
9 Jul 2009
This harks back to the debate had many times over, and quite significantly a few years ago (2011) where it depends on the actual stations noted on the ticket. For example if the ticket said from Pontefract Stations to Leeds then my interpretation - supported by the response from ATOC at the time - said that you were not free to choose which ever of the Pontefract Stations you liked to take a longer journey, but had to choose the relevant Pontefract Station to start from. The example given at the time - very similar to this example - was Bradford to New Pudsey (i.e. you decided to start at Forster Square and go via Shipley and Leeds and not start directly at Forster Square) was declared as invalid by ATOC. At the time Journey planners offered it as a valid journey, but negative easements were added as the journey planner software obviously wasn't interpreting things correctly! Other examples were Farnborough Stations to Blackwater - i.e. is it valid from Farnborough Main via Basingtoke and Reading? The answer again was no, you had to choose to travel from the relevant Farnborough station, in this case North.
So, in summary, my view is that a Pontefract to Leeds ticket is not intended and should not be valid via Church Fenton, but the journey planners are offering it in error. As a matter aside there are quite a few similar errors creeping again of late, especially in the North West where there are all sorts of dubious double backs and protracted journeys being offered as valid when they shouldn't - and in some cases haven't been offered previously.
The routeing guide maps behind NRES seem to lurch from one set of errors to another!
If you had a valid itinerary printed out, however, then I expect it to be honoured.
You're right; it's not intended to be valid but the way the systems have been programmed, it currently is valid.
Whether 'negative easements' have any contractual meaning is also debateable.
But the simple fact is that the piece of track between Micklefield & Church Fenton is vastly overpriced, and I know of many ways to reduce the cost which can't all be "fixed", because what's broken is the high cost of that piece of track!
There's not even a very expensive tunnel between the stations, so there's no excuse for it.
Indeed. Although not related to the original question, it's along the same theme. And yes you're right; The TOCs are obsessed with 'closing loopholes' but to do this, they end up invalidating valid/reasonable routes, while validating a load of unreasonable routes as a by-product!
It's also interesting how one TOC can demand a change, ATOC cave in, and then other TOCs find that their passengers are denied journey opportunities, because the correct processes aren't carried out.
