Pointless Shunt Signals/Ground Position Lights?
SussexSpotter
25 Oct 2009
Sussex
I sometimes see ground position lights/shunt signals in the most ridiculous places such as sidings that are no longer connected to the mainline or disused overgrown railway yards. Why do Network Rail waste money putting these signals in these places when they will never be used and will be permanently red?
If anyone doesn't know what a shunt signal/ground position light is here is a picture:
http://farm3.static.flickr.com/2121/2441956355_329122cfd2.jpg
Here are a 2 examples I have come across of some of the most ridiculous places for these shunt signals:
http://cw-railpic.fotopic.net/p57377959.html
http://noxid.digimig.co.uk/p51189158.html
Does anyone else have any pictures of shunt signals/ground position lights in the most ridiculous places?
royaloak
11 Oct 2009
today I will mostly be at home decorating
Basically, network rail haven't wasted anything by putting these signals on disused sidings, when the signals were put in the sidings were in use. By leaving them in when the sidings are mothballed why would they waste time, money and manpower removing something which isn't doing any harm and would have to be refitted if ever the siding was brought back into use.
Another point is if the signalling is altered, by the removal, it would effect the interlocking at the signal-box.
Old Timer
24 Aug 2009
I can give you the answer to that question.
The removal of any signal requires the production of a proper signalling design.
To do this requires that the existing signalling equipment on site and in th relay room is surveyed, a process known as "Correlation". The Correlation is against existing signalling drawings compared to the actual situation in the lineside location cases, relay rooms, cable routes, etc, etc.
The various re-organisations within BR and then subsequently Railtrack / Network Rail have resulted in the loss of considerable amounts of Infrastructure records, indeed in some cases, we do not have any accurate picture of what is under the track when we go to do Renewals in station areas, other than from local knowledge, which is now fast disappearing with NRS policy of removing old BR people.
A similar situation applies to signalling. This can be compounded by maintenance alterations which are often only recorded on site and never transferred into the principal records.
On site, many location cases were installed many years ago and can suffer from a degradation to the rubber insulation on the cables, this is known as either "Wet Wire Degradation" or "Dry Wire Degradation" depending on which type is involved.
Similar problems occur in signalling relay rooms, and Railtrack was certainly going forward with the renewal of such wiring.
This can mean that it is not sensible to disturb any cables in location cases because the risk is that the insulation is damaged which would then require a complete wire change, which in turn could lead to damage to other cables and so on.
Where no records exist, then a new record would need to be produced from scratch and would require considerable time and drawing office effort just to replicate the former records.
The next stage is the revised design.
Now obviously the ground position light signals will be wired into various signalling circuits, and their removal would require alterations to these signalling controls together with alterations to the Control Tables, which in turn brings with it a requirement for full Signalling Principles Testing.
Signalling design and testing resources are scarce, and as a result they are expensive.
You can see therefore that what on the face of it appears to be a very simple task (just cut a few wires and remove a signal) is actually a much more complex engineering task. Far better therefore to leave the signalling controls in situ rather than recover.
Now on the LNE Zone, we developed a process known as mimimal signal recoveries, which set out what was left and what was recovered. In most cases we recover junction indicators and calling on signals mounted on main posts, but leave ground position light signals. The wiring in the location cabinet for these signals is "turned round" , i.e. a strap is placed across the controls to effectively short circuit the bulb detection system, the outcome of which is to "fool" the relay room into thinking that the signal is permanently alight and displaying a red aspect. The power is taken from the signal, and in some cases the signal is recovered, but not always. Do you want to waste money on a recovery that may not be necessary is the question.
In some cases the wiring may not be in a good condition in the location case in which case the signal will be left alone, and this can result in the sorts of instances you have identified.
In a world where money was no problem, then we would correlate everything, bring the records up to date, do the redesign, recover and test the recoveries, implement the new controls, recover the redundant signalling equipment and controls and update to final the main records, with copies redistributed to each Maintenance area, and fresh copies of the drawings into the location cases.
It really IS down to how best to spend money, and I will always counsel for minimal recoveries as the most cost effective way forward, given all that I have explained above.
Finally in the case of new installations it is much cheaper to install equipment in advance rather than return and do a redesign. It may look foolish, but it is cheaper in the long term.
chappers
5 Mar 2008
One thing that I was always told regarding seemingly pointless Ground Signals - or redundant S&C units - is that to get them taken off the signalling panel costs something in the region of £100k, making it cheaper to leave them in situ and keep up routine maintenance. Problems come from the renewal side when they have to be disconnected, protected and tested as if they are the most important infrastrucutre in the world!
O L Leigh
20 Jan 2006
In the cab with the paper
The problem is that even if a siding appears to be disused, if it still has a connection to the mainline it is at least still theoretically "live". Therefore there is still a need to have a signal to control movements in and out. This is the case with the CIBA-Geigy sidings near Duxford which haven't been used for, I would estimate, at least 10 years.
O L Leigh
jopsuk
13 May 2008
It's not been Ciba-Geigy for longer than that!
That siding is completely unuseable as-is, there's mounds of spoil on the track and fixed pallisade fence at the site entrance.
