Platforms 21 and 22 currently in use at Waterloo
Bessie
30 Oct 2017
I assume the work to get the old Eurostar platforms in use for Windsor/Reading lines is continuing apace. Platforms 19 and 20 currently shut at Waterloo with ex Eurostar platforms 21 and 22 in use. Need an extra 2 mins to run to catch the train!
5 Jan 2014
Yes it can come as a nasty surprise if rushing to catch a Windsor train. I was on a service on Thursday evening that used platform 22
SEClass375
16 Aug 2016
I have caught a train from both platforms however they weren't SWR trains and it is a bit of a walk from the main part of the station.
5 Jan 2014
Yes I took a South Eastern service from platform 22 during the December diversion, but then I was expecting the train to be in that part of the station.
SEClass375
16 Aug 2016
During the December diversions platforms 21-24 were treated like a separate station (which I like to call Waterloo West) a bit like Waterloo East because they only display SE services there and they blocked access to platform 20 which would of been very inconvenient if I had to go to somewhere like Egham.
paok
3 May 2010
Not sure why Platform 19 has to be closed - can anyone shed any light?
I think I read somewhere that there will be alterations to the dividing wall to make P19 much more accessible from the enlarged P20-24 concourse so that it can be treated as a 6 platform group dedicated to the Windsor side services.
Goldfish62
14 Feb 2010
I've noticed that at weekends P21 and 22 are closed and P19 is reopened.
Goldfish62
14 Feb 2010
Makes sense. The approach to WIT is restrictive due to there only being two lines and the Down Windsor Slow line is not accessible from WIT so using P19 for Windsor lines services as well increases operational flexibility.
SWT_USER
29 Aug 2010
Ashford Middx
P19 currently has a 10 car 458 sat in it, although the platform still seems to be closed to the public. How long before 19 is fully open again?
On another note they need to sort out the departure boards in the 20-24 section. Currently the Shepperton via Kingston services on the mainline side are displayed along with the Windsor side services.
30907
That actually seems quite sensible, given that you can get to Kingston and Shepperton both ways round, and so long as the platform numbers appear .
