Platform alterations/allocations at Newport
Dai.
2 Aug 2008
Wales
Platform alterations are the most annoying things in the world, I have never been in Cardiff when they have done an alteration and it's terrible you had to go through that, I once got told at Newport, I say told over the loud speaker it said the CDF - NOT service was coming in on platform 4?
I make my way to platform 4, stand on the platform and the loudspeaker informs us all the CDF - NOT service is now coming in on platform 3 as it usually does..
Why?!
Dai.
2 Aug 2008
Wales
Thanks the black horse.
I have a ten minute connection time and I don't like having connections under 15 minutes for some reason :s
anthony263
19 Aug 2008
South Wales
However the 07:45 Cardiff - Nottingham service can also go from platforms 3 & 4
HSTfan!!!
11 Jun 2005
Theoretically, any of the platforms at Cardiff Central can be used for up bound services. I'm sure from memory though it tends to be 0 or 1 for Nottinghams, 0 being a bit harder to get to in a rush.
anthony263
19 Aug 2008
South Wales
yes but every time i have used the 07:45 cardiff - nottingham service it has gone off platform 4 especially if it arrives after it arrives into cardiff after 07:30
Dai.
2 Aug 2008
Wales
It was on platform 2 it arrived just after 7:30 into cardiff, went out and came back in :)
merlodlliw
8 Mar 2009
slight out of area. I usually catch the 1720 CDF/HYD, a couple of weeks ago
the displays were giving the departure platform as zero, I asked and got the answer, if it says zero its zero,strange as its usually one or two,climbed with others up to zero,hearing the
loudspeakers on this platform is difficult, at well passed 1715 a ATW dispatcher was shouting across from platform 1, the HYD is on platform 4, mad scramble down the hill ,alas the 3 car 175 was already packed with locals, ah well.
Dai.
2 Aug 2008
Wales
Why?!
merlodlliw
8 Mar 2009
Why?!
Although improved over the years, the bi ling robotics did in fact shout platform zero,how ever when a real person broke in to tell us on zero to go to four, the audio for this platform is too low and prone to noise. so no one heard it , that's why an ATW dispatcher started flapping his arms on platform one shouting go to four for the HYD.
Zero just about sums up this platform on the backwaters of ATWs key south station,
HSTfan!!!
11 Jun 2005
Why?!
lol i've had to do something like that before, felt like a right tit having to correct a mistake, in recent times we have a screen showing pretty much what the panel is doing with reference to routing and where trains are, but it's not always 100%
Quite often though it tends to be either a signaller cock ups / lack of communication / CIS system differing to signallers simplifier.
emoaconr
20 Apr 2009
Merseyside
Is that Holyhead (HHD)?
I frequently catch trains at Cardiff Central where the HHD service is advertised for platform 1, but actually turns up on platform 2, having changed on the information boards just minutes before turning up. In my experience there has been no announcement of this change of platform; I assume because both 1 and 2 are on the same island.
merlodlliw
8 Mar 2009
you are correct I should have said HHD. agree when there is a switch between one & two no announcement, which is confusing, unless real people shout.
The platform zero for a HHD especially the most used HHD service 1720 was a real cock up, I am sure someone on the screens SHOULD have seen red lights
flashing, but then only Gerald is priority one, not the busiest train on the down to HHD
HSTfan!!!
11 Jun 2005
well you'll find where I work Gerald can well be the last priority regardless... first in first out to the timetable, end of!
MCR247
7 Nov 2008
It was what platform the 0745 from Cardiff to Nottingham would depart from, or any rough ideas
