Phil Sayer announcements?
Tony2215
6 Aug 2013
I have a model railway and just wondered is there a software or anything I can download to the phil sayer voice announcement thing so I can make my own announcements on it? Or doesnt have to be phil sayer it can be anne or celia?
thanks
Muzer
3 Feb 2012
I would love this as well - not for model railway purposes, just for general messing around ;)
Unfortunately, I don't think such a thing exists. It would be great if all the Phil voice samples were officially released if not the software itself, but I think for commercial/legal/laziness reasons they wouldn't do this.
Best bet would be to find some high-quality recordings of the bits you need, I'd say. Not sure how easy that would be.
Class 92
12 May 2011
There is something available but you would need to fit some tag things to your layout and you may need to become a member.
I dont know how difficault it is to sort all the annocments out and fit the tags but if u watch the video on youtube it is quite good will get a link for it soon.
http://merg.org.uk/
http://www.pedryfan.co.uk/rfid/downloads/
Found a video you would need to put your own Phil Sayer announcements on it.
http://www.youtube.com/watch?v=ywVldZOIcWk
Tony2215
6 Aug 2013
thanks. cant seem to get this to work though, are the voices stored in this already or do I have to download wav files?
Tony2215
6 Aug 2013
I installed it then when I open the program I get an dialogue box titled "Microsoft. NET framework" that reads:
Unhandled exception has occurred in your application. If click continue the application will ignore this error and attempt to continue.
(im on windows 7)
Class 92
12 May 2011
Oh right you need to make sure that you install it to the Program Files on the C drive (Make sure it is Program File, not Program Files (x86))
Tony2215
6 Aug 2013
it wont load now it says there is a file missing called announcer.accdb. found in the db file but in the db there is no file called announcer.accdb!
Class 92
12 May 2011
Make sure that the db.zip file and put it in the C:\Program Files\RFID_Announcer folder
Tony2215
6 Aug 2013
No matter how hard I try I cant do this there is always a box it keeps coming up saying
C/Program file/rfid_announcer/db/announcer.accdb is not a vaild path. Make sure the path name is spelled correctly and that you are connected to the server on which the file resides.
Ive unzipped db file but all that's in it is a document that opens up using Microsoft access 2010.
Class 92
12 May 2011
Have you got the files set up like: 'C/Program file/rfid_announcer' or have you made the folder a differant name because it needs to be exactly the same.
Tony2215
6 Aug 2013
hehehe I didn't check that! all done now!! thanks dude :)
this only seems to be based on Cardiff central. What if I wanted to base it upon another station? Is there a download where I can download wav voice tags for Birmingham New St? or calling points for more stops/destinations?
