Permitted Route Advice
Tomd
27 Sep 2024
I have been researching permitted routes via Leamington Spa and London Marylebone and have the following question:
On a ticket "via any permitted route" can I start at Leamington Spa, take a train to Oxford, get off the train and take a train from Oxford to London Marylebone? The direct route from Leamington Spa to London Marylebone does not stop at Oxford.
Any help would be greatly received.
Many thanks.
Bill57p9
1 Dec 2019
Ayrshire
I can't answer your question directly, but you could try putting the journey with Via Oxford into the forum ticket site and see what pops out.
CyrusWuff
20 May 2013
Unless there's a direct train (entirely possible at the moment with the flooding between Bicester North and Aynho the past couple of days), Marylebone - Oxford - Leamington isn't a permitted route.
Options are:
  • Euston - Coventry (optionally via Northampton) - Leamington Spa
  • Marylebone - Leamington Spa direct
  • Paddington - Reading - Leamington Spa
Dirty_Mac
2 May 2024
Edinburgh
Options are:
That doesn't seem correct. This search gives me a super off-peak single for LMS-OXF-MYB.
CyrusWuff
20 May 2013
Marylebone - Leamington Spa direct is 88.75 miles according to the eNRT. Marylebone - Oxford is 66.5 miles and Oxford - Leamington Spa is 40.75 miles, for a total of 107.25 miles, so it's not within 3 miles of the shortest route.
London Group and Leamington Spa are both routeing points so there's no need to do a fares check.
Map combinations are EN+SM, GC and EG+RB. None of those show the route between Marylebone and Oxford and then on to Leamington Spa.
There doesn't appear to be a relevant easement, so I'm at a loss to explain how the forum site has concluded that's a permitted route.
Doing a search on the National Rail site gives the expected warning that it's not a permitted route and may require multiple tickets. (I specified the via point as Bicester Village because specifying Oxford resulted in a route via Paddington.)
Tomd
27 Sep 2024
Ah - thank you very much indeed!
Thank you very much for checking!
Tomd
27 Sep 2024
Thank you very much for this explanation. Really interesting seeing how they calculate permitted routes.
Really appreciate the reply.
