Permitted route Advance Single SOU - SSD
Bungle158
17 Jul 2019
Benaulim Goa
I have a paper ticket, marked with the + sign from Southampton Central to Stansted Airport. (via WAT). The ticket includes a journey from Waterloo to Vauxhall, where I am to take the Victoria Line to Tottenham Hale.
My question is, am I obliged to follow this route, or can I change at Clapham Junct for Vauxhall, or even simpler, use the Underground from Waterloo to reach Tottenham Hale?
Thanks in advance.
Haywain
3 Feb 2013
Thanks in advance.
Yes, any of these are fine.
You can use any recognised NR/Tube interchange station from the following list (copied from here on NRE) that's appropriate to the journey, i.e. on a permitted route:
  • Abbey Wood
  • Aldgate
  • Amersham
  • Baker Street
  • Balham
  • Bank
  • Barking
  • Battersea Power Station
  • Blackfriars
  • Blackhorse Road
  • Brixton
  • Canada Water
  • Cannon Street
  • Charing Cross
  • Ealing Broadway
  • Edgware Road
  • Elephant & Castle
  • Embankment
  • Euston
  • Euston Square
  • Farringdon
  • Finsbury Park
  • Greenwich (DLR)
  • Highbury & Islington
  • Kensington Olympia
  • Kentish Town
  • Kings Cross St Pancras
  • Lancaster Gate
  • Lewisham (DLR)
  • Limehouse
  • Liverpool Street
  • London Bridge
  • Marylebone
  • Moorgate
  • Old Street
  • Paddington
  • Queens Park
  • Richmond
  • Seven Sisters
  • Shadwell
  • Shepherds Bush
  • Southwark
  • Stratford
  • Stratford International (DLR)
  • Tottenham Hale
  • Tower Hill
  • Upminster
  • Vauxhall
  • Victoria
  • Walthamstow Central
  • Waterloo
  • West Brompton
  • West Ham
  • West Hampstead
  • Whitechapel
  • Wimbledon
  • Woolwich Arsenal (DLR)
  • Woolwich (Elizabeth line)
So changing onto the Underground at Vauxhall, Victoria, Waterloo, Southwark, Charing Cross, Cannon Street, London Bridge, Blackfriars, or even Bank, Battersea Power Station or Balham would all be permitted. Arguably a few others too like Tower Hill, Farringdon, Embankment and Aldgate.
Mcr Warrior
8 Jan 2009
Does an Advance Single from Southampton Central to Stansted Airport, presumably routed ✠SWR & CONNECTION, not obligate the user to use the ticket on a booked train (or trains), at the very least for the first part of the journey with South Western Railway?
Does an Advance Single from Southampton Central to Stansted Airport, presumably routed ✠SWR & CONNECTION, not obligate the user to use the ticket on a booked train (or trains), at the very least for the initial part of the journey with South Western Railway?
A fair point - I had missed that in the title (it wasn't in the thread text). Yes in that case, the trains shown on the ticket must be used. 'Appropriate connecting services' can be used for the remainder of the journey.
MikeWh
15 Jun 2010
Crayford
Yes, but if it is routed via Vauxhall and the train calls at Clapham Junction on the way in it will be undetectable if the passenger changes at Clapham Junction and exits at Vauxhall. It should also work the barriers at Waterloo and when entering the Underground, all TfL will be looking for is the Maltese Cross. In reality you will have no problems with either of your alternative routings.
Haywain
3 Feb 2013
Me too.
You are obliged to follow the routing on your itinerary for the part of the journey on SWR services.
Farigiraf
23 Jul 2023
Bridge on the River Cam
Would the WAT/CLJ - VXH section of the journey count as a journey by 'tube, DLR or train', using maltese cross cross-London validity? In this case, the OP has to travel to Waterloo, as you can't BOJ at CLJ on an advance, nor could you use the argument that the CLJ-WAT portion of the journey is part of the maltese cross journey, not the booked advance, since CLJ is drop-off only. But if the WAT-VXH leg is interpreted as part of the 'cross london maltese cross connection' then I don't think there's any requirement to travel from WAT to Tottenham Hale that way.
But to bring up a different example, I once had a Winchester-Cambridge advance routed via Clapham Junction, Victoria and Tottenham Hale - presumably the CLJ-VIC national rail journey was part of the maltese cross ride, not a booked train as part of the advance, meaning that I think I could've also travelled to Tottenham Hale via Vauxhall if I wanted to, on this ticket. However, does the algorithm in the journey planner know this? Does it view short hops like CLJ-VIC, CLJ-VXH or WAT-VXH as a booked service you have to take, or a maltese cross connection?
If the former, then by that logic any national rail journey between designated NR/Tube interchanges on an advance single is valid, as long as it's not circuitous, which would make it possible to avoid London Terminals on quite a lot of cross-London advances even if the journey planner sends you via central London.
Haywain
3 Feb 2013
If you want to avoid using London Terminals stations on an Advance ticket you should ensure that you get an itinerary that gives the journey you actually want to make.
Farigiraf
23 Jul 2023
Which is easy enough on Trainsplit but not so easy on most other ticketing sites.
Let's say I have a (totally random) advance from Cambridge to Woking, routed Cambridge - London Bridge - Waterloo East - Waterloo - Woking, with a maltese cross. The first and last leg would have to stick to the itinerary as it starts/ends outside London and BOJ isn't allowed. But even though the Southeastern hop from LBG to Waterloo via WAE is using National Rail, and is part of the itinerary, it's a maltese cross journey (which is flexible, even on advances), meaning that I don't think there's any need to stick to the booked SE service on this leg - I could even the tube if I wanted to. If I'm wrong, and you do have to stick to the booked SE train, then I don't see the point of offering the maltese cross on such tickets if you anyway can't make any use of it. It's essentially the equivalent of '& connections' validity on advances for cross-London high frequency NR routes like Thameslink, LO, SE or SWR, which do appear in a ticketing site itinerary unlike the tube.
If you genuinely do want to avoid central London for some reason - e.g. Chelmsford-Woking via LST and WAT, instead taking the Mildmay line from Stratford to CLJ - then if your advance is booked from Chelmsford to LST I don't think you can get off at Stratford even if it's not dropoff only. There, you do need an itinerary via Stratford, which in most cases is only possible on Trainsplit. But for a journey between two London stations (where you're booked to get off at) on an advance, you have total flexibility (within reason) to travel between the two on Tube/DLR/NR trains even if the journey planner has booked you a specific NR train between the two. Hope my interpretation is understandable.
Haywain
3 Feb 2013
The Maltese cross is attached to the underlying ticket type, not to the itinerary. There are many journeys that are made using tickets with that marker that don't actually require it and do not even go near a station where it could be of any use.
Farigiraf
23 Jul 2023
So, if we ignore the maltese cross, if you have a booked itinerary via London, involving a cross-London transfer on a high frequency NR service that does appear in the journey planner database, you have to stick to the exact cross-London NR connection that's in your itinerary just because that's the one the algorithm decided works best? I don't think that makes any sense on flows like WAT-VXH-CLJ, the Thameslink Core, or any of the Overground.
So for the OP's itinerary, if you do have to double-back to Vauxhall because it's a booked SWR journey, then logically you also have to take the exact booked departure between Waterloo and Vauxhall that you've been assigned? For a flow with 17tph that's obviously nonsensical, but with yours and Watershed's advice that's the rule, since a fixed itinerary is a fixed itinerary. Which is why I'd interpret such a leg as part of a cross-London journey, made valid by the presence of a maltese cross (even if a journey is possible without one), during which you're allowed to take any sensible Tube or NR route, including those avoiding Vauxhall. The fact that both SOU-WAT and WAT-VXH is with the same TOC shouldn't bear any relevance as they're very different types of services.
If I do have it wrong, and my interpretation isn't a valid one, then I guess that's one valid benefit that TfL taking over suburban London services from national TOCs/IBUs would have at least, other than spending a lot of money on changing up the branding.
No, the only National Rail legs which count as part of the cross-London transfer are those made on interavailable routes, for example the Thameslink core and certain Overground routes.
The WAT-VXH leg in this example is simply part of the journey, it does not fall under the cross-London rules. Because almost all SWR services are reservable nowadays, the booked train would be shown on the ticket and so the OP is legally speaking tied to it. In practice of course it's another matter.
It was not part of the Maltese cross for the reasons described above. The Maltese cross section of a journey, and whether or not a train is a 'booked'/reserved leg of an Advance, are two independent things. All four combinations are possible, as shown by the examples I've given below:
Leg is a 'cross London transfer'/part of the Maltese cross journeyLeg is not a 'cross London transfer'/part of the Maltese cross journey
Leg is a reserved trainA reservable Thameslink service through the Thameslink core (e.g. Cambridge-Brighton)An SWR train between Waterloo and Vauxhall
Leg is an unreserved train (so any 'appropriate connecting service' could be used)A non-reservable Thameslink service through the Thameslink core (e.g. Welwyn Garden City-Sevenoaks)A Southern 'metro' service between Victoria and Clapham Junction (not one bound for the coast)
You can take any 'appropriate connecting service' for the parts of an Advance where no service is shown on the ticket (or accompanying mandatory reservations). Whether or not it would be 'appropriate' to go via Vauxhall is a fair question but since journey planners offer it, perhaps even by default in some cases, I don't see why not.
See above.
NR legs between designated interchanges can be taken for non-reserved portions of the journey if they are 'appropriate connecting service'. Whether or not it's circuitous isn't relevant but rather whether they follow a permitted route (which would mean they would be offered by a journey planner).
It's not a Maltese cross journey. But the portion from Finsbury Park to London Bridge is also a Maltese cross journey and isn't flexible because it would be shown on your ticket. As per the example above, just because something is a Maltese cross journey doesn't mean that you can ignore what's printed on your ticket - legally speaking, at least.
You need to stick to whichever legs are shown on your ticket. If a SE service is shown (because it's reservable) then you need to stick to it. If none is shown then you can use any 'appropriate connecting service'.
The Maltese cross is defined at a fares data level. It means that journey planners will be able to validate and thus sell tickets with an itinerary that includes the Underground for example. The presence of a Maltese cross does not require the use of the Tube. Many tickets exist where it is equally valid and plausible to use the Underground or to avoid it - for example a walk-up ticket from Cambridge to Colchester, where you could change onto the Tube at Kings Cross/St Pancras or just change at Liverpool Street.
The Maltese cross primarily exists to validate travel on Underground/DLR services. It also validates travel on a handful of interavailable National Rail routes but that was not its original reason for being introduced.
The main issue is that an increasing proportion of services on high frequency routes, for example Thameslink, SWR, Southern and SE, are now reservable so that Advances can be offered for journeys where historically only walk-up fares would have been available.
The reservability applies on a train level so it isn't possible to configure a train so that reservations aren't issued on it (as part of a connecting Advance) when the section travelled is just a short one, e.g. Clapham Junction to London.
That is correct.
If it is shown on your ticket, then yes that is the rule.
I agree but the rail industry is not interested in having rules that make sense!
That is the rule and it makes no sense. In practice I highly doubt any member of gateline staff would be interested in whether you are on the exact booked service. There's hardly time for a guard or RPI to come through checking tickets either.
It's not, unfortunately. Frequency does not determine the ticketing rules.
The type of service doesn't make a difference as to the ticketing rules. SWR have decided to make (nearly?) all their services reservable lately, so every booked service will be shown on an Advance, eben local ones.
If you mean in terms of services no longer being reservable then arguably so, but that is a really niche benefit!
Farigiraf
23 Jul 2023
Thanks @Watershed for the in-depth response.
Is there a list of these routes? There's no chance it'll cover every high-frequency NR route so I don't think it's fully fit for purpose. Also the fact that I'm only hearing about this existing now (after about 3 years of learning about rail ticketing) shows just how much they actually want you to know about this.
The fact that high-frequency services on Advance tickets are handled informally isn't appropriate IMO. Naturally until it's made any better (and that's not achieved by reducing flexibility, GBR!) it's best practice but there are enough edge-cases that it creates complexity.
Waterloo-Vauxhall is an obvious one, where no staff will take issue with taking the first available service, but there are a number of 2-4tph connecting routes where for a number of reasons taking an earlier service makes sense. Making a cross-London transfer faster than expected is the most common example, but Stevenage-Cambridge is another, where someone arriving on Lumo/LNER would see the TL and GN trains depart within 5 mins of each other. You really shouldn't be penalty fared for taking the wrong one, but there's always a chance.
Which of these would allow you to be flexible with a connection on a '(Long-distance TOC, e.g. SWR) & Connections' ticket and which wouldn't? Officially, as in practice it usually doesn't matter. E.g. for a SN metro connection between CLJ and VIC, on which I had a counted place reservation (even though it stopped at Battersea Park, so was a metro service, I have the ticket to prove that I did get one), would taking any train not officially be valid?
But since the CLJ-VIC connection was shown on the ticket, it wouldn't have been valid? Counterintuitive.
Meaning that taking the tube between LBG and Waterloo wouldn't be valid on a maltese cross ticket if I have a 'reservation' on SE to Waterloo East. Note that there are 18tph between these two stations (plus the Jubilee line) and a transfer is possible much faster than the minimum connection time. Again, counterintuitive. These are just a few examples from actual journeys I've made, but I'm sure there are even more confusing cases.
The Maltese cross isn't just for the tube though, it's also valid on specified NR routes, as you explained. I'm glad you brought up that example, as on that route you may also opt for a change at Tottenham Hale for a local service to Stratford. That involves a short-distance high-frequency NR connection between two designated interchanges, but I would be surprsed if it's on the list of permitted unreservable NR routes through London. Therefore I'd have to stick to a specific train there as well, if on an advance, despite high frequency. Think we're at 4 counterintuitive cases now?
And even if you could, it would add even more complexity to the rail ticket system when it'd only be used by a small number of power users anyway, since every ticketing site will insist that advances are always only valid on booked NR services with no exclusions. So it's not an easily solvable thing, just quite frustrating. I'd be interested in knowing if there's any way of making high-frequency connecting services (on longer routes on advances) more flexible without opening dozens of loopholes.
How do other countries do it? Do they just not offer fixed-train tickets on high frequency heavy rail routes - which really isn't a good solution either, as there'll always be a dozen edge cases of services doubling up as high frequency metro + longer-distance regional services. Thameslink's undoubtedly the worst offender, though perhaps not introducing advances in the first place on an operator with 2tph+ at 99% of stations would've been a way of having your cake and eating it. But then you cart around numerous off-peak trains with fresh air.
To repeat my previous example, GTR can function as both an LNER/Lumo 'feeder' between Cambridge and Stevenage, and a longer-distance service down to London and Brighton. On the former, advances should be flexible; on the latter, it may be overdoing it. But maintaining a long list of flows which are exempt from the 'counted place reservation' system is also not sustainable nor passenger-friendly.
As others have said, in future, it is strongly advisable to obtain an itinerary you are happy with.
The forum ticketing site will let you specify various advanced options, e.g. you could force a change at Waterloo, or say don't change at Vauxhall, etc. If you ever need help obtaining a suitable itinerary, it's best to ask on this forum before purchasing the ticket.
In practice, you can generally get away with deviating from the route shown on Advance fares for cross-London travel, however it is a very grey area, and in the event of any unexpected delays, it could create a difficult situation.
If it was me, I'd obtain an itinerary changing at Waterloo and go Waterloo - Oxford Circus (Bakerloo Line) and then Oxford Circus - Tottenham Hale (Victoria). No stairs/escalators at Oxford Circus.
However, I'd check for signs of congestion before the train called at Clapham Jn (if it calls - only around half of them typically do; and none in the morning peak towards London) and consider changing there for a stopper to Vauxhall, if there were signs of delays on the approach to Waterloo.
The quickest way to the Bakerloo Line at Waterloo depends on the platform you use, but there is a direct underpass (avoiding the concourse) if you're around 3, 4 or 5 coaches from the front.
