Morpethcurve
- Joined
- 26 Jun 2012
- Messages
- 169
Just the inherent weight, I don’t think there’s any additional pressure such as springs.That’s quite surprisingly bad.
I suppose there’s not much actual weight on it from the shoe collector, or is there?
Yes I suppose so.Just the inherent weight, I don’t think there’s any additional pressure such as springs.
As far as I'm aware electrolytic corrosion is only an issue on DC electrified lines, and only where the current joins or leaves a conductor. So probably more of a concern on the running rails, as these are less well insulated from earth. I suspect the corrosion in Lancaster would have more to do with salt being blown in from the sea.Many years ago I walked down the entire length of the Snaefell Mountain Railway, and much of the "Fell" rail used for braking showed identical, if not worse, corrosion. In places it was totally collapsed. Even though the rail carries no traction current I presume there's enough residual/induced current to enhance the rail rotting.
You can see the same effect on bridges on electrified lines, for instance the safety rails on Carlisle bridge in Lancaster corrode at a remarkable rate due to the inductive effects of the 25kV
