Pendolino 135mph running
SkinnyDave
11 Mar 2012
I have been re reading a lot about last years WCML franchise fiasco
Virgin stated they wanted to invest money to run at 135 mph at certain sections
Has this ever been tested since 390s intro to service and where would they realistically get up to that speed in normal service?
Lrd
26 Jul 2010
I thought Pendos could do 140mph, obviously only with in cab signaling so they should be able to do 154mph including the 10%.
SkinnyDave
11 Mar 2012
if you read the links Yorkie posted it gives you a lot of information.
I dont think it will have much of a difference by the looks of it
Yes, that is the design speed, but not currently permitted in normal service. It has been stated that the limiter is currently set to 129mph.
notadriver
1 Oct 2010
TASS will intervene if the speed exceeds 3 mph above the line speed. So even though trains could go a few mph above 125 mph, they never do. Train drivers are professional and nowadays do not break speed limits.
notadriver
1 Oct 2010
One of the extra vehicles is powered so apparently performance is only slightly down on a 9 car set.
11 cars only make a difference at slow exits to stations, New St is the only place it has been spotted as making a slight issue.
Aldaniti
13 Jun 2009
You might just find that what Virgin want to do is invest other people's money in this project rather their own. I have no problem with this as long as excessive timetable padding is removed at the same time.
It is pretty much dead in the water, if they were going to get 135mph they would have by now. You will never stop operators putting +5 in the public timetable at destination either.
rebmcr
15 Nov 2011
St Neots
I think 390s will probably see 140mph in service eventually, but as the result of standard ERTMS rollout, not any special investment.
aylesbury
3 Feb 2012
I think that 125mph is okay for the WCML a higher speed would be adding to maintainence costs that are already very high.Passengers want reliable on time services and that is what Virgin are delivering.
TDK
19 Apr 2008
Crewe
To be fair pendos' have cruise control so once the set gets to 125mph the driver presses a button and it stays there - not the same sort of skill as getting a flat liner from a 158 at 90mph on an OTMR.
