Penalty Fare Appeal - Invalid Routing
Swedenorer
28 Sep 2025
Hants
Interestingly at the moment the NRE site will offer this fare on some dates but only if you change at Teddington both for xx14 and xx44 departures from Upper Halliford. It will not offer this fare for tomorrow it will only offer £22.30. The Southern Site also offers the £8.80 fare without the change. The old forum site will not offer it at all for 23/2.
I freely admit the way it seems to be working others might well get different results but what else can you expect from an industry that uses negative easement as a synonym for prohibition.
As for the RPI I bet he looked at this ticket as askance as one at Worthing might look presented with a ticket from Barnham to Littlehampton.
walkingsophie
29 Nov 2025
Sunbury
This does look like excellent rules abuse! (and expect Yorkie to be right about the routeing changing to NOT LONDON), BUT, as I see it the double back between ClaphamJ/Waterloo is only valid if you are actually travelling the Richmond route (Maps TW+EF). Otherwise there is a double back past New Malden (Map SU), and having chosen your mapped route you cannot switch...
Edit: I don't see how using map SU even allows you to get to Wimbledon...
Double backing at Wimbledon is valid via easement 000012.
I always ensure I go via Twickenham in at least one direction to ensure that I can do the double back between CJ and Waterloo.
First draft:
[Penalty Fare Case Number]
Dear Penalty Services,
I was travelling from Upper Halliford to London Waterloo on the 09/02/2025 1444 service with an Upper Halliford to Hinchley Wood Any Permitted Evening Out Return Ticket. I was charged a penalty fare for Incorrect Route at the gatelines at London Waterloo.
On the national rail planner, if you search for return tickets from Upper Halliford to Hinchley Wood departing at 14:30 and travelling via London Waterloo at an appropriate date in the future (for example 23/02/2026), it will show an itinerary using the Upper Halliford to London Waterloo train I was on. According to NRCoT (13.1.2), The tickets are valid as shown on an itinerary presented by the journey planner on www.nationalrail.co.uk, thus the tickets I produced were valid for my whole journey from Upper Halliford to London Waterloo
Yours Faithfully,
[My name]
Send with the PF notice and my tickets
Fawkes Cat
8 May 2017
First draft:
I am writing to appeal against the above penalty fare as my ticket was valid for the journey I was making
On the national rail planner, if you search for return tickets from Upper Halliford to Hinchley Wood departing at 14:30 and travelling via London Waterloo at an appropriate date in the future (for example 23/02/2026), it will show an itinerary using the Upper Halliford to London Waterloo train I was on. I enclose a print of this itinerary. According to NRCoT (13.1.2), The tickets are valid as shown on an itinerary presented by the journey planner on www.nationalrail.co.uk, thus the tickets I produced were valid for my whole journey from Upper Halliford to London Waterloo
I would be grateful for your prompt confirmation that the penalty fare has been cancelled
Yours Faithfully,
[My name]
I've suggested 3 additions (n.b. - click to expand the box to see them all). The topping and tailing are to make it easy for SWR to understand quite what you want out of the process - they should be able to work it out easily enough, but as you want something from them, it's in your interests to make it really easy for them. And if you can generate a print of the itinerary which does what you want, I think it makes sense to enclose a copy: from the comments in this thread this does not seem to be an easy itinerary to create, and you wouldn't want SWR's response to amount to 'I can't get that itinerary, so I don't believe you could either': neither is it impossible that now this loophole has been uncovered it will be closed very promptly so that by the time your appeal is looked at, the itinerary is no longer available.
walkingsophie
29 Nov 2025
Sunbury
Getting these printed and adding them to the mail should be sufficient, right?
  • Printout.pdf
walkingsophie
29 Nov 2025
Sunbury
I am writing to appeal under 16(3)(a) of the regulations against the above penalty fare as I produced a ticket that was valid for the journey I was making under 4(1), so 5(1) was never engaged
On the national rail planner, if you search for return tickets from Upper Halliford to Hinchley Wood departing at 14:30 and travelling via London Waterloo at an appropriate date in the future (for example 23/02/2026), it will show an itinerary using the Upper Halliford to London Waterloo train I was on. I have enclosed a print of this itinerary. According to NRCoT (13.1.2), The tickets are valid as shown on an itinerary presented by the journey planner on www.nationalrail.co.uk, thus the tickets I produced were valid for my whole journey from Upper Halliford to London Waterloo
Yours Faithfully,
[My name]
Does this look good?
Edit: For the benefit of people reading this in the future, when submitting the actual penalty fare appeal I have replaced the first paragraph with the following:
"I am writing to appeal against the above penalty fare as my ticket was valid for the journey I was making"
Also is there a significant difference between appealing via https://www.penaltyservices.co.uk/make-an-appeal/ and via post? I'd prefer to appeal online if possible.
z444z
17 Apr 2022
Might it be more effective in this case to simply argue that the ticket was valid, rather than arguing that 5(1) was never engaged because of xyz? I would expect the appeals service to know to cancel a penalty fare if the ticket was in fact valid, all the additional legislative stuff may just confuse things and could always be added to the final stage appeal anyway if required.
Yes, this. Just state and demonstrate the ticket was valid, that is all that is required.
furlong
28 Mar 2013
Reading
(My words were only a brief summary of what needs to be explained. It's up to the OP how to phrase it.)
z444z
17 Apr 2022
Wasn’t a dig at your perfectly reasonable suggestion btw, just an alternative suggestion :)
Fawkes Cat
8 May 2017
I've just realised I have typoed the date as 2025 instead of 2026 in my appeal. Hopefully that will not be a problem
The consensus round here is that while there are three rounds for an appeal, the first two tend to be a bit of a waste of time (although you have to go through them to get to the third appeal). So if this typo does cause a rejection, you can still put things right for the third appeal.
z444z
17 Apr 2022
Surprisingly enough, the first appeal was successful. I guess the new NRCoT does work.
That’s great! Would you be willing to share the response to your appeal? Would be helpful for us. Remember to redact personal details though.
z444z
17 Apr 2022
Thanks for sharing that, a fairly decent response but you’d hope so with something so simple.
Looks like this was indeed the way to go though.
walkingsophie
29 Nov 2025
Sunbury
Note that for the appeal I just showed the outbound ticket and the route the national rail journey planner showed, which implies that they now do the appeals based on the new NRCoT (13.1.2) rather than the routeing guide, as the ticket I showed would not have been valid for the whole journey with just the routeing guide. This might be helpful in the future when appealing more routeing based penalty fares, and I think is definitely helpful for the people giving advice here.
bb21
Emeritus Moderator
4 Feb 2010
Yes keep it simple where possible. Chances are people at the appeals body haven't even heard of the routeing guide so there is no point complicating things unnecessarily.
sot
17 Jul 2022
SOT
An excellent outcome, well done.
I'm glad they said something along the lines that it was allowed routeing rather than the "we have decided to cancel this pf on this single occasion for some unknown reasoning that we are not going to share with you"
jfollows
26 Feb 2011
Wilmslow
Right outcome, but did anyone apologise for the errors which caused a Penalty Fare to be incorrectly issued in the first place? It doesn’t look like it to me.
sot
17 Jul 2022
SOT
It may be worth a speculative post in the correct area, but given this new NRE validity rule I suspect sooner rather than later there will be some form of 'reasonable' adjective applied within the ruling - no London to London via Aberdeen allowed.
They seem to have opened themselves up to routes that were previously not allowed by the Routeing Guide for no reason.
Even more insane is the lack of requirement to even buy with an itinerary now, if NRE is good then all is good it seems.
That is unless this was valid due to some recursive LONDON routeing points or was within the allowed 3 miles.
OP - perhaps if you wish to account for the future usage, travel with a copy of the PF and appeal decision to convince and thwart any further unwarranted PFs. Or don't and demand some great compensation if it occurs again.
walkingsophie
29 Nov 2025
Sunbury
Yes, there's a high potential for exploiting here.
In this case neither of these apply, and in fact the Upper Halliford to Hinchley Wood ticket is not valid between Wimbledon and Clapham Junction according to the routeing guide.
z444z
17 Apr 2022
Then they should make their website work properly, and if they can’t do that it’s probably a sign the fares system needs simplifying? Am I missing something?
ChilliSauce
28 Oct 2025
A
Personally I am not sure if it is the role of "Penalty Services" to apologise for the failing of the TOC by way of clearly wrongly issuing the PF.
Perhaps the OP should now open a customer complaint with SWR complaining they had to go through the procedure of appealing a PF that basically should never of been issued in the first place, and seek a reasoning from SWT for this failure and an apology for inconvenience caused.
Starmill
18 May 2012
Bolton
Have you raised a complaint about the inspector with SWR customer services?
They're unlikely to cough up anything much but if I were you I would send them a copy of your appeal being allowed and ask them to confirm if they agree the inspector made a mistake which caused you to waste a significant amount of your time. It will be interesting to see what they say. In theory they could be liable for damages for your wasted time, if they accept that the inspector shouldn't have issued the Penalty Fare, though they are very unlikely indeed to accept that point willingly. This certainly won't amount to much in cash form but say £40 for two hours of work for you filling in the appeal and dealing with the correspondence seems reasonable to me.
Personally I am not sure if is the role of "Penalty Services" to apologise for the failing of the TOC by way of clearly wrongly issuing the PF.
Perhaps the OP should now open a customer complaint with SWR complaining they had to go through the procedure of appealing a PF that basically should never of been issued it the first place, and seek a reasoning from SWT for this failure and an apology for inconvenience caused.
These messages crossed in the posting, but I agree with the suggestion. This can be done without referring to the possibility of a breach of contract or damages for wasted time if preferred, as it's less confrontational.
bakerstreet
29 Nov 2009
Possibly one for a separate thread, but I’m appalled that we are now in a position where (ignoring anyone on this forum testing validities of routes) passengers essentially risk a penalty fare by taking an invalid route when it should be pretty obvious that somebody who:
- possesses a ticket,
- is travelling from the origin and to the destination on the ticket,
- or is asking to break their journey
- has appropriate supporting documentation for the journey (eg railcard)
- that the journey is taking place on the correct date
- and the ticket is valid for the time the journey is being made,
- is not taking the Michael
- is an adult or child and the ticket matches the passengers status
is most likely to be an honest passenger.
I think this is one of the most egregious changes in recent times to ts and cs on the English railway.
To be required to pay a penalty fair under the circumstances, and be logged as a wrongdoer in the railway system, is very worrying in my opinion
