Freight Drivers learn far more routes than passenger. FAR more. For example, I've said it before & I'll say it again, a newly passed out driver for my TOC (Northern) only signs 3-5 routes, mostly short local routes.
That maybe so for YOUR TOC but the world doesn't start and end at Northerns borders.
There are EC drivers at Newcastle who sign KX to Aberdeen,Carlisle via Tyne Valley,Donaster-York via Askern/Milford/Colton,Newcastle-Northallerton via Durham Coast/Yarm/Picton Branch just as there are FlIM drivers who sign Leeds-Peterborough and nowhere else!
Freight drivers do not have to know the route to the same level of detail as passenger drivers before being allowed to sign it.
That one sentence proves you know next to nothing about the subject.
All large FOC's have the same Group Standards and Safety Cases that any operator on NR needs to adhere to.
Unannounced audits ensure these requirements are taken seriously.
Passenger drivers need to stop for stations - freight drivers need to stop for points into loops and yards,they need to know gradients to the nth degree especially with trailing weights approaching 3000 tonnes.
The route knowledge for either job needs to be equally as good.
That's why I say any monkey can 'operate' a train - only an experienced driver can actually 'drive' a train.
No amount of listening to tittle-tattle will ever replace experience.
freight drivers also spend more time in yards and carry out a lot more shunting.
Totally depends on the company (and even the location within that company).
DBS are recruiting Depot Operators to cover shunting freeing up mainline drivers to do the distance work - in that case a TOC driver will do far more shunting simply taking a set to depot than any of the mainline drivers at locations where DO's are used.
No.
SOME freight can have 'worse' shifts than SOME TOC's.
The shifts at certain IM depots are 95% dayshift starting around 0800 and finishing around 2100 with various shift lenghts.
FTPE operate almost around the clock to Man Airport.
EC services can start around 0400 (bringing set from depot) and finish after 0200.
Cross Country is very similar.
Not quite as black/white as you state is it?
and often worse traction in the form of class 66's which are apparantly worse than anything except a 142.
You use the word 'apparently'.
I take it you aren't passed out on the traction and have precisely zero experience of them?
The Cl66 isn't without fault but i'll let you in on a little secret:
They are FAR FAR better than the old relics they replaced.
Excellent reliability,modern ergonomics,comfortable seating,enough power and tractive effort to totally wipe the floor with anything fitted with a marine engine,software and hardware to pull a weight that would see 2X37's struggling and slipping to a stand.
There is a reason you only see 31,37,47,56 etc used on 'pretend' railways and fly-by-night FOC operators.
Can you guess the reason?
Speaking from an empty stock driver it is very nice not to have passengers, and I think most Drivers in my TOC would agree its better when you do not have passengers.
In other words,you've driven empty coaching stock but nothing else.
You then use flippant remarks from others to form a definitive opinion.
I can spot a tiny flaw in your plan...
The positive side to having passengers is the job satisfaction you may get when they ask you a question and you can answer it.
That.
And the fact that without them you wouldn't have a job!
Even on Maintenance Depot Driving we use braking zones. When shifting a "swinger" type unit it takes a very long time to stop even when braking from 5mph if the swinger is a lot heavier than the braking unit especially on the downhill gradient on the south end of Newton Heath.
Seriously mate,there is NO comparison.
