Passenger train consists as Open Data
Freightmaster
Verified Rep
7 Jul 2009
Those don't show allocations, unless I am missing something.
Correct - it was in reply to people pointing out passenger trains which are listed on RTT
but don't show allocations because the operators do not use the GEMINI system, such as
Tyne and Wear Metro, Sheffield supertram, etc.
There was a time when they did show, although at a different Wimbledon station. I seem to remember that they were either 1Ixx or 2Ixx depending on whether they were Edgware Road or 'City' services.
They still show on realtime maps, but the trains don't use different headcodes:
(extract from my Woking to Wimbledon map)
MARK
Peter Mugridge
8 Apr 2010
Oakham
That's a known issue with the data on the branch; it doesn't even show the trains correctly on the platform indicators at the stations between West Brompton and Wimbledon.
takno
Verified Rep - Traksy
Hopefully there are plans to introduce this into websites such as Trasky , RTT and Railrecord quickly.
I'm hoping to get something out for Traksy soon, although I expect it to initially be an extension of the way we currently do C2C tracking - barebones unit numbers, and on the new site only. Will take a couple of weeks to think through whether I want to do a more comprehensive version and how to make it available to free users.
The release comes entirely without documentation in the form of gigantic XML files fed through a new connection method, so it's not going to be trivial, and it's unlikely to be released for a day or two. You may see me hacking away on Monday and Tuesday as I take very stupid way round from London to Edinburgh.
trainmania100
8 Nov 2015
Newhaven
The good thing about c2c is the trains don't divide on route. I've only just started properly looking at this, but now I'm having trouble finding a service that divides so I can handle the deallocation properly on a schedule route...
I've found today's Horsham / bognor splits but I've only just started logging so I've missed the input...
Agree documentation would be good but I guess that takes the fun out of it. Eg not knowing the difference between TrainDest and AllocationDest lol
takno
To be honest I think it's reasonably clear, or not incredibly difficult to figure out, and waiting for somebody to clear the documentation as well would only have delayed the process even further. It's mostly just quite a lot to parse through and get set up, with having to use an external Kafka connection. The Kafka client library I'm using is already a bit dicey for internal connections, so I'll probably need to look at something which just copies the queue over to my local Kafka server.
Poggs
Verified Rep - OpenTrainTimes
28 Aug 2008
There is an ICD (Interface Control Document) on its way, and some XSDs (FOI request pending) for the XML data will be available soon too. I will also write a less formal explanation of how to use the data for the Open Rail Data wiki in due course.
takno
Wonderful, thanks for all the hard work on this.
I think looking at the messages that I've got a fairly good grip of what most of the fields mean. It would be good to know what some of the possible values are for operators and liveries (I guess the operators might be the same values from Trust, but just as a 4 digit number?). Would also be handy to know whether the train id (which is embedded in a longer code for the examples I've looked at) can be depended on, or whether I should be figuring it out from operator/station/headcode.
Dren Ahmeti
17 Oct 2017
Reading
Hopefully it will happen at some point given most TOPS data is already available "on demand". Eg through groups.io where various groups publish loco pool lists daily...
Yes, but TOPS access is tracked, and a few similar “holdouts” on the freight side of thing view it as infringing on “commercial sensitivity” - it took a lot of work to get freight headcodes unscrambled - I remember the days of FRGT and random headcodes being displayed in data!
trainmania100
8 Nov 2015
Newhaven
I was looking this morning for the operator codes I wasn't sure if it had something to do with the 2 digits at the end of the train ID eg (not a real example) 2K21W1234523 as I can't see anything else it could be.
Tom
19 Jan 2008
35,000ft
The last two digits at the end of the Train ID in LINX messaging from memory is the hour of train departure from origin. RTT uses the Core identifier and plucks the UID out of it. From memory in some cases a TRUST ID can also appear in that field (but that might have been changed in the past few years!)
From experience the metadata that goes along with the messages, e.g. livery/operator/seats, can be taken with somewhat of a pinch of salt.
littledude
21 Nov 2011
People’s Republic of South Yorkshire
The last 2 digits of the full headcode are the day of departure. Everything departing today will end with 21
trainmania100
8 Nov 2015
Newhaven
Happy to be corrected but the TRUST ID last 2 digits is the day of departure, this linx specific element I think is different.
Guess a cif lookup will be needed to get the operator then.
Oxfordblues
22 Dec 2013
I'd love to be able to access TOPS if only to find out about wagon locations and train-lists, but I can see that they might be deemed commercially-sensitive, so I don't hold out any hope.
Tom
19 Jan 2008
35,000ft
That is correct for TRUST but LINX (where this data flow originates from) is not the same.
For instance, a message I've randomly plucked from Friday (19th) has a Core train ID of 1W57G5608010 which was scheduled to leave Cardiff at 1053.
You can get the sector code from the ResponsibleRU field. I'm not sure I would trust the Operator/Livery fields personally on the actual allocations based on past experience - RTT uses a custom mapping.
trainmania100
8 Nov 2015
Newhaven
I see it now- thanks.
See what you mean, TL, SN and GN all use sector 88 as part of GTR.
Not familiar with ScotRail workings, do any friends here know if 170s are regularly paired with 43 sets?
Poggs
28 Aug 2008
If you have some money, you can get access to the rail mainframe for yourself - we're taking a few thousand pounds per year for two CICS sessions. No guarantees you'll be able to make the TOPS enquiries you want, but it is possible.
Thank you - it's been a priority of mine to get this data open so everyone can use it - not just me!
Operator codes are 99xx, with the 'xx' being the numeric code as used in TRUST messages. Liveries... that's another story, I'm now trying to assemble all the associated reference data to help people make best use of it.
You shouldn't need to work anything out - allocations have start/end times and TIPLOCs which you can match up to a schedule. Likely you won't even need to reference any of the train identification data, but if I were you, I'd work with the UID embedded in the TransportOperationalIdentifiers tag.
takno
I'm hoping to keep building this as a separate model which doesn't need access to the CIF schedules, but l'll see where we get - it all ends up running in the same process anyway, so it's not the end of the world if it has to do a schedule lookup
nesw
5 Jan 2013
I wonder whether there’s scope or sufficient detail to use the allocation data to produce resource diagrams?
Class 466
5 Mar 2010
Atherton, UK
it would be pretty cool if there was a fleet list site that listed when a train was last allocated and what to. Alas, I have no such skill.
trainmania100
8 Nov 2015
Newhaven
It's possible, but obviously it's not going to ever be 100% accurate, I've seen 377 diagrams get updated late evening for services they worked in the morning.
Poggs
28 Aug 2008
Yes, there is enough detail to do that - but only where resource allocations are made. You don't know if a resource diagram is an LTP or STP diagram, therefore you can only guess (but quite reasonably most of the time) until you've had what you think are all allocations in for a particular day.
JAWZ
29 May 2023
Bath
This is excellent news - just started playing with the API myself, hopefully should have it integrated into TrainMapper soon!
You can enter a unit number into the search on Realtime Trains and if it's currently doing something it will bring that journey up.
One thing that would be REALLY handy would be if this data included which way round a given unit is, particularly on TOCs where units can end up either way like TPE and XC. That would require input by guards, I guess, though, so I doubt it's coming soon.
MrJeeves
28 Aug 2015
Burgess Hill
The data includes this, but its accuracy is unreliable for most TOCs.
That's quite interesting as the formation diagrams on CIS displays usually do show the orientation correctly for most TOCs so the data must be there somewhere. Those diagrams for something like WMT obviously don't show first class (even though it'd be useful for those of us who like the declassified bit to know where it is so we can get there first, same for the bike spaces which if accurate would result in fewer bikes shoved blocking the way in vestibules) but for the likes of XC it often is correct. However there do seem to be multiple sources of this data - one I noted recently was SWR platform screens saying in the text "this train is formed of 6 coaches" but the little icons showing three (the 6 was correct).
JAWZ
29 May 2023
Bath
Don’t the “associations” records in the Schedule feed essentially describe diagrams? I played with them a bit recently but not to the extent of trying to build up a UI for them. Looked fairly comprehensive though from just playing with SQL.
Where is the API access link? I'd like to start using it too
It’s on the RDM site, you need to sign up for an account, the link isn’t public as such. Easy (and free!) to subscribe though.
nesw
5 Jan 2013
Greater Anglia upload formations and capacity for long term and short term each week on the marketplace. I’m guessing that it would be possible to match the data using the ID. C2C also publish their formation data each day and a number of other operatots have uploaded long term plan formation data. I’m told that the open Gemini data includes diagram numbers, NT 301 as an example, that should simplify creating diagrams.
stadler
5 Jun 2023
Horsley
I think that is a major London Underground wide issue. Nothing really to do with this section in particular. Lots of stations between Earls Court and Ealing Broadway also fail to show trains properly on the station boards. Even some stations in Central London can be very out of sync with the reality of when trains are due to arrive. London Underground are just very poor at providing correct next train data at stations.
