Paddle Steamer Waverley
morrisobrien
23 Aug 2017
Waverley,built in 1946,is at present sailing the longest journey of her life.Ayr to Plymouth 'clockwise' ie. northabout.She has just left Dundee after taking on more fuel and water.
Sir Felix Pole
21 Oct 2012
Wilmslow
Strong winds and swell forecast off Land's End I believe - hence having to take the 'long way round'. Excursions from Penzance and Falmouth cancelled, unfortunately.
CarltonA
22 Apr 2012
Thames Valley
It's a fairly good vessel to travel on though I only did a return from Ilfracombe to Lundy Island. The food on board was good. It broke down in the Bristol Channel afterwards and had to be towed into Barrybados docks.
John Luxton
23 Nov 2014
For anyone who hasn't done it WAVERLEY is a good day out and she is a former LNER ship.
If I had a choice between a trip behind an A3, A4 or WAVERLEY - I know the one I would chose. :D
Only thing is she does have weather limitations - beware travelling long distances or booking hotel accommodation for sailings specifically to travel on her unless you book flexible rates which you can cancel.
I know one or two people who have booked non cancellable hotel deals for WAVERLEY trips and the inevitable has happened.
Fortunately she does tend to come to Liverpool once a year thus I can get a couple of trips in each time she comes and was on her earlier this year.
Whisky Papa
8 Aug 2019
Ayr to Brodick in 1999 proved a memorable day out, and an unexpected finding rather than being pre-planned.
We had also seen her by chance calling at Clevedon pier a few years earlier.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Wouldn't it be wonderful if she could be scheduled to cover the annual Manchester Ship Canal trips from Liverpool to Salford and return? Unfortunately she tends to be in Scottish waters in June.
John Luxton
23 Nov 2014
Unfortunately it won't happen due to her limited manouverability some waters are restricted. She isn't allowed into the Menai Strait either.
When Waverley Steam Navigation Co owned the MV BALMORAL I believe she went up the MSC.
Mersey Ferries no longer run to Salford due to silting issues and just run round trips from Liverpool to Latchford Lock and back.
However, the SS DANIEL ADAMSON does run trips on the Manchester Ship Canal, River Weaver and River Mersey, though the trips up the canal Runcorn and beyond have been run for this year. Though there are quite afew still on the Weaver and lower canal still to run.
To find out about the SS DANIEL ADAMSON please visit https://www.thedanny.co.uk/
BayPaul
11 Jul 2019
Arriving in Dartmouth after her longest journey!
AndrewE
9 Nov 2015
Another place that Waverley used to visit but isn’t allowed to now is Bristol.
which isn't surprising given the tortuous channel to get there - and the cost of tugs fore and aft in case anything went wrong. It must be an absolute nightmare steering her when you can only deviate from your current line when you have plenty of forward (or sternward) motion...
and looking great...
BayPaul
11 Jul 2019
She's surprisingly easy to push around! Two smallish ribs (115hp + 70hp) do the job nicely!
Plus I wanted to show off a few more photos of my favourite ship!
There's also the risk of the engine stopping dead centre at a critical moment: https://www.gov.uk/maib-reports/contact-with-pier-by-paddle-steamer-waverley
The investigation identified that Waverley made heavy contact with Brodick Pier because the engine was slow to provide astern propulsion due to the engine becoming ‘locked’ at top dead centre, and the engineers controlling the engine could not rectify the matter quickly enough to prevent the collision.
AndrewE
9 Nov 2015
O0ops! When I was on board and visiting the engine room I asked about the "controls" which looked like a small 4(?) lever signalling frame. The engineer explained that the extra lever I couldn't explain for myself was a "Simpling" valve. It just puts full boiler pressure into all 3 (normally compound) cylinders. With this I would have thought that there was no "Dead Centre..."
BayPaul
11 Jul 2019
The issue is that it takes a few seconds to get to that value and use it... Can be too long!
fandroid
9 Nov 2014
Hampshire
A great experience. Thoroughly recommended. I have been twice this year, around the Isle of Wight (in both directions). Great welcome on board and good food.
Harpo
21 Aug 2024
Newport
I’d thoroughly recommend the Thames trips that include passage through Tower Bridge especially as it needs the bridge to be open. Even more impressive is doing those trips after dark with everything around the banks of the Thames illuminated.
telstarbox
23 Jul 2010
Wennington Crossovers
Thames Barrier, Greenwich and the open bridge.
greyman42
14 Aug 2017
Yes, Canary Wharf looks good in the dark.
Harpo
21 Aug 2024
Newport
Yes. Try the view from the high ground in Greenwich Park (e.g. by the observatory) at dusk too. But it needs careful timing as I think the park closes when it gets dark?
Russel
30 Jun 2022
Lichfield
Been years since my last trip on Waverley, I'm going to have to keep an eye on her schedule next year to see if I can fit in a trip!
hermit
23 Jul 2019
Isle of Wight
Harpo
21 Aug 2024
Newport
I’ve never understood why a non-sailing ship needs masts at all, but there’s no doubt a good reason.
Just needing Tower Bridge to be opened for it on every visit to Tower Pier is good enough reason for me! :lol:
Gostav
14 May 2016
Every ship going to sea must have a mast capable of flying markers and flags to indicate its identity and other information. The mast also supports antennas and other equipment essential at sea.
Modern ships don't have tall masts because the superstructure takes up a large portion of their height allowing those equipment to be installed directly on the roof.
AndrewE
9 Nov 2015
I hesitated to say that (not being much of a sailor) I understand and have experience of a boat rolling heavily which was immediately controlled/reduced by hoisting a small mizzen sail, which acted an an air brake.
Hence lots of small fishing boats which are entirely engine-powered still having a mizzen mast and a small sail - which when stationary also has the effect of keeping them head to the wind/waves and a lot more comfortable. I think a lot of pictures of early steamships show such sails not needed for propulsion, my interpretation is that not needing a keel to stop them blowing sideways meant they would have rolled badly, so a few fore-and-aft sails were useful in that respect.
