Paddington to Farringdon connection question
ngood77
30 Nov 2012
Hello everybody.
I have a ticket with the attached suggested itinerary provided by the retailer (trip.com). It’s an Advance ticket so I am required to travel on the specific Chippenham and Farringdon trains shown.
The suggested service between Paddington and Farringdon does not allow sufficient connection time at Farringdon which, according to brtimes, has an MCT of 8 mins between EL and TL platforms.
I notice that the tube fixed link time between Paddington and Farringdon is 19 minutes at this time of day so is that what makes this a valid itinerary regardless of the individual connection times of the two stations ? I didn’t think the EL was classed as tube for FL purposes.
Where am I going wrong ?
Many thanks.
Our site won't offer that itinerary; it's not a compliant itinerary.
By using Trip.com? ;)
They appear to cut corners and their site appears to be generally shoddy; it's surprising they pass accreditation, given numerous issues that have been uncovered over the years.
What's the final destination?
ngood77
30 Nov 2012
They should not have offered this itinerary.
But they have, so you are entitled to use the ticket!
I'd recommend using the forum's ticketing site :)
My concern is I don’t have the MTC/FL protection for the Paddington to Farringdon (TL) leg.
What do you make the valid connection time as being ?
I was naively under the impression there is one underlying ticketing system that suggests itineraries. How come one retailer can suggest this and another wouldn’t ? Why is your system better ? Genuine questions. Ta
kacper
27 May 2022
In my non expert opinion and from what I've gathered with a similar journey, I think that anything after you reach Paddington is flexible?
Seeing as the EL trip counts as a cross London tube trip, you don't need to follow that. And Thameslink allow any train on an advance if you connect from another TOC (I believe there's a thread somewhere on here that explains this in more detail)
redreni
24 Sep 2010
Slade Green
You're following your itinerary issued by an accredited retailer, so you have the same protections as you would if the MCTs and fixed link times had been respected.
And in practice, 29 minutes is ample for that connection in my opinion.
etr221
10 Mar 2018
OTOH, if your GW train is on time, you stand a good chance of getting an earlier EL train at Paddington. Then be at the back of the EL train, and use the lift up to pfm 3 (not the escalator, which goes to pfm 4...) and you stand a reasonable chance of making your TL train.
ngood77
30 Nov 2012
Not according to my tickets
Thanks, that’s helpful. So if I follow the suggested itin between P & F, and it arrives on time at 19.00, I can’t be punished for missing the 19.04 TL ?
Hadders
27 Apr 2011
It would be helpful to know exactly what the routeing is on your ticket. I suspect it is +AP Slough.
If so then internal industry guidance says that you can take any train between London bridge and Brighton.
  • Where a journey involves using a Gatwick Express, Great Northern, Southern or Thameslink as a connection into a different operators service (not a different Gatwick Express, Great Northern, Southern or Thameslink service). For example Advance Tickets routed “AP SLOUGH”, or “AWC & Connections”, the passenger can use any Gatwick Express, Great Northern, Southern or Thameslink service to complete their journey, even though retail systems will force a reservation to be made.
ngood77
30 Nov 2012
Yeah I just read the TL bit elsewhere, reassuring.
There’s no routing on the ticket.
My onward leg is (again mandatory reservation) 19.24 LB to TON.
Mcr Warrior
8 Jan 2009
If your actual journey is from Chippenham to Tonbridge, and you have been sold a (Booked Train Only) advance single ticket, then the routing should indeed be 'Route ✠AP SLOUGH' as @Hadders has already mentioned. Presume you've not been sold some weird combination of split tickets by trip.com?
ngood77
30 Nov 2012
No, nothing on the ticket about routing or Slough.
Hadders
27 Apr 2011
I assume you're on the 19:36 from London Bridge to Tonbridge. If so, then the itinerary gives sufficient interchange time between Paddington and London Bridge, which is 55 minutes at that time of day.
FastJP gives the same itinerary, albeit showing it as a London Underground connection. Thameslink can be used as a cross-London connection.
ngood77
30 Nov 2012
Nope, 19.24. And my ticket says I must travel on the 19.04 from Farringdon to LB.
The 55 mins is calculated as 15 + 30 + 10, correct ?
You can ignore that; this is because TL trains are mandatory for reservations when using an Advance ticket in the data. But in practice you are on a cross-London transfer, so it's fine.
Also, see post #11 above.
ngood77
30 Nov 2012
And what about the SE leg ? Can that be ignored too ?
Hadders
27 Apr 2011
I cannot see how this itinerary is compliant. When the ELizabeth Line first opened the default interchange time at Farringdon was 3 minutes but it was soon amended to 8 minutes when interchanging between the Elizabeth Line and Thameslink and v.v.
For reasons we have explained above the mandatory reservations on the Thameslink train can be ignored.
Correct. But if you're booked on the 19:24 from London Bridge then that isn't compliant.
ngood77
30 Nov 2012
Quite. So should I take it up with trip.com or put faith in the ticketing staff on the day will be understanding (a big risk in my view) ?
Hadders
27 Apr 2011
By all means take it up with Trip.com but don't expect anyone to understand the issue - they are not renowned for their customer service.
In reality as long as your train is on time into Paddington then you should make the 19:24 with time to spare.
Kite159
27 Jan 2014
West of Andover
That itinerary in my eyes is a bit bonkers, surely using the Bakerloo direct from Paddington to Charing Cross to board the Tunbridge Wells train at the starting station (more relaxing compared to standing around London Bridge) is more logical than using the Lizzy to Farringdon with a Thameslink to London Bridge (other than wanting a cooler journey).
ngood77
30 Nov 2012
I didn’t ask for that itin ! The funny thing is I’m actually going out in Farringdon so am going to have to either take a chance on the night or contactless it across London instead.
Didn’t think the forum would be beaten by this one ! I’ll be wary of trip.com in future, although they are cheaper.
Ciao for now.
alistairlees
29 Dec 2016
Ciao for now.
What's your planned date of travel? The GWR arrival time at Paddington varies slightly, and this sometimes changes all the subsequent legs (though it does not excuse the inadequate time to change at Farringdon)
redreni
24 Sep 2010
Slade Green
Sorry, when are you going out in Farringdon? After arriving at Paddington but before departing London Bridge 58 minutes later?
Ciao for now.
Your original question was "where am I going wrong?" which Yorkie answered in post #2.
Your itinerary is non-compliant but issued by an accredited retailer. It is also eminently followable in practice, in my opinion. My suggestion would be to follow it, and if disruption prevents you following it, travel on the next train to Tonbridge. It's a judgement call whether better to approach the guard before they approach you, or simply play it cool, show your tickets if asked and then deal with any objections they may have to your being on the wrong train at that stage (by politely explaining that you missed your connection due to a delay earlier on in your journey).
Realistically the only way you'd miss your train is if your train into Paddington is late or there is disruption on the Elizabeth Line and/or Thameslink core, all of which will be checkable by railway staff. When they check the actual times they'll see the MCTs weren't met and conclude that you should be allowed to travel on the next train to Tonbridge. (If they were to check the booked times rather than the actuals, they'd also see that the MCTs weren't met as you've pointed out, but it shouldn't matter if they notice that or not as you'd be travelling on an itinerary, issued by an accredited retailer, against which your tickets were sold to you).
ngood77
30 Nov 2012
Just out of interest is a booked train only a booked train where a seat reservation has been made ? Because although I have mandatory reservation coupons with timed trains there are no seat reservations of course for the TL and SE trains.
Hadders
27 Apr 2011
If a booked train is mentioned in an itinerary on an Advance ticket then you must travel on it (unless disruption prevents you from doing so). The only exceptions relevent to your journey involve Thameslink as referenced above.
