Paddington to Euston and vv
MarlowDonkey
4 Apr 2013
The traditional route from Paddington station to Euston station would be by Circle/H&C to Euston Square. I've noticed that journey planners sometimes prefer Elizabeth to Tottenham Court Road and then Northern.
I could believe that if you are already on an Elizabeth train going into Paddington, that staying on until TCR is sensible. Equally if intending to head out of Paddington on an Elizabeth. But what if it's a regular main line service at Paddington? It can seem a long walk from Euston to Euston Square, but the underground passages at TCR and Euston aren't short either.
My regular service at Paddington would be the 387 semi-fast, so that's likely to be platform 12 or 14.
Sir Felix Pole
21 Oct 2012
Wilmslow
One disadvatage of the Circle eastbound is that you have to change at Edgware Rd. - although it is any easy x-platform one. The H & C platforms at Paddington can be a bit of a traipse depending on where your main line train is and where your seat is.
The Euston Road can be a pain with luggage too, threading through the crowds - although you can take the back way via Drummond St.
I've not tried the new interchange at Tottenham Ct. Rd. - I'll give it a go next time!
Jamesrob637
12 Aug 2016
I did this last Friday. Out to Euston Square and westbound Circle Line. I actually alighted at Edgware Road because that was fractionally closer to my intended destination (the new Wetherspoon on the wharf bit just outside Paddington station)
vuzzeho
11 Apr 2022
Bakerloo to Oxford Circus then Victoria to Euston? I don't know Paddington too well. If you're feeling wacky, Bakerloo to Queen's Park then Lioness to Euston NR. But that's a bit out there.
A lot of the underground passageways are one way only, and set up to avoid people meeting at cross passage junctions, so often signed to go long way round.
If you know layouts of stations there is often shortcuts, some of them just few metres long which connect to an old shorter (but no longer signposted) route. TCR also has some part built passageways (provision was made for Crossrail 2) which would open up further alternatives if they were finished.
Yes, but need to use the stairs at opposite ends to escalators, which lead to a sort of footbridge arrangement linking the northbound and southbound platforms, not go via ticket hall.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
My method for that route is cross-platform change at Oxford Circus for southbound Victoria Line to Green Park then cross-platform there for northbound Victoria to Euston. Given the frequency of the Victoria Line service this can be quicker, and is certainly easier, than the directional change at Oxford Circus.
Wolfie
17 Aug 2010
Bakerloo line to Oxford Circus then Victoria line to Euston is also a viable option which l have seen some journey planners offer.
Wolfie
17 Aug 2010
Saw this after l posted - good tip, sir.
MarlowDonkey
4 Apr 2013
Agreed there, the change between southbound & northbound platforms at Oxford Circus can be a bit of a hike, especially when it's busy
Green Park can be an immense hike between the intersecting lines, but perhaps not between southbound and northbound Victoria.
Mcr Warrior
8 Jan 2009
The Victoria Line at Green Park is essentially an island platform with cross passages between the two sides; A very simple change!
Changing at Green Park for a Paddington to Euston journey seems to be a somewhat circuitous route. :s
Thames99
11 Sep 2023
Reading
From platforms 12 or 14 there are steps up to the bridge and you are then very close to the H&C platforms at Paddington. You would be best to be in about the 5th coach of a 387 I would think. This would also be in roughly the correct area if you came in on a different platform. It is a fairly short walk from Euston Square.
In the current weather I would definitely go for an aircon train. The Victoria line and other deep level tubes are not fun at the best of times ...
Mike99
4 Mar 2011
G E M L
Got to be one of best tips ever given on here, I've walked from Bakerloo southbound to Victoria Line northbound and I felt like giving up. Well done, thank you
VT 390
7 Dec 2018
When making a connection from Paddington to Euston I always do Bakerloo and Victoria lines changing at Oxford Circus this is almost always quicker than the Circle/Hammersmith & City line if you board the correct carriage for the change at Oxford Circus in either direction. The Walk platform to platform at Oxford Circus usually only takes around 1 minute, although it does involve steps.
Falcon1200
14 Jun 2021
It does, but avoids the walk from Euston Square (subject to unpleasant weather) and is faster than the bus, especially since TfL diverted the once-useful 205 away from Paddington (although if not in a hurry I do still use the bus, changing en route between the 27 and 18 or 205).
Mike99
4 Mar 2011
G E M L
Which would be correct carriage on the Southbound Bakerloo line transferring to the Victoria line Northbound?
VT 390
7 Dec 2018
In this direction I recommend either the front door of carriage 7 or the rear door of carriage 6, towards the back of the train in direction of travel (Bakerloo line trains have 7 carriages).
CW2
7 May 2020
Crewe
Over several years of rush hour commuting Paddington to Euston and vice versa, I concluded that the least stressful travel mode was the bus. I would only venture into the Underground if time was short.
Mike99
4 Mar 2011
G E M L
Thanks I've got to do exactly that move late at night shortly so that's good info. I was weighing up the tip earlier in this thread about nipping down to Green Park and returning Northbound, anything to save that long walk. I'm not badly disabled but I do walk quite slowly with a stick, so this info is helpful, thanks again.
Mike99
4 Mar 2011
G E M L
I agree, when the 205 stopped on Praed Street and when into Euston Bus Station it was pretty good all things considered.
Harpo
21 Aug 2024
Newport
Buses in central London are fabulous for convenience. If time is not an issue.
sh24
28 Sep 2023
Also if you don't mind being in a mobile sauna at this time of year. Borderline unusable for me right now.
vuzzeho
11 Apr 2022
Some routes have really nice new Chinese buses with AC. I don't think the 205 does, but I'm far more into trains than I am buses so I'm not the best source.
