Oyster PAYG query
GodAtum
11 Dec 2009
I had £5.70 on my card. I went to East Croydon - Victoria and back on saturday. Now I only have £0.50! Is this right as on the website it should only be £3.40.
OwlMan
25 Jun 2008
A National Rail zones 1-5 single is £2-60
total for return is £5-20.
I do not know where you got £3-40 from.
Peter
GodAtum
11 Dec 2009
Sorry i forgot to mention I have a YP railcard so a single fare is £1.70.
Any Permitted
16 May 2010
Southampton
In that case it looks like it didn't register your railcard. Ring up the helpline and ask them if it's registered properly.
Mojo
7 Aug 2005
You do not get Railcard discounts on Oyster single fares; they only apply for price capping.
MikeWh
15 Jun 2010
Crayford
You do for NR journeys. It's only bus/tram and wholly tube/dlr fares that aren't discounted. But as you say, the price cap is discounted as well so you'll get there quicker with tube/dlr.
GodAtum
11 Dec 2009
I rung the helpline up and they said my YP card was not registered so I need to go to a tube station to register it! I've already done that once at an Oyster outlet which is annoying!
RJ
25 Jun 2005
Back office
They give 1/3rd off the Oyster PAYG off peak fare for journeys not involving London Transport.
MikeWh
15 Jun 2010
Crayford
Not quite. They give 1/3 off journeys involving National Rail, including Overground.
Tyke Toper
20 Jan 2009
West Riding
Not quite (2).
"Pay as you go on National Rail before 2010.
On the following routes Tube, DLR and London Overground Oyster single fares will be charged"
- those NR lines Oysterised before 02.01.10 and except the bit used as test on Southern in/out of Victoria just prior to 02.01.10.
Don't we all like these simple fares systems?
MikeWh
15 Jun 2010
Crayford
Not quite (2).
Just checked the single fare finder. West Drayton to Paddington is an example of an oysterised before 2010 and the discount applies to off-peak fares. New Cross Gate to West Croydon is now Overground and the discount still applies to off-peak fares.
RJ
25 Jun 2005
Back office
For hybrid journeys like Rectory Road to Oxford Circus, there is no Railcard discount even though it involves NR, which is why I said there is no discount for journeys involving LT. You certainly wouldn't get a discount with a paper ticket + Railcard.
London Overground is a special case - it is TfL run so part of LT but also part of ATOC (National Rail). Depending on the journey, you may or may not get a Railcard discount when using Oyster. I.e for Gunnersbury - West Brompton, I expect you'd only get a discount if you use the pink reader at Willesden Junction.
I did bring up the New Cross Gate - West Croydon/Crystal Palace thing in another thread. My ZIP card which gives me child fares on LT routes does give that discount on that route. My YP Oyster also gives me the discounted fare. This is because LO is part of both TfL and National Rail.
Looking in the opposite situation, TfL pricing continues to apply on certain non LT services when using Oyster - the NR routes Oysterised prior to 02/01/10 although I need to double check Victoria - Balham. Just like with London Overground, you get Railcard discounts also.
I think the general rule is routes where you'd get a Railcard discount on paper tickets, you will also get on Oyster.
13 Jun 2009
The WDT-PAD example is indeed a little odd since before 2010 the fares were in line with LU fares. Since the introduction of PAYG oyster on NR the fares were frozen in line with LU fares, whereas a journey from LST (underground) to ECR (National Rail) falls under the new fares regime which charges a premium for services that are NR-only or NR+LU.
So WDT-PAD for example comes out at £4.20 or £2.40, (the same fare as Heathrow (LU) to Holborn (LU)).
However a journey from Liverpool Street (LU) to East Croydon (NR) will be charged at the new NR+LU fare (£5.00 or £3.70).
Interestingly out of the two examples above, both will have a NR discount applied, but not if the WDT-PAD journey was extended to say, Holborn.
Incidently a journey from Liverpool Street to East Crodyon might just as easily be completed via ELL from Shoreditch High Street, in which case the fares would be £3.90 and £2.60 peak/off peak respectively, and the £2.60 will have a railcard discount applied to it.
Well, thanks to the legacy Oyster PAYG implementation on FGW services this is turning out to be as clear as mud isn't it? :)
TSM
