Oyster or KeyGO
sonic2009
19 Jan 2010
Crewe
If not wanting to purchase Oyster as i believe its now £7 for the card - can you use KeyGO to get a travelcard loaded onto the card with a railcard discount (DSB)?
It's ages since i've had a railcard almost 2 years and things have changed from what i understand.
Or is it best to just stick and buy a paper travelcard?
MrJeeves
28 Aug 2015
Burgess Hill
You don't need keyGo, just a normal Key smartcard.
You should be able to buy a London Travelcard from a Thameslink, Southern, Gatwick Express or Great Northern ticket machine for the Key, but only Off-peak and Anytime travelcards (not Super Off-peak), including with your railcard.
keyGo isn't a replacement for Oyster, as you can only use it on GTR services (and GWR between Redhill and Dorking Deepdene).
Haywain
3 Feb 2013
And on GWR between Warblington and Brighton. It's worth adding that in some cases KeyGo produces cheaper fares on GTR services than other methods, particularly for railcard holders, as it will discount contactless fares.
sonic2009
19 Jan 2010
Crewe
So i can't use it on any train within the London Zones?
Haywain
3 Feb 2013
But they don't run that route anymore, hence it's not valid (only Redhill to Dorking is mentioned in the FAQs).
It's mentioned on the map though, which is what I was going by. So it is valid, there just aren't any trains.
You can use it (KeyGo) within the zones for PAYG but only on trains operated by GTR. KeyGo is loaded onto a Key card which can have a Travelcard loaded onto it.
MrJeeves
28 Aug 2015
Burgess Hill
Yes, and I could use my Z1-6 Travelcard on Transport for Wales services within Zones 1-6, but there's an important distinction between providing completely accurate and predominantly useful info.
Alex365Dash
2 Jul 2019
Sussex
The keyGo Conditions of Use now only permit use of GWR between Dorking Deepdene and Redhill - the conditions were updated after GWR services from Brighton were withdrawn.
Haywain
3 Feb 2013
Does it actually matter?
Haywain
3 Feb 2013
I was just making a silly backhand comment as an example for if TfW theoretically ran to London Z1-6.
Where does that fit in with "there's an important distinction between providing completely accurate and predominantly useful info"?
MrJeeves
28 Aug 2015
Burgess Hill
An example of accurate but not useful info that is more likely to cause confusion than anything else.
