generally booked for one or the other, unless theres a failure. there is a H symbol at the top of the column where there is an hst operated service.
Excepting one on a Sunday which is booked as a Turbo.Quite right! If its a Hereford, it will be a hst![]()
There are no guarantees with the rest of the services either. PAD-OXF or PAD-Cotswold Line HSTs are the first to be substituted for Turbos if the HST is needed elsewhere during disruption or because of failures.
Timetable is here:
http://firstgreatwestern.co.uk/Documents/Custom/TTs Dec '10/GW10D_TT16_WEB_(1).pdf
Basically nearly all of the peak fasts are HSTs, most of the off-peak ones aren't.
Thanks for the link, oh and is the catheadrals express the service to Hereford.
Are the Oxford fast Turbos DOO with no guard on board? My 11:50 to Oxford yesterday was thankfully a HST (with very reasonable £5 Weekend First upgrades available on board) but the 13:30 back to Paddington was a Turbo, although it did arrive slightly early at 14:27 and no ticket check on board.
