Hi,
Does it matter if the electrification is 3rd rail or overhead AC?
All the services currently using the area are modern(ish) EMU's or DEMU's.
The EMUs are (technically) already able to use either source of power. (OK, I know the 444's and 450's don't have panto's but they would never need them on thieir current destinations)
The DEMUs (Voyagers) are currently flirting with DfT offering to provide pantograph cars. Modern modular power electronics will be used and it is very simple to add 3rd rail pickup (Bombadier already have the technology from the Electrostar family)
The cost of re-doing the electrification infrastructure will surely outweigh the costs of specifying dual mode power on any new build or newly allocated stock?
Cheers,
Jason
The 442s cant use both, but thats because they are the last of the Mark 1 EMUs for all intents and purposes.
You can't add the current third rail pickup to the Voyager family of trains as the "lightweight" bogies have nowhere you can attach the shoebeam to at the current time, you would probably require an expensive development programme.
But I agree, electrification is electrification whether it is AC or DC, money spent on ripping up perfectly functional third rail to replace it with OHLE would be better spent putting up OHLE/Third rail somewhere else.
It also increases resentment of the south amongst the people who have to squeeze into ancient diesel trains that wll apparently at this rate last until the national retirement age.
