ryan125hst
New rolling stock has been rolled out in many areas in recent years. New trains often have distributed traction with greater horsepower than the trains they replaced. When you combine this with more electric trains being introduced and, on some routes, the introduction of air conditioning when trains that previous operated the route only had opening windows, and the electrical load will clearly have increased.
Taking my local station of Retford as an example, instead of a mixture of diesel powered HST's and electric Intercity 225's, we now have electric and bi-mode Azumas meaning, if all is well, all of LNER's trains will pass through using electric power. Hull Trains now also use bi-mode trains, and Lumo have commenced service too, also using electric traction. It has made me wonder, as an Electrical and Electronic Engineer, what the capacity of each OLE section is on the ECML and indeed elsewhere in the UK. While it will be engineered for typical timetables (presumably as designed in the 1980's, although I believe power supply upgrades have been carried out across much of the ECML in recent years), what happens during disruption when multiple trains stop and then start to accelerate shortly after one another?
Looking at the Sectional Appendix, the overhead line section through Retford starts just north of the station, and the next Overhead Neutral Section (OHNS) is at South Muskham, about 3 miles north of Newark North Gate, around 16 miles of double track in one section in total.
So let's say there is disruption and there is a 10 car Azuma on platform 1 and another on platform 2 (using 10 cars in my example due to three motor vehicles per set, six per 10 car train). Then another Azuma stops on the up fast line to allow the late running service on platform 1 out, and a Hull Trains unit stops in the section behind it awaiting platform 1. If the train on platform 1 sets off and the section becomes clear, the Azuma on the fast line can now set off, meanwhile the Hull Train can now enter the now available platform 1. If the Azuma on platform 2 sets off just as these three trains are setting off, then before it reaches just north of Retford and thus the next overhead section, we will have four trains accelerating at once. In addition to this, there could be other trains heading north also drawing power. This is just a theoretical example but having seen trains bunch up one behind the other, and be sent to the platforms at Retford during disruption, this scenario is possible.
With all this in mind, what is each overhead line section capable of supplying, in Megawatts? Is it fairly standard for each section, or does it vary across the country? Looking at the Sectional Appendix it seems they are a lot closer together south of Peterborough, which suggests the limits of what can be supplied can be reached and therefore more sections are required to satisfy the power demand.
What is the limiting factor of the OLE power? Is it the substation and therefore substation upgrades allow greater capacity to the section. Or can the maximum current of the OLE by reached quite easily in busy areas, meaning the only way to increase capacity is to split it into a greater number of sections?
