bakerstreet
At the launch of the Oval phase 1, I noticed a ‘feature’ when using paper tickets that – in order to complete my journey from north west London to, for example, Staines - I have to leave a good 1hr 20 minutes before the PM peak period begins, because of 2 changes of trains on route.
Frustrating.
Worse, if any of three TOC timetables were to be recast, this could change the peak period for said journey.
With Oval phase 2 the same situation applies but effects become more widespread.
The premise is the same - paper tickets are charged the same as using contactless.
Off Peak restrictions are harmonised (other than before 06:30 on weekdays), so far so good.
BUT … Consider a journey like Chelmsford to Reading.
If you use contactless you can catch the 15.55 departure from CHM and travel on any train out of PAD and pay an off-peak fare.
Use a paper ticket (perhaps because you want to use a railcard) the last departure you can catch is the 14:25 from CHM because it is not valid on trains timed to depart between 16:00 and 19:00 and you’re picking the last valid train at PAD leaving at 1548.
This is a significant difference on something that's supposed to be the same.
It's even worse when you consider that currently CHM to RDG is restriction C4 -where you can use it in the afternoon peak, so long as you’re not catching GWR services from PAD.
Since when did the evening peak last over 4.5 hours?
There'll be lots of other examples where people will be in for a shock in a couple of weeks when the fares change.
With many restrictions, a change of trains during a journey would be immaterial. Surely it should be the same in this case. Would this be so difficult to apply?
I really thought they might’ve fixed this for phase 2.
Frustrating.
Not valid on trains timed to depart after 04:29 which arrive at, or depart from; any London Terminal, Farringdon, or Kensington Olympia before 10:00
Not valid on trains timed to depart after 16:00 from London Paddington on Great Western Railway services until 19:01
