Openbve
If it's like the old BVE, you put them into the folders in your BVE folder, which is likely to be found on the C drive under Program Files. Many routes & trains will automatically extract into the right place so you may not need to manually copy files.
devon_metro
11 Oct 2005
openBVE files are all compilled into .zip files, so you do indeed have to manually put them into a folder, however the whereabouts of this folder is absolutely irrelevant to the functioning of openBVE.
