OPAS - the fall-out from Northwich incident
S N Barnes
20 Jan 2011
With another engineer based in Surrey, I was already on the trail of OPAS failures to deliver a reliable and accurate review of structures condition across stations & other fixed assets on the rail estate
His local station as timber platforms (100% structure & deck) built c.1950 with extensions for 3 coach & now 4-coach trains 'stitched' on to the old platform, more make it up as we go, than a sensible plan of building a new pair of platforms with step-free access & a direct link for the 30% of users who walk the 500m & climb a 6 metre flight of steps from the station on another line, operated by another TOC. Extending the old platforms is a fudge, as this means the work does not create a new station, and thus the current non-compliant arrangment of a station on top of an embankment with only 1 access to each platform could remain
The steel staircases replaced a timber one with a barrow crossing in 1984, with a projected 25 year life (do the sums?). OPAS inspections over the past 15 years had instructed clean off corrosion, treat, and paint, which had never been done, nor subject to audit scrutiny. The result steel plates & sections now beyond treatment, with rust lamination, and daylight seen through holes patchd up (badly) with timber. When new waiting shelters were ordered & platform stripped back, major rot was revealed, delaying the work...and of course, only patch repairs!
There are around 87 stations on UK network with timber in all or part of platforms, some in a dire state from what I've seen, and no group standard for timber platforms? (Godley pictured) Do DM me what you see.
Post Northwich its now gone rather quiet from ORR & RAIB, and I'm wondering if the sheer scale of close-to collapse structures is similar to the void revealed post Hatfield, and also has parallels with the Staines Moor Lane LC fatality in 2008, where a crossing reported as unsafe & slippery by HMRI in 1996, was 'lost' as a job to clear for 12 years, until someone died because it was not done. Subsequent to the RAIB report there was a flurry of dealing with slippery timber crossings yet 9 years later, checking out 3 Horseshoes No 3 where cyclists regulalry get felled and a motorcyclist died - there was still untreated, slippery, timber on the footway strips
Astro_Orbiter
8 Nov 2019
What's OPAS, and what is this about?
Is this in relation to a previous thread? What happened at northwich? What's going on?
Clarence Yard
18 Dec 2014
There’s definitely some very poor structures out there and NR are woefully behind on their maintenance/rectification work.
A point about the RAIB - they only investigate accidents, determine the cause and recommend actions, they don’t do follow up inspections - the ORR is the safety body who should be getting to grips with this issue.
snowball
4 Mar 2013
what's OPAS, and what is this about? Is this in relation to a previous thread? What happened at northwich? What's going on?
I too was about to ask what OPAS is. A Google search reveals lots of meanings for OPAS, none of which seem relevant.
However I do know that a roof collapsed at Northwich station, thread here:
LOL The Irony
29 Jul 2017
Chinatown, New York
Just go a bit further up the line to Knutsford and the problems are evident there. Several bars that support the banister and stop you falling out of it are severely corroded or completely rusted through in places. The road bridge that carries the main road from to Macclesfield has a tree growing out of it, meaning collapse would close a very busy stretch of road and rail for weeks, probably months. And this is just 1 station, how many more are in a worse state?
Yes, see https://www.railforums.co.uk/threads/northwich-station-roof-collapse-18-05-2021.217538/
The roof of the station over the ticket office collapsed after the door to the platform closed, nearly crushing the woman who had just exited it and taking part of the canopy with it.
PupCuff
27 Feb 2020
Where these issues relate to stations they should be being picked up by the station operator as part of planned general inspections. Whilst they are unlikely to be comprehensive enough to detect failures within the structure of a building (unless any cracks/bulging etc was noted externally) they should be picking up and highlighting issues as above like platform surface issues and problems with the stability of stair handrails and these then flagged for repair.
S N Barnes
20 Jan 2011
RAIB has already announced that they are looking at this incident (along with ORR) which closed the station and railway as around 5-6 Tons of masonry fell through the canopy on to an open platform, and also on to the railway tracks. We were lucky no deaths or injuries happened, as no train was calling at the time.
RAIB do full investigations and also issue USA (Urgent Safety Alerts) when incidents do not warrant the resources of a full report, or - as in 2008 Croydon Tram Crash provide a better & published record than that delivered by HSE/Croydon Council (Section39 RTAct 1988), or the Coroner's Inquest delivered (& it was required!) Chillingly the fatality in 2008 arose because the bus passenger was ejected through the side window which was toughened rather than laminated glass, a cause of many of the 2016 deaths was being ejected through the toughened glass side windows that shattered & fell away
4069
8 Aug 2016
RAIB is aware of the Northwich incident, but has not announced any investigation, and is not doing one.
USA (Urgent Safety Advice) is issued during an investigation, not instead of one. Safety Digests, formerly called Bulletins (such as the one referred to covering the Croydon tram/bus accident) are issued when a full investigation is not appropriate.
Parham Wood
13 Jun 2011
I would have expected OPAS to keep a record of work required following inspections and to follow this up if not reported done in the appropriate timeframe. However I do not understand their remit.
