ON/OFF Indicators
Matt Taylor
31 Aug 2008
Portsmouth
On a recent trip to Norfolk I was a little bemused to see an 'ON' indicator, are these common in some areas as I have not seen anything other than 'OFF' indicators before, and to be honest it seems like a good start along the route to a SPAD.
http://www.flickr.com/photos/40172673@N03/9862294514/in/set-72157635468186016
This was at Great Yarmouth, there was one on each platform with both associated starter (semaphore) signals at danger.
30 Aug 2011
Manchester
You picture shows the ON indication as having a red background? Did the off indicator show in a green colour?
TheEdge
29 Nov 2012
Norwich
No. Its just the age/colour of the bulb.
Platforms 2, 3 and 4 at Yarmouth all have one all of which display ON and OFF. That looks like it might be the one on platform 4 which looks a different colour, lesser used platform so older bulb probably. The one on 2 is white.
Not seen another one around, although these are the only ones attached to a semaphore.
Railsigns
15 Feb 2010
There are "On"/"Off" indicators at stations on the Met. This one (which looks more modern than most of the others) is at Amersham:
Railsigns
15 Feb 2010
ON indicators (which used to be common throughout Britain)
Were they? The evidence I've gathered seems to point to both "On" and "Off" indicators being pretty much confined to the Southern Railway / Southern Region until early BR years. For instance, the resignalling at York in 1951 had included equivalent indicators in the form of a green light, normally unlit, as was formerly used by the LNER and LMS. The 1952 resignalling of London Euston included stencil "Off" indicators, one of the earliest mentions I've seen outside of the Southern Region.
