Olton Booked Freight Trains
james66414
Is They Any Booked Freight Passing Through Olton im going on thursday 18th any info please thanks
Freightmaster
Verified Rep
7 Jul 2009
Is They Any Booked Freight Passing Through Olton im going on thursday 18th?
Olton near Tyseley, Birmingham?
Yes - there are a number of booked freight services on that route on
a Thursday; if you indicate your expected arrival and departure times,
I would be happy to provide details.
MARK
james66414
MARK
olton near tyseley
GazzaB24
30 Apr 2011
QUOTE=james66414;769887]Is They Any Booked Freight Passing Through Olton im going on thursday 18th any info please thanks[/QUOTE]
I commute on the Moor Street - Leamington line and know of the following regular workings:
EWS 66 South Modal thru Widney Manor around 07.55 so probably through Olton around 07.50 ish*(works M-S)
FLT 66 South Liner thru Widney Manor around 08.20 so Olton at 08.15 ish
(works M-S) this has been a 70 three times this week but don't rely on this.
EWS 66 northbound cars around 19.00 at Widney Manor (M-F)
On Saturdays there is a southbound FLT 66 on liners roughly on each hour at Solihull from 09.00 to 12.00 but some run as required.
I'm at work in between those times so can't let you have anymore details. The vast majority of these also go through washwood Heath and water orton too. Also, don't take the above times as gospel they are correct give or take 10 mins either side depending on traffic on the line. If busy, southbound freights normally wait between small Heath and Tyseley for a path south, or occasionally the loop just before Dorridge.
Hope that helps,
Gary
james66414
Hope that helps,
Gary[/QUOTE]
wht time does the ews northbound car train go through olton at?
MARK
i live 10 miles away from olton propley i might arrive at 11:45 or 12:00
Freightmaster
Verified Rep
7 Jul 2009
Trains at Olton from 11.45 am to 8pm on Thursday August 18th
Code:
North South H'code      Train                      Traction  Type of train
12:10   -    4M55   Southampton-Lawley Street     F.Liner 66  Freightliner
13:30   -    4M28   Southampton-Ditton            F.Liner 66  Freightliner
14:30   -    4M66   Southampton-Birch Coppice         EWS 66  Intermodal
  -   14:45  4O09   Trafford Park-Southampton     F.Liner 66  Freightliner
15:30   -    6M22   Westbury VQ-Stud Farm         F.Liner 66  empty ballast
  -   16:05  6X01   Scunthorpe-Eastleigh              EWS 66  loaded rails
  -   17:05  4O55   Leeds-Southampton             F.Liner 66  Freightliner
18:00   -    6Z85   South Ruislip-Bescot              EWS 66  engineers
MARK
james66414
Code:
MARK
hi mate thanks for the info by the way is they a car train running tonight?
james66414
Hope that helps,
Gary[/QUOTE]
is the saturday freightliners go towards sutton park and what time
