Extra points for having Balloons going around the balloons, surely!Is it cheating to say Blackpool since those ones are still in use?
Is this what you had in mind (from NLS)?I believe Roundhay Park in Leeds was a classic - but having failed to find it on any old maps maybe I am thinking of a trolleybus turning circle. https://www.reddit.com/r/TransitDia..._1929_map_modernised_and_colourised/#lightbox does show route 11 terminating in the right place though...
Maybe the trams just reversed at a crossover and the circle had to be put in for the buses?
Saw a sort of Y junction in Katowice at the end of the 24 route.As well as balloon loops, some urban operators ran (and still run) through a sequence of streets to get turned around. Others employed triangles, not necessarily needing someone to assist the reversal part as the single-ended cars might have simple shunting controls at the opposite end which the driver could go back to.
Double ended cars have a range of downsides, from waste of passenger space with entrances on both sides, only one being used in any journey, to the expense and complexity of providing two cabs and two sets of controls.
True, but they do give flexibility to have platforms either to the side or between the tracks - particularly important for new tramways where it may be difficult to make space for side platforms in existing built-up areas. A few networks with single-ended cars that go into tunnel sections with centre platforms have to swap the tracks over via a diamond at each end.Double ended cars have a range of downsides, from waste of passenger space with entrances on both sides, only one being used in any journey, to the expense and complexity of providing two cabs and two sets of controls.
That (which a number of systems do) is a very low cost solution in comparison, and no difficulty for a tramway at all. However centre platforms have tended to fall out of favour for new works due to difficulties with making them fully accessible, which can cause the tram tracks to have to be splayed out more than previously necessary, with additional land purchase costs.True, but they do give flexibility to have platforms either to the side or between the tracks - particularly important for new tramways where it may be difficult to make space for side platforms in existing built-up areas. A few networks with single-ended cars that go into tunnel sections with centre platforms have to swap the tracks over via a diamond at each end.
Swapping the tracks to left hand running (which would be right hand if done in the UK) is impossible if sharing roadspace with other traffic, and may be considered too hazardous if pedestrians cross the track, when they may be instinctively assuming the trams follow the normal rule of the road. Looking at Metrolink Phase 3 for example, you will find a mixture of centre and side platform stops - and inserting a balloon loop would have been extremely difficult at most of the termini not to mention intermediate turnback stations.That (which a number of systems do) is a very low cost solution in comparison, and no difficulty for a tramway at all. However centre platforms have tended to fall out of favour for new works due to difficulties with making them fully accessible, which can cause the tram tracks to have to be splayed out more than previously necessary, with additional land purchase costs.
Here (from NLS) is that one in 1942. In 1914 the two tracks just ended here with no loop.In Sunderland, the Seaburn terminus was so busy during the summer that a loop was added there to increase the throughput of trams. You can see on the map as Whitburn Road from the south approaches what is now marked as the "Seaburn Fountain Roundabout" how the road was widened to accommodate it. A very ornate tram shelter was also built there for passengers waiting to return to the Town and beyond to the south east of the roundabout which still exists (marked on the map as Blacks Corner Tram Shelter) and is now a coffee shop.
That's another one. It falls right on map boundaries, and the best I can do from NLS's collection is 1937 for the top bit and 1925 for the bottom:Was there a balloon loop at the end of the Birmingham City Corporation route out to Rednal and the Lickey Hills? I never knew it in the tram era but I think there was a circular turning point for buses at the terminus?
Indeed, research with Streetview shows what looks like preserved tram tracks still embedded and running parallel to what is now Elliot Gardens, Rednal, behind the Chinese Restaurant there ........
Zvonařka on the SE edge of central Prague also uses a triangle, although it doesn't use gravity. It is currently the 'city' terminus of route 23 which supplements the 22 up past Prague castle and uses the oldest, unmodified single-ended Tatra T3 trams.Saw a sort of Y junction in Katowice at the end of the 24 route.
The tram would go up the hill to the right then go backwards under gravity round the curve to face the other way. All on roads.
Haven't seen one like that anywhere else.
Talking of which, there's an information board there nowWas there a balloon loop at the end of the Birmingham City Corporation route out to Rednal and the Lickey Hills? I never knew it in the tram era but I think there was a circular turning point for buses at the terminus?
A new information board depicting the history of trams to the Lickey Hills has been unveiled in Rednal this afternoon (Saturday 27th April).
Researched by members of the Lickey Hills Society, the board is situated just behind the Lai Ling Cantonese Restaurant in Lickey Road.
The building is all that remains of the Rednal terminus, which was the gateway to the Lickey Hills Country Park for tens of thousands of city dwellers during the industrial revolution. A section of tram track still remains, set into cobbles behind the building.
The board was funded thanks to a generous grant from the Midland Adult School Union and designed by Keith and Simon Woolford.
On one side of the board, “A Tram to the Lickeys” panel tells of the part played by the trams in the growth of Rednal since the first tram arrived at the iconic Rednal terminus 100 years ago in 1924.
On the other side, the “Rednal Village” panel shows how, in the early part of the 20th Century, the arrival of the trams led to the village becoming a tourist centre.
The Lickey Hills Society thanked the Elliott Gardens management team for permission to use their land for the board.
To find out more about the work of the Lickey Hills Society, visit their website.
Was this solution used for GB trolleybuses anywhere (yes there are examples outside GB).
I much prefer finding a balloon loop at the end of the line. Often accompanied by greenery and a small cafe. Will often have sidings with other trams waiting.Double ended cars have a range of downsides, from waste of passenger space with entrances on both sides, only one being used in any journey, to the expense and complexity of providing two cabs and two sets of controls.
Indeed. One of my favourite trips in the USA is to take the N-Judah car in San Francisco, out to the end of the line. There's a balloon loop, AND a pleasant cafe. Plus a huge beach and the Pacific Ocean just across the road. What could be better ...? Here:I much prefer finding a balloon loop at the end of the line. Often accompanied by greenery and a small cafe. Will often have sidings with other trams waiting.
Straight in and out termini are almost invariably soulless affairs.
City centres would often have a street circuit where route could terminate, or one service be turned short. Sheffield had several, all double track, though in most cases not all radial lines could be bypassed on the loop. The one that called at Exchange Street could return trams towards Rotherham.There was a batch of single ended trams in Rotherham (photo on Flickr, again not mine here) - I don't know if their termini had loops or a triangular junction to allow a three point turn. They must have been a bit of an embarrassment if there was ever a need to turn them short of their regular destination...
Rednal was served by route 70 which opened in 1924, with the loop being added the following year. It was closed with the rest of the Bristol Road routes in July 1952.Was there a balloon loop at the end of the Birmingham City Corporation route out to Rednal and the Lickey Hills? I never knew it in the tram era but I think there was a circular turning point for buses at the terminus?
Ta.There was a trolleybus turntable at Longwood, Huddersfield (which has its own wikipedia article here) - for what wikipedia is worth, it says there were only 4 trolleybus turntables in the world, two in the UK.
Most London trolleybus depots were converted from tram depots with minimal structural changes, and I understand that at least some of those with traversers had a turntable installed on the traverser so that trolleybuses could be driven in and be turned round. Photo of Poplar depot traverser on Flickr (not mine) here.
I'm not aware of anything like it for trams in the UK (or, to the limits of my knowledge) elsewhere. Almost all UK trams were built double ended, and trailer car operation was a rarity, so a loop terminus would have been a convenience rather than essential. (Having said that, the LCC used trailers on routes that involved a traditional terminus, where the electric car either had to run round its trailer, or leave its trailer for the next tram, at least at one end of the route.)
