Old HD wheel flanges and peco track
HDmike-68
6 Nov 2013
Hi..I wonder if anybody can help..I have some old HD 3 rail locos and want to change to two rail track...would the old wheel flanges fit...peco straight track ok and the points..or do i have to buy old HD 2 rail points....i realise have to change too old two rail loco chassis ....
Monty
12 Jun 2012
Strictly speaking the flanges on Hornby 'Dublo' rolling stock were finer than on the contemporary Tri-ang models. They may work through Peco's code 100 track but I'd definitely not consider using code 75, you may have to rewheel some of it anyway as a lot of the old Hornby 'Dublo' 3 rail range had metal wheelsets on metal axles that were not isolated so you would short out your layout if attempted to use those items in an unmodified form.
Hope that helps. :)
DXMachina
24 Oct 2011
2-rail and 3-rail Dublo runs perfectly on Peco Code 100. Done both - the latter with an added power rail
HDmike-68
6 Nov 2013
Thanks guys..the peco 100 i have tried the straight track and the clearance over the top of the chairs is ok.....but what about peco points...i will be using surriagate 2 rail chassis on the old 3 rail bodies......Mike
DXMachina
24 Oct 2011
Also works fine. HD2R is finer-scale than 1980s Lima !. Code 100 points are no problem but Code 75 is right out
