221129
Then what is it? Charter train, private train, special train?
It's a charter.
Wonder what the power cars will be??
The last HST to Okehampton was Tuesday 21st Feb 2017. Albeit an ECS and not in passenger use.
Was this a proving run or some such?
Here are the runs - hopefully the actual service doesn't get quite so held up!
5Z77 1133 Exeter St Davids to Okehampton
5Z78 1340 Okehampton to Exeter St Davids
A historic train journey had to be abandoned minutes after setting off when the train slipped from the rails.
Shortly after leaving Okehampton the 500 passengers were transferred to a different train at Exeter....
...GWR which owns the train said the damage was caused by 'poor railhead conditions'.
The OkeRAIL Forum says it has been reassured that the return journey from London Paddington direct to Okehampton will still go ahead.
THE much-anticipated direct train from Okehampton to London — the first in 50 years — hit a stumbling block this morning as the engine slid down a bank on its way out of Okehampton, damaging the wheels and deeming it unsuitable for the rest of the journey.
The wet weather overnight and this morning had caused the tracks to be slippery and as the train, organised by OkeRail, left Okehampton Station this morning just before 8am, it slipped on its tracks causing ‘flats on the wheels’ — where the wheel wears away and causes flat areas. An engineer confirmed the damage was too much to continue and the train was directed to Exeter, St David’s where another train was waiting for passengers to continue their journey.]
The green set (43188/194) was faulty and taken off at Exeter St David's to be replaced by 43143 / 020.
That sort of information isn't in the open data feed used by sites such as Open Train Times (OTT) or Real Time Trains (RTT).Thanks -RTT doesn't shew that.![]()
By the way your quote tag is broken in post #44...
As you've gathered, set swap at Exeter after developing bad flats on 43194. The new set was taken off 1A15, and had a micro buffet.
Yes, after I chased my moved post around UKRail, I caught up with it here and then went through RTT to see how many 'normal' pax were inconvenienced. In fact the scheduling people did very well. The cancelled Paignton goes via Bristol and I was able to see they put on an extra at Bristol, which ran to time. The stations between Exeter and Taunton were catered for by the following ex-Plymouth (also picking up the ones from a local from Paignton to Exmouth) so only pax at Weston could have been left. They could have got a local to Parkway and picked up the Carmarthen,and indeed, it looks as thoough it was held for them specially.
Well done GWR!
Just saw the special take a left and head towards Crediton. Hope things go a bit better this evening. Does anyone know where the main trouble spots were?
I always imagined that the grades would be more favourable departing Okehampton in the direction of Coleford junction and onwards towards Crediton so I too would be interested to learn.
Update: I see that the return trip got away at 1805. I wonder if they had time to sort out the Pullman catering? Hope so, as it was bad luck what happened. A lesson learned on the track upkeep on the Okehampton stretch, I imagine.
The Okehampton branch is used for skid pan training with a healthy dose of washing up liquid, is it not? Maybe no-one thought to give a good clean before he trains ran?
The return went better anyway - arrived at Okehampton 4L
