OHLE down at Wolverton (again?)
oversteer
26 Jan 2011
Wires down on the fast lines, apparently a VT service less one pantograph, so VT running via Northampton, and resulting issues with all VT and LM services..
Some very delayed southbound services ! The 0605 from Liverpool just got in to Euston, 116 minutes late.
Anyone know if these services would be pick up only or could I use them on an any permitted ticket ?
@LondonMidland: "#Wolverton update 13: to help get you on your way, @virgintrains from Eus at xx.00, xx.07, xx.23, xx.30, xx.40 all calling Watfd, MK, Rugby"
tsr
15 Nov 2011
Between the parallel lines
Looks like 1R09 0627 Wolverhampton-London Euston has brought down the wires at 0738(ish) on the approach to Wolverton Platform 2. It's still there...
Goatboy
23 Jun 2011
Yet more OHLE issues. Should we really be so desperate to bring this sort of problem to the entire network at a cost of billions of pounds?
oversteer
26 Jan 2011
What with Southern, SE and SWT all having third-rail pickup issues, now this OLE issue, it's not a good day for electric trains!
Still, at least the MML and ECML are OK *tempts fate*
tom1649
5 Jul 2010
Well hopefully the new stuff will be better put together.
YorkshireBear
23 Jul 2010
Electric trains don't break down as much so you could say that the problem is just different rather than making it worse...
northwichcat
23 Jan 2009
Northwich
That does refer to an average. It doesn't mean a modern DMU is automatically less reliable than an old EMU because it's a DMU.
It does seem the two electrified mainlines (WCML and ECML) have frequent problems compared to electrified commuter routes like Manchester-Glossop/Hadfield and also HS1. I wonder if things can be done differently on the GWML and MML line to have less frequent electrical failures. Obviously, the ECML hasn't had the same level of investment as other lines but the WCML has had a lot of investment.
YorkshireBear
23 Jul 2010
Well yes i just mean generally. So electrification does have benefits especially when electrifying routes with least reliable units in the country (142s). Ie across the north.
It can only be hoped the newer stuff doesn't come down easily...
ushawk
5 Nov 2010
Eastbourne
You cant compare the WCML to commuter routes in the Manchester area - the WCML is a lot more extensively used.
OHLE on HS1 is more robust as well because of the higher speeds and is probably maintained a lot more too.
Crossover
4 Jun 2009
So maybe it isn't just the ECML that suffers after all. I have to say, having seen the thread title, I wondered if it was the thread from the other week, as the dewirement this time can't be far from the last!
There again, with the WCML, it seems to be "pockets" of problems. Wolverton being one and the line through Penkridge managed to dewire itself a couple of times in quick succession last year as well.
At least on this occasion, the slows are still open, as I think the dewirement the other week closed all 4 lines for a while, didn't it?
northwichcat
23 Jan 2009
Northwich
The WCML should of course allow for being more intensively used and also has quadruple track for much of it.
The single track section at Glossop actually sees 4tph, while at Stockport the WCML sees 3 electric tph on the line through platform 2 (all Virgin) and 3 electric tph (all Northern) on the line through platform 1.
This is one of those WCML locations with 125mph EPS round reverse curves on full tilt.
Matt Taylor
31 Aug 2008
Portsmouth
Disruption ongoing due to OHLE issues from this morning, person reported as having been hit by a train at Bletchley in the last few minutes.:cry:
londonmidland
22 Dec 2009
Leicester
From NRE:
"A person has been hit by a train between Cheddington and Leighton Buzzard.
Because of this, there are delays of up to 60 minutes between London Euston / Clapham Junction and Bletchley. These delays will continue until further notice."
Not looking good...
GB
16 Nov 2008
Somewhere
1T18 at Denbigh Hall Jn apparently. Working on getting fast lines opened.
tsr
15 Nov 2011
Despite the fact this was sadly a fatal incident, all involved have done very well in service recovery - 1T18 is now on the move. I expect following services to resume shortly.
jon91
18 Oct 2010
Blackburn
You're comparing a relatively slow speed commuter route with a 125 mph main line, the forces on the contact wire from an incorrectly set up or damaged pantograph at 125 mph will be much higher than your little EMU pootling down the line to Glossop.
At 2300 Monday this is what it still says on NRE (it's been there all day):
Due to the amount of work needed to repair the damage, it's currently unclear how long this disruption will last, but current estimates are that it may take most of today - please check back later for further updates
Still no advice on what is happening tomorrow.
Amid the various Twitter updates there are "line cleared" messages, but this might only relate to the Bletchley problems, not the Wolverton dewirement.
Huge VT delays continue (90-120 minutes common).
Reporting not very helpful.
Starmill
18 May 2012
Bolton
:o Rude, actually!!!
jon91
18 Oct 2010
Blackburn
I'm waiting for the LNW sectional appendix to be thrown at me... <D
I don't have anything against said EMUs, honest guv'nor.
Because diesel powered trains never fail.... ever?
I would like to see some sort of analysis of the number of problem free running miles obtained on an electric railway compared to a diesel one.
Then I would like to see a relative costing taking into account the numerous maintenance and operational advantages of electric over diesel.
MK Tom
31 Aug 2011
Milton Keynes
I've lost count of the number of times I've suffered WCML disruption due to broken down class 66s, Voyagers or older freight locos. Voyagers have a, ahem, track record of doing little things like ingesting water through their exhaust vents, or catching fire.
Everybody on here knows the advantages of electric traction around operating costs, track wear, reliability and so on. Not to mention the problems with diesel fumes at enclosed stations. Ever walked out of the underground at Marylebone and been hit in the face by that smell? I'd be interested to know if travelling from Marylebone causes a higher occurrence of respiratory disorders.
OHLE problems on the WCML do usually happen in the same places and there may be a need to reintroduce a 110mph speed limit over locations like this just to prevent this sort of thing happening. But that would have obvious impacts not just on journey times but on the entire timetable for all services.
