Off-peak ticket used during peak time
Puffing Devil
11 Apr 2013
Good heavens this is so far gone. Yes you can! What is the purpose of an excess fare otherwise? It is in condition 9 which is helpfully called "Travelling Without A Valid Ticket" and explains how you excess an invalid ticket to a valid one. You're better than this.
It's a complicated situation, and there are two ways to look at it, which seems to be at the heart of the disagreement.
One argument suggests that a railcard's minimum fare is functionally a time-restricted ticket, and therefore, an excess fare should apply. The basis for this is that both the minimum fare rule and a standard time restriction, such as an "Off-Peak" ticket, serve the same purpose of limiting discounted travel during a specific time period. A ticket that fails to meet the minimum fare is thus seen as "invalid for the service on which you are travelling" due to a time restriction, and according to Condition 9.5, an excess fare should be charged for the difference.
However, the stronger legal argument is that a railcard's minimum fare is not simply a time-based restriction, but a fundamental condition of the ticket's validity. The National Rail Conditions of Travel (NRCOT) makes a clear distinction between a ticket that is incorrectly used and one that is invalid. The NRCOT states that a railcard can have "additional restrictions which will apply to any Tickets you buy when using it," and a violation of these terms means the passenger is treated as having "joined a train without a valid Ticket". The document explicitly states that for a passenger without a valid ticket, the train company is permitted to issue a penalty fare or charge the full undiscounted fare, but it does not list excessing as an option. The ticket's fundamental invalidity due to the railcard rule supersedes the more common time restriction violation.
furlong
28 Mar 2013
Reading
Which is a statement of fact in 8.2.
But once again, where does it say that? The quote comes from 8.5 which only covers someone who can't present the necessary railcard.
The ticket remains valid after 10am. How is that not a simple time restriction?
The reason for this is that the ticket is treated as fundamentally invalid from the start due to the Railcard conditions. As outlined in Condition 8.4, when you purchase a Railcard, the full terms and conditions will be provided to you. Furthermore, Condition 8.2 specifies that the Railcard may have additional restrictions which will apply to any Tickets you buy when using it. This is key. Condition 8.5 states that if you are travelling with a Railcard discounted ticket and are unable to present the Railcard, you "will be treated as having joined a train without a valid Ticket". The same logic applies when the ticket itself violates a key term of the Railcard, such as a minimum fare. Condition 9.2 then specifies the allowed actions for a passenger without a valid ticket. These include charging the full, undiscounted fare, issuing a penalty fare, or reporting the incident for prosecution. The document does not list excessing the fare to meet a Railcard's minimum as an option.
The SRA rule does not apply in this case, as it involves a stacking of errors, not just a minimum fare issue.
Identical cases? Off-peak ticket out of hours stacked with a Railcard discount?
Do you accept that under the SRA rules, it was explicity stated that a PF was not appropriate for a time restricted ticket to be issued a PF for travelling at a restricted time?
If so, do you think this changed in 2018?
If so, do you have any documentation stating this definitely changed and/or that the intention of Government at the time was to increase the scope of PFs to include this reason?
Kite159
27 Jan 2014
West of Andover
As you're not Penalty Services, at the end of the day, that's not your call. Sorry to spoil your fun.
Pretty sure this is something you've been posting for quite a number of years now? Perhaps you ought set us a deadline by which your suggested change will have come into force ;)
Most likely it will get changed so those Railcards either gain a blanket time restriction on use, or have a blanket all day minimum fare (similar to the Network Railcard in the former NSE area). Simply to do away with the 'confusing' minimum fares before 10am rule which has been around for many years.
Maybe even doing away with confusing off-peak fares so the only fare available is the peak time fare, like they are doing in Wales ;)
Starmill
18 May 2012
Bolton
So you often suggest!
Puffing Devil
11 Apr 2013
I understand your point, and it is a good one, but the legal reasoning goes a bit deeper than just being unable to physically present the card. The National Rail Conditions of Travel states that a railcard has "additional restrictions" which apply to any tickets you buy with it. The legal leap is that the validity of the ticket is contingent upon your meeting all of those restrictions. A ticket purchased in violation of a railcard's terms, like the minimum fare rule, is treated in the same way as a ticket without a railcard being presented at all. In both cases, a fundamental condition for the ticket's validity has not been met. Whether the railcard is physically absent or its terms are violated, the ticket is invalid, and the railway company is justified in issuing a penalty fare for travelling without a valid ticket.
The key is that the discounted ticket and the railcard are not two separate entities. They form a single, conditional contract for travel. The NRCOT makes this clear by stating that a railcard can have "additional restrictions which will apply to any Tickets you buy when using it". The minimum fare rule is one of these restrictions. The validity of your ticket is entirely contingent on you fulfilling this condition. If you don't, the contract is broken, even if you hold both the ticket and the railcard.
Your question goes to the heart of the matter. While Condition 8.5 literally says "unable to present the Railcard," this phrase can be interpreted more broadly in a legal context. It doesn't just mean a physical absence. Consider this analogy: a Tesco Clubcard has a condition that a discount is only applied on purchases over £100. You have the physical card with you, but you try to use it on a £5 purchase. You can't "present" the card in a valid state for that transaction. The card is present, but it's void for that specific use. The same principle applies here. When a ticket violates the minimum fare rule, the railcard is present, but invalid for that specific journey. Because a necessary condition of the contract has not been met, the ticket is treated as invalid from the start, a principle supported by the wording of Condition 8.5. This is why the railway is justified in issuing a penalty fare for travelling without a valid ticket, rather than a simple excess fare for a ticket used improperly.
You're asking, under the SRA rules, it is explicitly stated that a penalty fare is not appropriate for a time-restricted ticket used outside the specified time period. The simple fact is that what the SRA may have stated is no longer relevant. The SRA was replaced by other bodies in the early 2000s, and the laws governing penalty fares have since undergone changes. The legal framework currently in effect is the Railways (Penalty Fares) Regulations 2018.
You've also asked if this changed in 2018 and if I have documentation. The legal framework for penalty fares underwent changes in 2018 with the introduction of new regulations. This change is what governs the situation as it stands today. Under the current National Rail Conditions of Travel, a penalty fare is explicitly allowed as an option for this type of violation. The NRCOT states quite clearly that you may be issued a penalty fare for travelling with a ticket that is not valid. The ticket in this situation is invalid because it violates the railcard's terms, which are separate from a ticket being "service-specific". While I cannot speak to the government's specific intention for making these changes, the legal text itself serves as the documentation.
The core of the matter is that the new rules allow the railway to see this as a more serious issue than a simple time restriction that can be corrected with an excess fare. The rules now explicitly permit a penalty fare for this specific reason, regardless of what the outdated SRA rules may have said.
This misses the bigger picture.
It isn't.
It said that prior to 2018, but you admit that PFs couldn't be issued for this reason back then?
But you admit you don't actually know this is the intention of the new rules?
The people who approved the new rules didn't understand the nuances.
I am far from convinced that a PF can legitimately be issued simply because "a ticket is not valid".
So you think a PF can be issued for being on the wrong route, or being on an Off Peak Day return from (say) Birmingham to Nottingham at 17:00 when an Off Peak would be the appropriate fare?
That seems to be an admission that the rail industry behaves incorrectly.
It's a time restriction.
No such thing. How does one purchase the ticket incorrectly? What does that mean? It has been used incorrectly - at the wrong time.
The railcard's terms haven't been violated. The discount was properly applied to a time restricted ticket and a journey entirely within the conditions. It is not a breach of the railcard conditions to travel earlier, and even if it was, the NRCoT provides and limits the company's recourse.
...It does. That is why it says that. It is really clear. It could say other things, like "if you break the terms of your railcard" but it doesn't. This section does literally mean your inability to present the railcard. Your entire argument hinges on this Hail Mary attempt to make this part of the terms say something else. And it really does not look like anyone else in the room is buying it.
It does not make the Clubcard invalid or the purchase invalid though. It just means you can't get the discount. This is a complete red herring.
It isn't. It says that:
You may be issued a penalty fare for travelling with a ticket that is not valid.
And subsequently clarifies there are some types of invalidity which *will* (important word compared to may!) be disposed of by way of excess fare. It is therefore the only remedy.
It doesn't. The ticket itself does nothing of the sort. It is a perfectly acceptable ticket to buy. You just cannot use it on a train at the time the OP did without paying up to the correct fare.
This isn't the 4D chess you think it is. Northern quashed convictions and stopped others for the sole reason they accept - as is fairly obvious - the minimum fare constitutes a time restriction on a ticket, and the matter has to be disposed of with an excess. Which is what the NRCoT says.
Alex C.
7 Jan 2014
there is a legal rule in contract law, contra preforentum, which essentially says that when a contractual term can reasonably be interpreted in two ways, it should be interpreted in the favour of the party who did not draft the contract.
I think the debate on both sides would support application of that and the narrower interpretation should be used (only failure to present a railcard entirely triggers 8.5).
Starmill
18 May 2012
Bolton
If there's doubt about the meaning of condition 8 it should also be interpreted in whichever way is most favourable to the consumer. This is a special provision that only applies to business to consumer transactions, and is in line with the more general provision you rightly mention.
davews
24 Apr 2021
Bracknell
What Puffing Billy is trying to suggest has wider implications with all railcards. Suppose there is disruption and my normal off peak train to London is delayed but I get on the train before which arrives later than my normal train but is technically a peak service. I am expected to get a penalty fare because I bought it with a Senior Railcard? I suspect not as the reason I got the other train was for things outside my control. I fail to see why whether a rail card was used for a journey or not, having bought a ticket with good intentions and due to misunderstandings bought it at the railcard price, you would still only be expected to pay the correct fare for the train you used.
Starmill
18 May 2012
Bolton
It used to be the case that some companies would refuse to permit earlier departures in this case.
Nowadays they agree to allow you to use any of their services two hours before or two hours after your planned service. They do not however always make that obvious.
I'm not going around the houses with this anymore - let's see what the outcome is.
The rail industry and the legal system (unless pushed to a high level) cannot be trusted to come out with a correct outcome.
Excellent post, thank you!
EmbedShampoos
5 Sep 2025
Hi. Thanks to all the spirited discussion from railway experts. I had typed up a longer, more detailed response but the forum's server timed out and I couldn't recover the message.
I have made the first appeal on https://www.penaltyservices.co.uk/. Once again, thank you all for your input.
jumble
1 Jul 2011
Until the NRCOT gets changed to remove the right to attempt to use a Railcard discounted offpeak ticket at a time where they would have needed an anytime ticket without a Railcard discount. But agreed the OP should have been excessed to £12 in line with the minimum fare.
Chances are the OP knew what they were doing and was hoping the poorly trained agency barrier staff at Leeds to just take a glance at the ticket and open up a manual gate without actually looking at the ticket in detail.
Just to be clear
Are you saying thet if the OP had not used their railcard they would have paid £3.80 and would be entitled to be excessed to £4.00 to regularise things but because they used a railcard they should pay have to pay £12.00?
Kite159
27 Jan 2014
West of Andover
Just to be clear
As there is a minimum fare for using that railcard before 10am as part of the long-standing T&Cs which the OP would have agreed to, even if simply clicking "Agree" without actually reading them.
It is not what they are entitled to under the NRCoT though, which is an excess to the cheapest possible valid ticket.
Tetchytyke
12 Sep 2013
Isle of Man
Just to point out that appeal stages one and two are not independent, no matter how much Penalty Services argue otherwise. You may need to be persistent on this one.
So £12 then, as you can't excess away the railcard discount element
[citation needed]
It may be internal policy that the industry refuses to excess away a railcard discount, but that is not the same thing at all. I can't recall this ever being stated in any term or condition presented to the public. Internal policies are not contractual terms.
In any event, even if that were true it further supports the argument that a Penalty Fare should not have been issued. Even if the excess was £12-[fare paid] that is a lot cheaper than £50/£100+fare.
Kite159
27 Jan 2014
West of Andover
Where do the NRCoT say that?
"8.2 The Railcard may have additional restrictions which will apply to any Tickets you buy when using it."
Unless you are somehow claiming the £12 minimum fare for usage before 10am on a weekday (excluding July & August) isn't an 'additional restriction'. Similar to the restriction on say a Network Railcard which can't be used before 10am (other than on certain listed easement journeys) when someone buys a network railcard discounted 'Anytime' ticket (above the £13 minimum fare) and tries using it before 10am.
Tetchytyke
12 Sep 2013
Isle of Man
unless you are somehow claiming the £12 minimum fare for usage before 10am on a weekday (excluding July & August) isn't an 'additional restriction'.
There is a minimum fare if you are using the railcard. That is agreed.
But where, in any terms or conditions, does it say that the railway cannot excess a railcard discounted ticket to a non-discounted ticket?
Kite159
27 Jan 2014
West of Andover
So where does it state within the T&Cs that the railcard can excess a railcard discounted ticket to a non-discounted ticket?
The Railcard restrictions are, in this case, simply an additional time restriction, making it a time-restricted ticket. NRCoT 9.5.1 states that in such cases you "will" (not may) be charged the difference to "the lowest price Ticket that is valid for the train you are using". Clearly, the cheapest valid ticket in such situations would be the undiscounted public fare.
I have no idea where the idea comes from, that you can excess someone to the Railcard minimum fare when it exceeds the undiscounted public fare!
CyrusWuff
20 May 2013
[citation needed]
The Ticketing and Settlement Agreement states the following:
Ticketing and Settlement Agreement said:
An Excess Fare may only be Sold if it entitles the Purchaser of it to:-
  • travel via a different route than the one he would otherwise be entitled to use;
  • travel at a different time or on a different day than he would otherwise be entitled to travel;
  • terminate or break and resume his journey at a Station at which he would not otherwise be entitled to do this;
  • use a better class of accommodation;
  • travel beyond the Station to which the Fare he holds entitles him to travel, but only where he was unable to buy a Fare that entitles him to make such a journey at the Station where and at the time when he started his journey; or
  • start his journey at a Station that is on the Permitted Route for the Flow that he is entitled to use, where he would not otherwise be entitled to do this.
Whilst TOCs may have a local policy that allows staff to Excess away a discount, there is no entitlement for this to happen under the TSA and the correct procedure (on a strict interpretation of the TSA) would be a refund and reissue. This may or may not incur an admin fee, depending on where the original ticket was purchased.
Refund and reissue is preferable to issuing an Excess anyway, where possible, given Excess tickets are generally rejected by ticket gates so both the Excess and the original ticket can be checked manually.
Customers are not parties to the TSA though, so whilst that may explain the process element of things it doesn't change the customer's entitlement under the NRCoT to an excess to "the lowest price Ticket that is valid for the train you are using".
Tetchytyke
12 Sep 2013
Isle of Man
The TSA is an internal agreement between RDG (and its predecessor) and the retailers. Passengers are not a party to that agreement.
The contract between the retailer, the operator, and the passenger is the NRCoT. And that says you are entitled to an excess to "the lowest price ticket valid for the train you are using".
Kite159
27 Jan 2014
West of Andover
And so there is this concept of having your cake in buying a railcard discounted ticket for a time it isn't valid due to an additional restriction (as well as being not valid due to being an off-peak ticket rather than an anytime) and the only punishment if you are caught out by barrier staff who are paying attention is simply paying what you should have paid originally?
So similarly, I presume if you are in Tesco buying loose veg and 'accidentally' select a cheaper veg at a self-service checkout, you simply have to pay the difference if caught out?
Tetchytyke
12 Sep 2013
Isle of Man
To add, it's interesting how the terms of the Two Together Railcard are structured.
This is the only railcard which is specifically and expressly not valid at all between 0430 and 0929 on weekdays.
Even then, the terms state this:
2.10. If you fail to comply with condition 2.7, 2.8 and/or 2.9, the Train Company reserves the right to charge you the full price for the single fare applicable to your journey, as if no ticket had been purchased before starting the journey.
2.7 refers to buying before boarding (where facilities exist), 2.8 refers to carrying the railcard, and 2.9 refers to the photo having to match the person carrying the railcard. The time restriction is condition 4.5. This is not mentioned in condition 2.10.
Therefore even when using the only railcard not valid at all in the morning peak, the implication is still that you can excess to a non-discounted ticket.
How is that any different to the situation where someone attempts to travel in the peak time with a non-discounted off-peak ticket?
